Megasquirt: Q&A
+ Reply to Thread
Results 1 to 8 of 8
Thread: Megasquirt: Q&A
  1. #1
    Join Date
    Sep 2009
    Location
    va
    Posts
    5
    Megasquirt: Q&A
    Hi all I have been getting more and more questions about Megasquirt lately. So I am going to create a thread to help everyone out and answer some generic questions.
    My background on this I have been running Megasquirt since 2006. I have a pretty good understanding of it and what it takes to install and run most engines. Right now I currently run Megasquirt 2 v3.57, 2.1.0d Extra code, and EDIS 6 for ignition control. This is installed on my 1990 toyota supra with a 1JZ.
    Go here for you basic questions about Megasquirt that is not specific towards the supra and M/JZ series motors. I'll be going for more a specific questions aimed towards Supras.
    http://www.bgsoflex.com/megasquirt.html
    Guess I can start with some Q&A here
    Q: How hard is Megasquirt to install on XM/JZ motor and is their a PnP version available?
    A: How hard something to install depends on anyone's knowledge and technical expertise. Now I am not going to say anyone can do but with reading and research I believe any person with the right skill set and patients can install it. I started out knowing nothing about MS or standalones when I started and with no one around to help me just the MS forums and manuals. Now www.diyautotune.com builds a DIY PnP MS2 for the 7M engine but it is not Plug and Play you still have to do some soldering and research to get it running.
    Q: Can I use all the stock sensors with the MS2?
    A: Yes and no on this question. You can use all the stock sensors with certain modifications done to the MS2 it self such as to read the 7Ms stock CPS. On the JZ series of motors the MS will not work with the stock ignitor so you have to find another solution for ignition control.
    Q: Can I pay someone to install and tune the MS for me?
    A: Now there is some people that do MS installs but not that many because the MS was originally developed for the do it yourselfer. Typically people who do MS is for people who don't want to spend a whole lot of money or like to do things for themselves.
    Q: How does MS compare to other standalones out there?
    A: Now I can't answer this question completely because I haven't used anything else but MS. For the money you can't beat it but it does have its drawbacks of if you run into issues you may not have anyone local to help you solve your problems.
    This should be good for now If anyone has a question or any helpful information please ask or add to it! I'll add any good questions with answers to the thread that come up.
    IGNITION SECTION:
    Alright here I'll explain prolly the easier ways of doing ignition on the 7m and then on the 1JZ/2JZ.
    Ok the 7m ignition system uses and dual trigger 24-tooth/ 1 tooth trigger setup which is known for causing issues due to brittle wire. Then there is the ignition module which drives the three coils in a wasted spark configuration of cylinders 1-6, 3-4, 2-5. Now it is possible to run the stock 7m ignition system but with some electrical mods done to the MS unit itself which maybe be easy for some and not others.
    Alright one way is to do the mods to the MS ecu and run the stock ignition system which is going to be hard for most people.
    Now the one I recommend is using EDIS-6 from a ford mid 90's V6. Now the MS2 ECUs from Diyautotune.com already come setup for EDIS use. EDIS is very reliable ignition system to use and is pretty easy to get a hold of the components required to install it from most junk yards. It will also fire the stock coil packs and IS300 coil packs. There is some wiring that has to be done to install it. The hardest part of the install is installing the 36-1 trigger wheel and VR sensor on the crank pulley. The nice thing about using a crank trigger is you can get rid of the stock CPS and plug the hole with a freeze plug. Only drawback is controls such as 2-step launch won't work. Things needed for this install is below.
    VR sensor
    EDIS-6 Modules + pigtail
    36-1 trigger wheel mounted to the crank pulley
    Next would be modifying the stock CPS to a 24-1 trigger wheel as linked below. Now what you can do here is using the stock CPS modified to the 24-1 trigger wheel and drive Bosch ignitors or a Mitsubishi v6 ignitors. I haven't done this type of install yet but it is supported by MS2 and from what I heard works well. This wouldn't be a real hard task to do since it will require some wiring to do also.
    I'll do the 1JZ/2JZ section later.
    WIRING SECTION:
    Now you can use the stock wiring harness which I don't recommend. I would use the Megasquirt 12' labeled wiring harness and do a custom harness which looks really nice and isn't hard to do if you can strip and connect wires.
    I'll add more later.
    FUEL SECTION:
    The 7m electronic fuel system is a semi sequential fueling which fires injectors 1-6, 3-4, 2-5 as same as a waste spark setup. MS2 out of the box supports only batch firing which would allow you to fire two banks of injectors instead of three like the stock supra ecu does. Now you may think this is a down grade but really isn't batch firing works just fine its all in the tune.
    Here is a write-up a friend of mine did to modify the stock CPS to a 24-1 missing tooth wheel MS can easily read.
    http://www.saturnwiki.net/index.php/Nippon_Denso_CAS
    1990 Mk3 Supra, 1jz, Megasquirt, Tokico Blues, H&R race springs, and other stuff.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Thanks for sharing!
    '89 NA Auto: Project Cheezgrator
  4. #3
    SupraForums Member MADSUPRA88's Avatar
    Join Date
    Apr 2004
    Location
    Lansing, MI
    Age
    29
    Posts
    4,721
    Would you make me a harness for my 1j
    Click here to enlarge
    Naber Racing
    1994 MKIV 8.78 @ 164 daily summer cruiser
    1991 MK3 2J (1khp in progress)
    1991 C4 Drag Vette (Grudge car)
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    greasemonkey williamb82's Avatar
    Join Date
    Aug 2002
    Location
    spring hill, florida
    Age
    35
    Posts
    3,104
    to add to this, i posted the basic settings and my tables that i currently run on my 7mgte car. they will be similar for a jz engine. good enough to get you running at least. i got online last night from a friends and was able to upload them.
    http://www.supraforums.com/forum/sho...=347502&page=4
    http://www.cardomain.com/ride/2042690/1 black 84 7mgte, ms2, truetrac lsd, bbk, etc... lots more in the works
    http://www.cardomain.com/ride/2117186/1 blue 85 trd header, hks exhaust, custom intake pipe, cone filter,etc... my beater.
    http://www.cardomain.com/ride/2965297/1
    black 86 bought with rod knock. hks tripple weber setup in the works
  7. #5
    SupraForums Member scarface007's Avatar
    Join Date
    Jul 2009
    Location
    Miami,Fl
    Posts
    1,249
    I too am running an MS3 with ms3x card in my 2jz it was done by shadome. Great ecu for the money and the software tuner studio is very user friendly real easy to tune.
    1994 MKIV Supra Ms3 BWs376 Th400 and some juice.
    8.5@164 1.3 60 foot
  8. #6
    SupraForums Member Juhanis's Avatar
    Join Date
    Sep 2003
    Location
    Los Ghettos, California
    Age
    34
    Posts
    2,767
    i run the diypnp on my 2jzge (na-t), and if anyone is looking to run this on their a70 supra i'd run a ms2 or a ms3 not the diypnp.
    Sisu Research & Development, Specializing in Expandable Fuel Injector Sales/Production.
    I'm currently not taking any new orders. I do plan to still build injectors in the future.
    Feel free to pm me if you have any questions.
    stable:
    90 supra, bw s366, 272 cams, srd 1400cc, e85, front/rear bbk, 2jz, megasquirt diypnp
    91 eagle talon tsi, bw s258, forged 6 bolt, built close ratio trans, PTT twin disc, evo brakes
  9. #7
    Driving: 1991 Supra Turbo CheesePhantom's Avatar
    Join Date
    Apr 2010
    Location
    Tampa, FL
    Age
    26
    Posts
    959
    Interesting. I plan on running MS3X on my 7MGTE when the time comes. Here's an E-mail I got from Matt Cramer at DIYAutoTune.com. It may help.
    Hello Alvin,
    Here's the basics of what you'd need to run the engine. The 7MGTE ignition module is a bit of an oddity that the current firmware does not support, so that is a minor complication. This is a list of parts I would recommend.
    - MS3 with MS3X
    - Main board harness and MS3X harness
    - JimStim test board (optional - simulates signals from a running engine so you can test the ECU on a bench)
    - 3 channel Ignition module (or coil on plug coils with built in ignition modules) - I'd probably use an off the shelf Bosch one if you're in Europe
    - USB or serial cable to connect the MS3 to a laptop
    - GM IAT sensor (optional, but it makes removing the vane air flow meter easier)
    - Wideband sensor with controller (optional, but makes tuning a lot easier)
    We had a temporary delay getting some parts in, but a complete MS3 should be ready to ship in just a few days. The kits are ready for immediate shipping. It's likely to take around 8-12 hours to solder a V3.0 kit together if you go that route. The directions can be found on MS3EFI.com in the Documentation section.
    Thanks,
    Matt Cramer
    DIYAutoTune.com
    Click here to enlargeClick here to enlarge
    1991 Toyota Supra 3.0GT - [7MGTE] - MA70 - 60-1 CT26, AEM, Apexi, Blitz, Eibach, HKS, Sportmax, etc.
    1989 Toyota Supra 4.0V8 - [1UZFE] - UZA70 - Quantum-Auto Manual Conversion, R154, Apexi, Tein, Tilton, etc. [Build Thread]
  10. #8
    Join Date
    Sep 2003
    Location
    Age
    34
    Posts
    2,767
    matt is a cool guy. he has helped me a lot with my diypnp. i dont really have a problem with the ems itself, its just nowhere near pnp for the mk3 supra. plus it cant drive the 7mgte low impedance injectors, maybe with certain resistors that's a different story. it also can't work with the 7mgte ignitor, which a lot of the wires on the 7mgte harness are daisy chained together. so, eliminating the wiring for a key engine system and not having it effect the other engine functions/wires/sensors is next to impossible. but it does have a lot of cool features, and its way easier than the ms2 to assemble (i've built both). i really like the ms2 for how cheap it is and how well it works. if you get that with the optional direct coil control (the bosch 373 transistors i think) it can pretty much run off of whatever signal you can get to it. plus it can do just about everything you would want (if you get the proper upgrades). as for the ms3 boards, it looks just like a more advanced ms2, and there's absolutely nothing wrong with that =)
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
