7mge to 7mgte common problems?
+ Reply to Thread
Results 1 to 7 of 7
Thread: 7mge to 7mgte common problems?
  1. #1
    Join Date
    Mar 2010
    Location
    tacoma
    Posts
    37
    Alright got almost everything I need to know cept a few things like, does the gte bolt onto the W58 transmission? Is there anything else that this swap requres? I already know about tac. Ecu for ge works on gte i think. Any other problems that pop up. Sorry bout bringing this up again but I just can't find shit about it on the forums.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SF Contributing Member 87supramario's Avatar
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,362
    if you have a 7mgte i would not waste it with a w58. get the r154 if your going gte
  4. #3
    (◕_◕) Hitman's Avatar
    Join Date
    Jul 2008
    Location
    Tampa, FLOORIDUH
    Age
    29
    Posts
    3,754
    If you are going GTE, get everything that is on a GTE car, like the R154, driveshaft, ecu, wiring harness.
    7M-Clevite bearings, Eagle Rods, Carillo Pistons, Treadstone TR1235 Intercooler, Tial F46, HKS SSQV, Mishimoto Radiator & Clutch Fan, Apexi Neo, Beech Performance stuff & adding more...
  5. #4
    Join Date
    Mar 2010
    Location
    tacoma
    Posts
    37
    Everything fits in without any cutin or weldin?
  6. #5
    Join Date
    Jul 2008
    Location
    Tampa, FLOORIDUH
    Age
    29
    Posts
    3,754
    100% yes, I got a donor car for my swap to make it a little easier. No cutting, or welding. For the clutch master cylinder you have to pop out two plastic body plugs on the firewall. That is the most fabrication you will have to do.
  7. #6
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,362
    Quote Originally Posted by Hitman View Post
    would you need a gte rear end aswell?
    Click here to enlarge
    Resurrection complete. Build thread-> http://www.supraforums.com/forum/sho...surrection-1JZ
  8. #7
    Join Date
    Jul 2008
    Location
    Tampa, FLOORIDUH
    Age
    29
    Posts
    3,754
    Depends, you might want a gte rear end, or you could put an aftermarket diff in your existing one.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
