what do you need to install a metal head gasket
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: what do you need to install a metal head gasket
  1. #1
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    i recently purchase a 1989 supra with a bhg i plan to do some upgrades on it like intake catback exhaust, down pipe and maybe some header other than that that would be all the modification i will do to the engine i plan to keep this car for a long time and take it out on the weekend it has a 7mge motor my question is do i have to really install a metal head gasket or could i just go with the toyota one also what do i need to use arp head studs or head bolts this is just going to be a weekend car i am not aiming for turbo or high horsepower i have another car which is a commuter and if i do need to go with a metal head gasket i plan to use the hks 1.2mm can i just install that one immediatly or does the machine shop have to do something with the head i appreciate all the help you guys have given me on the forum
    also what amount of torque should i give to the head to prevent another head gasket
    thank you
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Join Date
    Jan 2008
    Location
    Staten Island, NY Hialeah, FL
    Age
    31
    Posts
    4,966
    I/H/E is a waste of money on a N/A Supra. That is my personal opinion.
    If you want to keep it N/A, I suggest you invest money in suspension and brakes first incase you change your mind about going forced induction. You won't have wasted money in a intake and header.
    You can go with the Toyota Headgasket with ARP bolts. Have the head sent out to a machine shop to get resurfaced and make sure the deck of the block is not warped. Uneven surfaces on the head or block = another blown headgasket.
    Since you have the head off and at the machine shop, have them put in some new valve seals. You also want to make sure the block still has the cross hatches on the cylinder walls. Any type of vertical scratching or marks on the walls may indicate a problem.
    Pick up some new exhaust manifold studs and nuts from Toyota. Coat them with Anti-seize and insert them into the head. Now would also be a good time to pick up a new timing belt and tensioner from Toyota, aswell as all the intake gaskets. This is just my personal preference. I like to get everything done once. I hate to finish everything and then have a problem later on down the road.
    I'm currently using a Cometic metal headgasket with ARP bolts torqued to 85ft/lbs. on my 7MGE, but its currently getting a turbo bolted on to it as I am typing this.
  4. #3
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    is there any other name for the tensioner you speak off i can find it on champion toyotas website
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    do you know if the valve seals come with the toyota head gasket kit also arp head bolts that say they are for the 7mgte will work on the 7mge?
  7. #5
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    so 85ft/lbs of torque will be good on my toyota head gasket
  8. #6
    Join Date
    Jan 2008
    Location
    Age
    31
    Posts
    4,966
    Quote Originally Posted by mazinkaiser View Post
    Timing Belt tensioner and spring. It applies pressure to the timing belt and keeps it nice and tight.
    Usually a Headgasket Kit will include every gasket and seal from the head up.
    ARP headbolts for the 7M are all the same.
    Do 75ft/lbs.
    Also, pick up some Copper spray and coat the headgasket with about 2-3 coats. Apply some to the deck of the block and head aswell.
    Available at your local autoparts store.
  9. #7
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    i use the copper spray on the toyota head gasket?
  10. #8
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    you wouldnt happen to know the toyota part number for the tensioner and spring?
  11. #9
    Join Date
    Jan 2008
    Location
    Age
    31
    Posts
    4,966
    Yes. Use the copper spray on the Toyota gasket. I even used it on my metal headgasket.
    I will have to check on that part number when I get home. I'm posting on my blackberry now.
  12. #10
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    is the tensioner the same this as the idler pulley
  13. #11
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    would i also need the Camshaft Seals Front Main Seals since im changing the idler pulley and spring
  14. #12
    Join Date
    Jan 2008
    Location
    Age
    31
    Posts
    4,966
    Yeah. For the Timing Belt.
    No. But It wouldn't be a bad idea.
    If you buy the complete headgasket kit, it will bring cam seals, valve cover gaskets, intake manifold gaskets throttle body gasket, exhaust manifold gasket, valve stem seals, and headgasket.
  15. #13
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    would it be a good idea to change the water pump also
    thanks for your help degree
  16. #14
    Join Date
    Jan 2008
    Location
    Age
    31
    Posts
    4,966
    Yup. Water pump and thermostat replacement would be a very good idea. Especially if they are the original parts from the factory. Nobody knows when they will fail.
    Honestly, if you can... I'd just do a complete rebuild if you're going all out. The only things you have left to replace are the bearings and piston rings. lol
    You say you have a daily driver so my vote would go to pull the engine and rebuild it.
  17. #15
    A Happy Dad mdr40z's Avatar
    Join Date
    Dec 2002
    Location
    Markansas
    Age
    58
    Posts
    2,321
    yes, it's not very hard or much additional expense
  18. #16
    Join Date
    Oct 2009
    Location
    United States
    Posts
    36
    is the thermostat easy to replace on the 7mge
  19. #17
    Join Date
    Aug 2009
    Location
    merrill, WI
    Posts
    47
    Yea, the thermostat takes about a whole 15 minutes if your slacking off
    white trash jap crap
  20. #18
    Join Date
    Jan 2008
    Location
    Age
    31
    Posts
    4,966
    Follow the upper rad hose to the engine.
    that is the thermostat housing.
  21. #19
    Join Date
    May 2009
    Location
    Shippensburg, PA
    Age
    38
    Posts
    17
    DegreE, damn. I know I'm pretty new around here, and I don't know you right, but I've read a lot of your posts, but are you feeling alright? Don't take that wrong, I'm a fan, but it's like you got the sand out of your vagina today.
  22. #20
    2Fast4U OneJSupra's Avatar
    Join Date
    Nov 2006
    Location
    Orlando, Fl
    Posts
    1,058
    Quote Originally Posted by anonymic View Post
    rofl
    1JZ | Stealth ECU | PTE CEA 6266 Billet |Tuned by ME-Motorsports
    Click here to enlarge
  23. #21
    SupraForums Member boricua114's Avatar
    Join Date
    Mar 2009
    Location
    Florida
    Posts
    482
    aahahahahahahaha
  24. #22
    SupraForums Member justforkiks's Avatar
    Join Date
    Mar 2006
    Location
    Arizona
    Age
    40
    Posts
    40
    Quote Originally Posted by DegreE View Post
    Do 75ft/lbs.
    werd copper headgasket spray makes for a nice seal. Dont forget to chase your threads in your block with a tap to get a nice clean hole and proper torque reading. I think its a 12mm x 1.25 tap if I remember correctly.
  25. #23
    SupraForums Member blacksupra7mGTE's Avatar
    Join Date
    May 2007
    Location
    maryland
    Age
    29
    Posts
    41
    u shouldnt need the spray stuff and as long as the head or block has not been shaved a 1.2mm hks head gasket will work if u go with the arp studs
  26. #24
    Supra Moderator Zumtizzle's Avatar
    Join Date
    May 2006
    Location
    NorCal
    Posts
    4,595
    DO NOT SPRAY COPPER SPRAY ON A NEW MHG!
    Viton does not play well with Copper Spray.
    Welcome to my nightmare!
  27. #25
    Overlooked bassjunkiens5's Avatar
    Join Date
    Jul 2006
    Location
    Nashville
    Age
    31
    Posts
    4,677
    ^ I was thinking that but wasn't too sure. HKS MHGs come with a sealer on them.
    People tend to make a bigger deal out of somethings than are needed I think. Just get the head and block resurfaced, use ARP studs and torque to 75lbs. You'll be set.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
