Idle speed control valve HELP
+ Reply to Thread
Results 1 to 8 of 8
Thread: Idle speed control valve HELP
  1. #1
    Join Date
    May 2010
    Location
    Troy oh
    Posts
    13
    Hey guys I could really use someone's help I swapped a jdm 7MGTE in my 89 turbo supra this past winter, got it up and running then when we took it to get tuned it started idling crazy and had a bad vacuum leak, we searched around couldnt find it so we pulled the manifold off to check everything put a new I/M gasket on. now were putting it back together and we cannot find where the line that runs from the bottom of the IDLE SPEED CONTROL VALVE either im stupid or were just missing it, ive searched and searched for diagrams and nothing.
    its the line that runs out of the bottom of the ISCV
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Join Date
    May 2010
    Location
    Troy oh
    Posts
    13
    anyone???
  4. #3
    92 1JZ Supra Twin2Turbo's Avatar
    Join Date
    Nov 2007
    Location
    Mill Creek, Wa
    Posts
    2,713
    you cant find where it goes?
    92' High Rpm JZ
    |1JZ|AEM V.2|PTE 7068|Tilton 7.25"|Carrillo H Beams|Diamond Pistons|Shimless Buckets|Goleby Billet Tensioner|BRE FFIM|
    |2% OB Crank|BC272|Technico Gears|Remote EWP|Remote PS|Mechman ALT|Sumped|Meth Injected|Caged|
    Click here to enlarge
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Overlooked bassjunkiens5's Avatar
    Join Date
    Jul 2006
    Location
    Nashville
    Age
    31
    Posts
    4,677
  7. #5
    Moderator SideWinderGX's Avatar
    Join Date
    Mar 2007
    Location
    Syracuse, NY
    Age
    28
    Posts
    4,729
    OP, are you talking about the long black hose running vertical in the picture, past the intake manifold? It's a coolant line...there's only one place it can go where that hose can reach on the intake side of the engine.
    Both of the black 1/4" hoses that go to the ISCV are coolant lines. The giant fat hose is a vacuum line. 17344 in that cygnus link is another vacuum line that is in front of the intake manifold.
  8. #6
    Join Date
    May 2010
    Location
    Troy oh
    Posts
    13
    its not the 17344 one. and yes it is the one that runs vertcal down past the runners of the manifold. i cannot find a diagram or anywhere this goes, i knew it was a coolant line i just cant find where
  9. #7
    Join Date
    Mar 2007
    Location
    Syracuse, NY
    Age
    28
    Posts
    4,729
    Only thing I could find is this link, maybe it'll help, can't find it in cygnus...
    http://www.toyota-supra.info/forums/...e-replace.html
    Really it shouldn't be harder than seeing if there are any open pipes anywhere in that region and smelling for coolant.
  10. #8
    Join Date
    May 2010
    Location
    Troy oh
    Posts
    13
    found it ! thanks for the help guys. hope to have this damn car running this weekend
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
