is power shifting bad?
+ Reply to Thread
Results 1 to 18 of 18
Thread: is power shifting bad?
  1. #1
    Gov. drug car
    I heard that if you power shift (dont let up on the gas during shifts) a turbo car you can blow the turbine right off the turbo, is that true or is it just a myth.
    thanks
    gov.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Mk3-Mk45-Passport-Eagle Eko Ramadan's Avatar
    Join Date
    Apr 2002
    Location
    CT Power
    Age
    33
    Posts
    570
    damn man i was wondering the same shit, this civic owners do it all the time , it really helps during racing but i'm scared to do it on my supie
  4. #3
    SupraForums Member
    Join Date
    May 2002
    Location
    SF Bay Area
    Age
    34
    Posts
    1,440
    think if it this way, it's like doing a 4k-5k clutch drop launch everytime you shift. It gets you going faster, but at the expense of your transmission and clutch.
    BTW, the Civic guys do it cause they HAVE to in order to make their cars feel just a tiny bit fast. So they treat their car like shit in order to do it.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    ingrupen
    i think 5k launches and power shifting were the reasons why my original transmitions sincro's went. But my new tranny takes it like a champ.
  7. #5
    Buddy thought I had a NA NashMan's Avatar
    Join Date
    Mar 2002
    Location
    canada bc vic
    Posts
    2,455
    well you can do it but it ware the shit out of your clutch and as for power over reg shifting there is no gain over it caues we have turq
    and know you will not rip apar the turbine just eat clutches like mad men
    so other wise don't bother
  8. #6
    Señor Member Interex_87's Avatar
    Join Date
    Mar 2002
    Location
    Allen, TX
    Age
    34
    Posts
    4,741
    I don't think it would do any damage to the turbo turbine. Actually it shouldn't put any stress on the turbine at all. A weak or bad BOV would put stress on the turbine with changing gears conventially. The surge of pressure in the IC pipes when the TB closes would hit the turbine and snap the shaft, but thats why we have BOV's. But when power shifting you let off the throttle very slightly and then slam it into your next gear. The slight back off on the throttle isn't enough to cause any kind of surge in the IC pipes.
    The only damage that I see happening is in the tranny and the clutch.
    Dunno, just guessing....
    Harold
    - '94 Supra Turbo/Auto->6spd swap....PT76-GTS
    - '87 Supra Turbo/5 spd...62-1, 2JZ Intake, etc.
    - '99 Tacoma 4x4 TRD
    - '07 Tundra Limited DCab 5.7L
  9. #7
    fire
    this is a really good question. I don't think it's particularly bad for anything except the transmission. I just wonder if the turbo trans can take it over and over. I owned a 96 mustang cobra (305 horse, 5 speed, 32 valve) for two years and I power shifted that thing and ragged the crap out of it all the time. I traded it in with 86000 miles on it. Zero problems.
    BTW: to say that only weak cars need to shift fast...well, it sounds like you aren't keeping up with anything fast.
  10. #8
    SupraForums Member MKIIISupraGuy's Avatar
    Join Date
    Nov 2001
    Location
    Madtown, WI
    Posts
    1,665
    Powershifting...
    Don't do it on our MKIII's.
    I had a 87 Turbo that ran 14.2 @ 101.2mph. Anyhow I decided to powershift it one night. Did it a few runs and beat some of the street racers here. Then I did an exhibition run with a G-TECH and into 4th gear i heard a little rattle and the car started to shake a little bit... anyhow i ended up shattering the flywheel. So don't powershift on our MKIII Turbo's, there's too much torque and you'll break something. Just do a quick speed shift (lift throttle).
    My bro also has a Hunduh that I drove to a best of 13.3 @ 103mph. Now those bitches you can powershift cause they have no torque and you won't break anything.
    So it dependso on which car you're driving if you want to powershift or not. I was always under the impression that if you lift throttle shift on turbo cars, you let the turbo respool and you'll reach full boost each time.
    just thoughts...
  11. #9
    SupraForums Member
    Join Date
    May 2002
    Location
    SF Bay Area
    Age
    34
    Posts
    1,440
    Re: is power shifting bad?
    OMG, I know this was directed at me. Please re-read what I said a bit more carefully this time. What you imply is not what I said AT ALL.
  12. #10
    Gov. drug car
    those are all very valid points and i appreciate the input.
    thanks
    gov.
  13. #11
    Canada, Eh? Enraged's Avatar
    Join Date
    Oct 2001
    Location
    Victoria, BC, Canada
    Age
    35
    Posts
    2,488
    i only powershift when its raining out
  14. #12
    Great-S
    Re: Powershifting...
    just thoughts...
    in the 80's people were losing there legs cause the flywheel chopped it off once it shatters. but i think power shifting will make you go a little faster cause your turbo doesn't stop spinning. if you have an stronge flywheel, stronge clutch, and don't give a shit about your transmission then by all mean go for it
  15. #13
    W/W91t
    how's that? if you take your car up to 6000 RPM's then powershift your flywheel is still spinning around 6K. so when you put it in the next gear your RPM's will drop to about 4200, right? so your flywheel will actually be taking around a 1800RPM clutch drop. that's if you can shift fast enough. most of us drop the clutch around 3000 RPM's off the line at the dragstrip. so i't's not that bad of a clutch drop.
  16. #14
    SupraForums Member wastegate's Avatar
    Join Date
    Sep 2001
    Location
    Gold Coast, Australia
    Age
    40
    Posts
    475
    Well you won't hurt the turbo but you will hurt the clutch and tranny. If you have a big fu^koff clutch (mine is a 5puck brass button with 3400lb pressure plate) it will mince R154s hitting 3rd.
    This is what happens if you have a clutch that does not slip and you flat change/arcade change/power shift.
    I broke this twice, first time I thought it was a worn part, next time I knew it was the clutch. Because the clutch is so sudden there was no slip and no take up on the gears. When I hit 3rd gear so much torque slammed the gear back into 1st gear then hitting this trust washer into the main rear bearing breaking the washer into 4 parts and messing up 1st gear hub, syncro and the main bearing. $7 part = $1500 repair.
  17. #15
    Moderator
    l337 M0d3r4t0r
    ZaZZn's Avatar
    Join Date
    Feb 2002
    Location
    Toronto/San Francisco
    Age
    35
    Posts
    12,923
    Yep I have only powershifted my car 3-4 times.... I did brake slip the clutch off the line a few times...
    I can shift hella fast and I dont like ragging on my tranny since it already grines 2nd and 3rd when shifting fast....
    I don't think its worth it unless ABSOLUTELY needed to beat that one car that you just hate and have to win. (Bobby I'm talking about you're car) hehe
    As far as dammage to turbo.. Nothing It has nothing to do with it at all.
    However, If you plan to powershift alot like Bobby you'll be buying tranny's in dozens. Bobby's on his 3rd tranny and its dead so hes going to get a full rebulid.. Told him that he's too hard on his car but..
    Anyways...
    Eric W
    87 TT E85
    98 SC 300
  18. #16
    what will the future hold MKIVpowered's Avatar
    Join Date
    Nov 2001
    Location
    Atlanta
    Posts
    1,228
    My guess is that it is not good for the car!
  19. #17
    OB1JZA70
    I am doing it on a daily!
    Anyways...
    I only speed shift really at the track on drag radials and have had no problems w/ my tranny in 4 years. It is useless to speed shoft my current configuration on the streeet tires cause I only burn out through all gears 1-3.
    Orin B Sr
  20. #18
    maxim
    why dont you people wanna shift normally? let off the gas in between, just do everything fast.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
