why do my rotors keep warping?
+ Reply to Thread
Results 1 to 10 of 10
Thread: why do my rotors keep warping?
  1. #1
    SupraForums Member
    Join Date
    Jun 2001
    Location
    pasadena, CA
    Posts
    439
    I have gone through a few pairs of front rotors recently. both stock and brembo OE replacements (slotted). They keep warping on me. i dont brake HARD and come to a complete stop at the same time which i read was a cause of warpage. any other things that could cause this? i just put on my current set of brembos about 7months ago, and now they are warped already as well.
    Jason-
    94 MKIV 6466 dbb + ATF S3.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member neloner's Avatar
    Join Date
    Mar 2009
    Location
    honeoye falls ny
    Posts
    421
    do you wash your car just after getting back from a ride? It's the radical cool down of the rotor that causes warping, do getting them wet while still hot would cause this
  4. #3
    Speed limits = Guidelines Boosted Rooster's Avatar
    Join Date
    Dec 2006
    Location
    pennsylvania
    Age
    27
    Posts
    1,964
    Quote Originally Posted by neloner View Post
    driving in the rain or over a puddle can also do it...but it takes some very hot rotors to cause warpage, not likely to happen during normal driving, unless he has a frozen caliper(s)
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    backpsi is my batsignal!!
    Join Date
    May 2003
    Location
    MN
    Posts
    6,218
    Quote Originally Posted by mpunisher View Post
    when you install the new rotors. Do you break them in? It might not be warpage it might be that the brake material from the pad is not bedding itself correctly.
    No More supra
    Into taking care of paint on cars. Enjoy all vehicles.
  7. #5
    The Great Kruso Kruso's Avatar
    Join Date
    Mar 2002
    Location
    Sugar Land, TX
    Posts
    3,869
    The only reason why the rotors will warp is if they get very hot to begin with. Obviously they are being applied hard even if you dont think so. There is a slight possibility that the rears aren't being applied at full force causing more strain on the fronts. Are all rotors warping or only fronts? Bled the system recently?
  8. #6
    SUPRAFICIAL KODYHUGHES's Avatar
    Join Date
    Dec 2007
    Location
    CA
    Age
    28
    Posts
    1,512
    I would deffinatly flush your brake fluid with fresh Dot 3. and just make sure the rears arent clogged or anything.. like kruso said.. your front brakes might be doing all the work instead of both the front and back working together.
  9. #7
    Im A Fuking Ninja!!! TonyN's Avatar
    Join Date
    Dec 2007
    Location
    Tucson
    Posts
    4,586
    your calipers might need to be rebuilt because its sticking, causing the pad to not let the rotor float. you also need to bed the pad correct with the rotors, and i also notice some people like to ride the brakes. My frist choice would be to check the caliper itself.
    94 MKIV / SP63 / ATF Stage 3 Auto / FTI 3.5k Converter / CCW SP500 / Meth/Pump 91 = Garage Anchor
    2015 Accord EX-L 33MPG
    2010 Mercedes Benz GLK350 /Premium/ Baby seat = Beast Mode Family CUV
    Click here to enlarge
    More pictures here: http://www.supraforums.com/forum/sho...yN-Version-2.0
    Condition Trumps Mileage: http://www.supraforums.com/forum/sho...dition+mileage
  10. #8
    SupraForums Member
    Join Date
    Oct 2008
    Location
    Sydney,australia
    Posts
    423
    here is a interesting article on rotor warping:
    http://www.dba.com.au/2006/techdocs/T015.asp
    one of the things that were really enforced when i was working at Lexus was to torque every wheel nut by hand with torque wrench.
  11. #9
    SupraForums Member
    Join Date
    Jun 2009
    Location
    Camp Hill PA
    Posts
    346
    I was about to suggest wheel torque as well. If the lugs are unevenly torqued it can lead to warped rotors. It was very common on european cars with lug/stud combos. I don't see why it wouldn't be the same on a standard setup. Impact guns/long breaker bars are generally the cause.
  12. #10
    VVT-i FTW ProjekT_SuprA's Avatar
    Join Date
    Jun 2009
    Location
    Orlando, FL
    Age
    28
    Posts
    628
    ^All of these are very good possibilities. I'd say the top three are probably improper break-in procedure, faulty calipers, or your brake proportioning valve isn't working properly. Check your rear brakes and see how much wear you have on them in relation to your front (on both rotors and pads).
    Our supras, who art in the driveway,
    hallowed be thy name, thy speed has come, thy will never be done,
    on the road as it is on the mind, give us this day your daily beauty,
    and forgive us our speeding, as we forgive those who drive slow,
    and lead us not into incarceration, but deliver us from the five-o ....amen
    A beautiful Supra Prayer by: Kris Paczedlik
    2JZ VVT-i Swap/Build
    http://www.supraforums.com/forum/sho...d.php?t=546316
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
