+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 70
Thread: PHR Billet Intake Manifold DYNO RELEASE!
  1. #1
    THIS IS THE OFFICAL RELEASE FOR PREORDER
    I know everyone has been very patiently waiting for this moment to come along with Jonathan and I after all the money spent in R&D, going back to the drawing board, recutting, modifying etc. Its been a lot longer than expected but the project is DONE and has stunned us all with the results! Below the Dyno is done on 17lbs Pump Gas.
    Both power and looks are bar none!
    Pics speak for themselves below:
    PICS OF CNC Without chrome http://www.supraforums.com/forum/sho...d.php?t=585649
    We will have a few options available:
    Manifold Price with Single Rail w/o TB - $3000
    Manifold with Dual Rail w/o TB - $3400
    Throttle Size:
    80mm - $250
    90mm - $300
    95mm - $300
    105mm - $300
    105mm with VBAND - $365
    Price per manifold WILL include throttle Cable, assembled to bolt on and go - In stainless only.
    PREORDERS will be taken with a $1000 NON REFUNDABLE deposit and will take 3 weeks to finish completion.
    Chroming from RB CHROMING will get a special deal if on the Group buy and he will POST the price tomorrow.
    If anyone has ANY questions please PM me.
    PS - There is testing being done AS WE SPEAK against the Veilside (Discontinued) and the Virtual Works for final test comparisons.
    Thanks again for ALL your support,
    Joe
    Powerhouse Racing
    Ph: (817) 238 8434
    Follow us on Facebook www.facebook.com/powerhouseracinginc
  2. #2
    Hardtop FTW! jhepburn's Avatar
    Join Date
    Mar 2010
    Location
    Denver, CO
    Posts
    406
    Very nice, congrats! Do you have any other pics of the manifold?
    _____________________________________________________________________
    1993 Hardtop 6-speed | 3.4L | GTX-4202R | RMR intake manifold | Full-Race twinscroll T4
    T6 FMIC | MoTeC M800 | ID2000's | E85 | Tilton triple carbon | StopTech Trophy BBK | HRE C93's
    1136 RWHP - 923 FT/LBS Dyno Video - 3.4L Build Thread
  3. #3
    In the other thread.
  4. #4
  5. #5
    Moderator
    Join Date
    Jan 2002
    Location
    California, Colorado, Texas
    Age
    32
    Posts
    422
    Beautiful Car
    2005 Dodge Ram 2500 TD
    1995 Lexus Sc300
  6. #6
    Time for change
    Join Date
    Apr 2002
    Location
    Albany, NY
    Age
    31
    Posts
    6,700
    Great work gang! I assume you guys reduced the plenum volume for the increase? It does fall off a bit top end, however, it's literally almost not worth mentioning because there is a significant increase across the board! Plus you did take it to over 8K rpm so, I'd say you made the right choice.
  7. #7
    Join Date
    May 2008
    Location
    Central PA
    Posts
    80
    What brand throttle body is used? Any leaking issues?
  8. #8
    No sir. New design by Wilson.
  9. #9
    sadistic! Supra96-JDM's Avatar
    Join Date
    Apr 2006
    Location
    planet pandora :)
    Age
    29
    Posts
    332
    What turbo is on the car and what are the other supporting mods?
    Would love to see a high boost comparison, if possible. Because that would really show the true potential/capability of your IM..
    1996 Toyota Supra RZ, 6 Speed - JDM
    ETS turbo kit on a built 3.0L engine with CP & Carrillo / AP Engineering PowerFC PRO EMS / HKS 272 Cams / Crower Valve Springs & Retainers / Titan Motorsports Fuel System (with ID1000's) / Boostlogic T6 FMIC / OS-Giken Quad Plate Clutch / ETS 4" Exhaust / HKS Twin Power DLI / Blitz SBC iD-III / Defi Guages x 6 / JDM TRD Guage Clusters / JUN Cam Gears / HKS Hipermax Performer / ATI damper / L19 studs / Top Secret Hood & Rear Diffuser / CCW SP500's ..... etc etc etc...
  10. #10
    This has been done, waiting for the customer to give me the ok to post the dyno sheet. It did make over 1000hp to give you a little insight.
  11. #11
    Fuel
    triple denso hanger with triple denso with 48psi base fuel pressure
    ID2000 fuel injectors
    Engine mannagement
    HKS F CON VPRO
    Turbo
    garrett GTX4202R with 1.28 ar housing
    full race manifold modified with SP spool up valve
    Cams
    GSC S1 cams
    Both degreed the same. little different than cam card specified but degreed by the backpressure.
    Test with hypertune intake manifold 17psi off wastegate
    Test with PHR intake manifold 17psi off wastegate
    Room temp 89.7
    humidity 42,7%
    same day test.
    A/F target was 11.5 across, and timing value were same both runs.
  12. #12
    SupraForums Member
    Join Date
    Oct 2009
    Location
    WV
    Posts
    230
    $3000 for an intake manifold? somebody needs to pass me some of that good stuff that they're on.
    92 sc300, 2jzgte, r154 swap, map ecu 2, master power t70, huge front mount, custom built iintercooler pipes by me, custom 3"-to dual exhaust, work vs-kf 18x9/18x10s.
    http://www.supraforums.com/forum/sho...d.php?t=468279
    before i got it
  13. #13
    Well I just sold a Hypertune Manifold for $2400 + Chrome $250 + Rail $300 + TB $499 = $3499 + you still have to buy a throttle Cable.
    You may not realize what people spend. I will say you can get the VW for $2500 + PS Relocation Kit + Charge pipe for around $3000 too.
  14. #14
    Carbon Fiber Addict SUPRAMN's Avatar
    Join Date
    Nov 2008
    Location
    Knoxville
    Age
    30
    Posts
    573
    The car made 1013 RWHP at 31PSI on C16. We ran out of wastegate spring so we had to stop there.
    I cannot run back to back on high boost as the Hypertune I was using did not have dual rails so it is not compatible with my race fuel independent fuel system, so pump gas is all I can do back to back.
    Also remember this was done on a dynocom dyno which gives a real number not an inflated number like the dyno jet
  15. #15
    SupraForums Member
    Join Date
    Apr 2009
    Location
    PG County
    Posts
    374
    Nevermind........ Just reread the first post.
  16. #16
    (facepalm)
    Note: Please reread first post.
  17. #17
    SupraForums Member galleyhand's Avatar
    Join Date
    Feb 2002
    Location
    Pineville, Louisiana 71360
    Age
    36
    Posts
    1,295
    $3200 for the Hypertune/rail/TB??? Someone OVERPAID big time. You can get them brand new for $350-$620 less than that.
  18. #18
    SupraForums Member
    Join Date
    Apr 2010
    Location
    HOUSTON
    Age
    34
    Posts
    437
    Full race T6 or T4?
    1996 Supra NA-T <Under Construction>
    1997 Supra RSP, 6 SPD, HKS T04Z, AEM v1, AEM 5 bar, AEM WB, 1000cc, Carbonetics LSD, Driveshft shop HD driveshaft, VWR intake manifold, TRD 10k Tach, Exedy triple clutch, HKS fuel rail, HKS EVC 4, 6 piston Stillen breaks, Setrab oil cooler, TEIN flex with controller, HKS Ti, HKS TT, Volk TE-37, etc...
  19. #19
    Blood for Blood RogueSupra's Avatar
    Join Date
    Feb 2006
    Location
    San Diego Cali
    Age
    32
    Posts
    8,051
    Looks great and from the sheet looks like it works great as well... congrats on this... wish I was in the market for a serious intake mani... this looks to be the new king
    MKIV Parts for sale ....
    http://www.supraforums.com/forum/sho...-Greddy-intake
    If you can READ this thank a teacher. If its in ENGLISH thank a VETERAN.
  20. #20
    Member Since 2000...
    Join Date
    Oct 2005
    Location
    Nor-Cal by way of So Cal
    Age
    34
    Posts
    754
    Quote Originally Posted by SUPRAMN View Post
    That is a bummer, I would love to see how they compare dual rail to dual rail on high boost!
    98 Supra TT 6spd original RSP
    HKS TWINS
    Built and tuned by SP Engineering
  21. #21
    Join Date
    Nov 2008
    Location
    Knoxville
    Age
    30
    Posts
    573
    Quote Originally Posted by kloud9r View Post
    full race t6 or t4?
    t4
  22. #22
    Engmaineer kamiraa's Avatar
    Join Date
    Dec 2007
    Location
    Houston / Chicago
    Posts
    2,276
    Quote Originally Posted by JoeatPHR View Post
    Fuel
    Engine mannagement
    HKS F CON VPRO
    Turbo
    Cams
    GSC S1 cams
    Room temp 89.7
    humidity 42,7%
    same day test.
    doesnt that car also have a 3.4 hks stroker?
  23. #23
    Yes sir and a CNC Stage 5 head to match the flow test.
  24. #24
    With all due respect..... 2jzMK3's Avatar
    Join Date
    Aug 2003
    Location
    Orlando
    Posts
    6,365
    12x ind2000cc injectors?
    the picture is a comp turbo, was that the turbo used for the comparison or was the garrett used?
    GT4582R | Motec M820 | Tilton | Weldon | Hypertune
    http://blog.titanmotorsports.com
  25. #25
    Join Date
    Nov 2008
    Location
    Knoxville
    Age
    30
    Posts
    573
    Quote Originally Posted by 2jzMK3 View Post
    I have 2 independent fuel systems. one rail feeds my pump gas and the other rail goes to my race gas tank. It is easier to tune on the map with all injectors being the same size instead of 6 injectors being 1000 and 6 2000.
    Back to back was done with a Garrett GTX 4202R
    Pictures have a comp turbo as that was put on after the dyno as I am doing some testing on that turbo.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
