Electronics: Brand new EMS Stinger Standalone ecu
+ Reply to Thread
Results 1 to 5 of 5
Thread: Electronics: Brand new EMS Stinger Standalone ecu
  1. #1
    Join Date
    Apr 2008
    Location
    Miami
    Posts
    36
    I have for sale a brand new ems stinger Standalone.. This computer is in brand new condition
    and has never been used. I only tested it with a laptop to verify everything was good.
    Whats included:
    Ems Stinger 4424 V. 4 Ecu
    Brand new uncut harness
    Serial Cable to connect to your laptop
    Bosch Relay
    Usb to serial cable
    Calibration files for 1jz, 2jz, sr20det, vg30det, rb series motor, v8, this ecu can run almost any motor.
    Everything will be priced at $800.00 obo
    email: gaehring@hotmail.com phone: 786-286-1738 (MAX)
    Key Features
    4 User Definable outputs can programmed as PWM or digital. These can be used for controlling thermo fans, Idle controls, variable cams, fuel pumps, Boost Control, Variable water spray, etc.
    Connects to most sensors. This means that you can use your existing sensors with the Stinger.
    Adjustable RPM and load points. The Stinger 4 offers 40 RPM points with a 1 RPM resolution and 21 load points with a 0.1 percent resolution. This provides a tuning grid of 840 points. Of course you don't have to use this many. You can define any number of RPM and Load positions you require to tune with. This provides non compromised tuning ability. The advanced micro code will perform a 3 dimensional interpolation between all load points.
    Advanced trigger circuitry. Automatically filters trigger inputs for noise ensuring that the trigger signal is always 100% accurate. This combined with the advanced auto signal tracking and true zero crossing detection with magnetic sensors always provides accurate timing at all engine speeds.
    Advanced Micro Code EMS have put great effort in programming their micro code to ensure it stays in exact synchronization with the engine. This minimizes the risk of misfired and lean strokes therefore increasing engine life and providing more power. The system also performs a 3 dimensional interpolation between load points to ensure that your engine is getting what you tuned it to receive
    Manual in pdf format:
    http://www.enginemanagementsystem.co...20Brochure.pdf
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member S14eva1's Avatar
    Join Date
    Sep 2006
    Location
    Majic City
    Posts
    467
    ill vouch for you Max.......good deal
    Click here to enlarge
  4. #3
    Join Date
    May 2010
    Location
    Knoxville, TN
    Posts
    5
    Does a harness have to be made to connect it to mk3 supra with a 1JZ? I'm running the stock 1JZ ecu right now.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Jan 2008
    Location
    Wellsville, MO
    Posts
    149
    Still have this?
  7. #5
    Join Date
    Mar 2009
    Location
    Orlando, Fl
    Posts
    73
    is this sold?
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
