+ Reply to Thread
Page 4 of 4 FirstFirst 1 2 3 4
Results 76 to 86 of 86
Thread: Stock Twin Removal - How To
  1. #76
    wow.. seeing this makes me glad that i wont need my supra to run for a long time.. and im just going to slowly build it with a single. i would hate to take these off on the car..
  2. #77
    Junior Member
    Join Date
    Oct 2008
    Location
    Honolulu, HI
    Age
    31
    Posts
    126
    Awesome write-up. Defintely helped me take my stock twins out last night. The whole process took about 5 hours, mostly due to frustration, banging my head on things, etc. Thanks again!
  3. #78
    Join Date
    Dec 2007
    Location
    Philadelphia
    Age
    30
    Posts
    91
    Just removed these last week - the best feeling is when they are out and you know they are not going back in, - cast manifold 6266, ETS intercooler w/ TiAl 50mm BOV, TiAl 40 mm WG going back on!
    Had to invent some interesting leverage solutions for the bitch bolt and stock WG bolts in general!
  4. #79
    Join Date
    Sep 2009
    Location
    Wasco, Cali
    Posts
    6
    Great write up, and thanks for all your input. I will be using it with in the next couple of weeks.
  5. #80
    Raising the BAR Dj6ta's Avatar
    Join Date
    Sep 2010
    Location
    College Station, TX
    Age
    25
    Posts
    2,145
    Blog Entries
    2
    Did you guys unbolt the mounts and lift the engine to get to most of the bolts? When I took mine off I did and it made the job so much easier.
    Downside to owning a Supra
    Quote Originally Posted by -defi- View Post
    down side? when girls get in and ask "where is the cup holder?"..... real question.... "Who the F*%! said you could bring a drink in here?!".
  6. #81
    SupraForums Member aphlux's Avatar
    Join Date
    Aug 2010
    Location
    Texas
    Posts
    1,097
    I just want emphasize something the OP posted.
    BUY A 14MM STUBBY IF YOU DO NOT HAVE ONE.
    We just pulled the twins off the car tonight for the first time in car and man, did that save us on the bitch bolt and the 4 bolts on the bottom that connect the turbos to the manifold.
    http://txcars.blogspot.com/
    A photodump of car pictures i've done while in Texas
  7. #82
    SupraForums Member Biologist's Avatar
    Join Date
    Jun 2011
    Location
    In My Laboratory
    Posts
    1,002
    took alot of parts off today, the harness/clips on the front next to the water pump was a bitch
    1994 Auto Renaissance Red MKIV 73k Miles 60mm|HKS|TiAL|GReddy|ProCharger|Marks Engineering|Widen Stockers
    Quote Originally Posted by Wreckless View Post
    I've basically ruined my life both financially and in career progress for the sake of keeping my Supra projects alive.
    Zero regrets.
  8. #83
    Join Date
    Jul 2011
    Location
    Calgary, Canada
    Age
    23
    Posts
    68
    For the bitch bolt I just put a 14mm stubby on it and hit the wrench with a 3lb mini sledge I always keep handy.
    Was a piece of cake.
    Once you've unlocked hammer wrench mode, there is no going back. You'll look at life in a whole new way.
    In cramped spaces with tiiiight fasteners it's so much easier than trying to get enough leverage to crack them. Not enough room to swing a hammer? Use a drift to transfer the hammer blow to the end of the wrench.
  9. #84
    Moderator
    Join Date
    Jan 2007
    Location
    huntington beach
    Posts
    46
    Just removed the stock twins on my SC300 with 2JZGTE swap, this thread was extremely helpful. Thank you for putting this together.
    I ended up rounding off the "bitch nut" so actually had to remove the turbos and manifold together which actually wasn't that bad at all and I think actually saved me some time. The trick to getting to all the nuts on the bottom of the manifold with the turbos still attached is a long 14mm ratcheting flex head wrench and you can get to the nuts from under the car.
    I let the bolts soak in PB Blast overnight which I think helped a lot because I didn't need to apply much force to get all the bolts loose.
  10. #85
    SupraForums Member
    Join Date
    Aug 2012
    Location
    Atlanta
    Posts
    217
    Can I just say that removing the turbos was easily the worst experience I've ever had with my car. This guide was invaluable though in helping me through the process. Have stubby box wrenches handy, a breaker bar, jack stands, a million extenders, and like 3 cans of PB Blast before attempting this.
  11. #86
    Join Date
    Jun 2011
    Location
    In My Laboratory
    Posts
    1,002
    Anyone lose their arm stays the 19mm bolt?? I lost mine and im not sure what the part number is!!!!
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
