Wheel/Tire Size/Offset Thread: Search here!
Page 107 of 107 FirstFirst ... 7 57 97 98 99 100 101 102 103 104 105 106 107
Results 2,651 to 2,655 of 2655
Thread: Wheel/Tire Size/Offset Thread: Search here!
  1. #2651
    i recorded mark7m001.mp3 Mark 2JZ's Avatar
    May 2002
    So Cal
    35
    1,922
    rears:
    currently running 18x10 +22 on 285/35, that very slightly rub on rolled fenders.
    changing to 18x11.5 +53 on 315/30
    to my calculations I'll be fine with actually more outside clearance? 12mm...
    Just want to know if that'll clear the coilovers fine
    1994 Supra PT71GTQ
  3. #2652
    Wheel Fitment Guru
    Up here
    3,703
    Quote Originally Posted by Mark 2JZ View Post
    rears:
    Your new wheels will be sucked into the fender approximately 3mm. Your previous rears were past the fender approximately 7mm. About 10mm difference between the two. Inner clearance will be fine.
    R.K.
  4. #2653
    May 2002
    So Cal
    35
    1,922
    thank you sir. seems like that'll be just about perfect then. Wide functional tire w/ no rubbage
  6. #2654
    Jul 2008
    South Florida
    29
    307
    Looking at 18x9 Fronts +35 with a 245/40 or 255/40 and Rears 18x10.5 +35 with either a 275/35 or 285/35. Trying my best not to modify the fenders or poke out past the fenders. I'm lowered on coilovers so I have some adjustment up and down. Am I in the clear?
  7. #2655
    Wheel Fitment Guru
    Up here
    3,703
    Quote Originally Posted by SnakeKouki View Post
    Fronts you have no problem. Rears you'll need to roll the fenders.
    R.K.
