+ Reply to Thread
Results 1 to 10 of 10
Thread: rod knock possibly
  1. #1
    2JZ sup_dawgTT's Avatar
    Join Date
    Jun 2008
    Location
    New Zealand
    Age
    23
    Posts
    740
    rod knock possibly
    hey guys
    iv been searching for two days now and have read up on the different cases where people had or thought they had rod knock. well i may have a similar problem as i have diagnosed that it gets louder as RPM's increase above 2000 RPM suggesting something internal is touching where it shouldnt be. my question is, would it be straight foward to get to drop the oil pan and get to the crank, undo the rod bolts and check the bearings? or am i missing some way of correcting this problem. also should i replace the bearings or the rods as well - if there is no damage would i be good to use the rods?
    cheers
    Ash
    1993 Supra 6 speed BPU
    1990 Mazda MX5 13B-REW
  2. #2
    Last NA Driver FLZ_Boy's Avatar
    Join Date
    Jun 2005
    Location
    So.Cal
    Age
    37
    Posts
    3,286
    Droping the oil pan is no easy task, as it requires you to lift the engine to provide enough clearance to get the pan out. If your going to replace rod bearings, I would suggest just taking the entire engine out to save yourself the fustration of limited space.
    2012 Toyota Sienna LE 2.7L 6AT (w/Convience Package + Preferred Package)
    2000 Ford Fucus ZX3 5MT (I want my MPG! American Style.)
    1994 Toyota Supra 5MT (SZ-R Project Status: Retired, 2012 Speed Ventures Time Trial CC9 Champion)
    Road Racing Videos: http://www.youtube.com/user/FLZBoy
    World's First Naturally Aspirated MKIV on E85: http://www.youtube.com/watch?feature...&v=h38jB0hSInw
    Quote Originally Posted by johno86 View Post
    Sheldon has no competition.
  3. #3
    Join Date
    Jun 2008
    Location
    New Zealand
    Age
    23
    Posts
    740
    FLZ Boy cheers for the input, i have realized that its no easy task after going through the repair and service manuals. ill have to check the oil and see if a magnet can pick up anthing, if not ill go from there.
  4. #4
    Postcount ≠ Intelligence AlterEgo's Avatar
    Join Date
    May 2006
    Location
    Sugar Land, Texas
    Age
    25
    Posts
    1,361
    If you suspect that you have spun your bearings, why dont you just drain the oil and look for metal shavings?
  5. #5
    [SFOT] Carbon2 SUPRMSC's Avatar
    Join Date
    Jan 2005
    Location
    International
    Posts
    866
    Yeah check the oil first, if it's suspect, then you will need to take a look at the block itself.
  6. #6
    Junior Member
    Join Date
    Jul 2010
    Location
    Calgary, Canada
    Age
    28
    Posts
    142
    sorry to re-ignight this thread but I believe I have some rod knock after tracking my car tonight, I also found out that my engine was running with almost no oil (warning lights also did not show up, so thats a whole other issue). I'm guessing this isn't a repair for someone who's never torn apart an engine correct? my diagnosis was based on some engine sounds I listed too on youtube and its the exact same
    95 USDM NA convert into a TT 6 spd
  7. #7
    Join Date
    Jun 2005
    Location
    So.Cal
    Age
    37
    Posts
    3,286
    If a rod is knocking, chances are the crank, main bearing, rod bearing are damaged and your better off pulling the engine for rebuild OR find a donor engine.
    Used GE engines are relatively cheap to come by, but recently they are not as cheap as they use to be.
  8. #8
    Join Date
    Jun 2005
    Location
    So.Cal
    Age
    37
    Posts
    3,286
    As for tracking the Supra, I would get an oil temp and oil pressure gauge/sending units. The stock oil level indicator light really isn't telling you whats going on with the oil on harsh conditions. High oil temps will kill seals ad bearings. Low oil pressure on high loads will give an indication there is oil starvation (also location of the sending unit does jnfluence the reading.
  9. #9
    Junior Member
    Join Date
    Jul 2010
    Location
    Calgary, Canada
    Age
    28
    Posts
    142
    thanks man, think getting a doner short block is what i'm going to do.
    As for tracking...it happened to be the last track day of the year (and likely last track day in my city as they're closing it down for some bullshit reason) so bad luck I suppose
  10. #10
    SupraForums Member topdog849's Avatar
    Join Date
    May 2008
    Location
    VA
    Posts
    198
    pull each plug wire one by one and listen for a change in knock to find which cylinder it is.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
