Cloudy Coolant
+ Reply to Thread
Results 1 to 7 of 7
Thread: Cloudy Coolant
  1. #1
    SupraForums Member
    Join Date
    Mar 2006
    Location
    The Netherlands
    Posts
    942
    Cloudy Coolant
    Guys,
    not really stressing here, but i noticed my coolant was kind of 'cloudy'. Did a search, and only found people yelling BHG. So, i checked the oil filler cap, looked good, same for the dipstick. Took a sample from the oil drain plug; clean blacked oil, no contamination. Fired the car up, no smoke out of exhaust.
    just wondering if it's just the cooling system on my old old car. (150.000 miles)
    any thoughts?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    second chance at life deck's Avatar
    Join Date
    Jun 2007
    Location
    in my supra of course
    Posts
    1,956
    Have you ever flushed the cooling system? How old is the coolant ? Maybe its time for a flush.
    540 rwhp on 93 pump gas. Tuned by Alpha
  4. #3
    The Great Kruso Kruso's Avatar
    Join Date
    Mar 2002
    Location
    Sugar Land, TX
    Posts
    3,869
    Quote Originally Posted by deck View Post
    +1
    1991 MKIII Toyota Supra 1JZ, the "official" FFIM MKIII- Officially stolen.
    1994 MKIV Toyota Supra Single T70, Fuel, MAP ECU, RPS 6 puck................Sold.
    1993 MKIV TT w/ 79k original miles APU
    2011 Toyota Tundra 5.7 Rock Warrior
    Quote Originally Posted by Zach90Turbo View Post
    When I put 7M in the search it only came up with blown head gasket threads.
    "There is so much good in the worst of us, And so much bad in the best of us. That it behooves all of us Not to talk about the rest of us."
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Mar 2006
    Location
    The Netherlands
    Posts
    942
    i pulled the radiator some time last year, flushed that out and refilled from there, so a semi-flush yeah. Like i said, doesn't really appear to be anything wrong.
    I figure i'll pull the sparkplugs this weekend and get a look into the engine, eventhough the oil already told me nothing is wrong.
    I'll have to plan a flush some time soon and go from there.
    Thanks so far, any other thoughts?
  7. #5
    A zone of danger. Dego Red's Avatar
    Join Date
    Apr 2005
    Location
    SE Michigan
    Age
    36
    Posts
    1,175
    I had one of the few MKIV's that lost a HG, and at a mere 63k miles while breaking in a clutch (no boost), nonetheless. Built on a Friday or a Monday I suppose. I managed to catch it instantly after parking the car, so I had zero engine damage, and went on to go single/fuel/etc etc.
    Rather than ask a bunch of questions, here's a pic for your reference. Oil on the left, coolant on the right. Samples taken first, then confirmed blow-by on 4 of 6 cylinders.
    You have to imagine the oil w/o the flash. It was actually a little tough to tell if anything is wrong with the oil, so the coolant should be your tattletale.
    HTH
    Mike
  8. #6
    SupraForums Member
    Join Date
    Mar 2006
    Location
    The Netherlands
    Posts
    942
    Thanks for posting up Mike, Can't say my coolant is looking that bad yet, but i sure don't hope it's the HG, had it replaced and the head decked when i got the car 3 years ago. Like i suggested earlier, i'll pull the plugs to check inside the cylinders and i'll see if i can pickup a compression tester as well.
    i'm still in disbelief as i would think of it to be impossible to blow a HG on a 2jz, especially at only 450 crank horsepower.
  9. #7
    SupraForums Member
    Join Date
    Mar 2006
    Location
    The Netherlands
    Posts
    942
    Well, false alarm. Don't know why the coolant appears to be cloudy when i shine my flashlight into the radiator (or why i think it is cloudy), but a sample pulled from it shows watery red coolant, no prob. Nothing like the milky brounish as seen in Dego's picture.
    Pulled the plugs, looks clean, insides of the cylinders looked clean and the compression test yielded good results.
    Cylinder 1: 155
    Cylinder 2: 155
    Cylinder 3: 155
    Cylinder 4: 149
    Cylinder 5: 158
    Cylinder 6: 160
    guess i'm just paranoid from time to time :S, did learn something from this so it's all good.
    Thanks again everyone.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
