Originally Posted by
T4-Teg
You need the o2 sensors unless you go full standalone, and have the cars fuel/ign maps set permanatly (tune).
You will need to run atleast 1 o2 sensor. Like you said before, you "can" leave one o2 sensor wire spliced into the other, and run 1 sensor. If your going NA and returning the car to stock, id just do it right and run both o2 sensors, and either run new signal wires if you must, or replace the engine harness with a new uncut one.
Why are you bothering installing the EGR again? You dont need it to pass emissions just make sure the car is fully warmed up, and as long as you have funuctioning cat converter(s) you will pass. The EGR basically does nothing, reguarding how the engine performs, besided putting exhaust gas back into the engine. You would actually have better performance NA if you left the EGR valve removed. Just wire a 10k ohm resistor into the twi EGR wires, and you set, it wont throw a code.
If your running a stock ECU with no piggyback setup, you really need to have your o2 sensors working properly. End of story.
P.S. and no, if your car has no o2 sensors, the engine will not go "boom", it will just run in limp mode, and run like crap. Bad fuel milage, etc...
