Help! Alarm Keeps Going off!
+ Reply to Thread
Results 1 to 16 of 16
Thread: Help! Alarm Keeps Going off!
  1. #1
    <O>_<O> chopstickz's Avatar
    Join Date
    Nov 2009
    Location
    Earth
    Posts
    2,152
    I have an aftermarket viper alarm installed on my mk4. This is very annoying, the alarm goes off randomly. It didn't start happening until maybe 3 months ago. I had the Viper alarm installed in there about 2 years ago.
    What is weird is that the actual viper siren isn't going off but instead it is the stock horn sound. I'm not sure what the problem could be. My battery is good.
    Click here to enlarge
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member FLINTSTONESKID's Avatar
    Join Date
    Apr 2005
    Location
    Reading PA
    Age
    38
    Posts
    7,685
    wait, so you said in the first sentence that your alarm is going off randomly. then you say in the end that it is a stock horn. now, are the stock horns included in the vipers system? if not, then i would say that you have something else going on, perhaps electronically. if the viper is going off randomly, depending on which model, they have sensitivity screws that can be adjusted to less sensitive.
    oh, also, was there a stock theft deterant system in your car from toyota and was it uninstalled? think about that one.
  4. #3
    SupraForums Member xpl0sive's Avatar
    Join Date
    Aug 2010
    Location
    Vancouver, BC
    Posts
    562
    this started happening to my car as well. i have a compustar alarm on it. it would go off in the middle of the night just randomly parked in the garage. nothing would touch it... perhaps try turning down the sensitivity on the knock sensor?
  5. #4
    Join Date
    Nov 2009
    Location
    Earth
    Posts
    2,152
    It is not the sensitivity for sure that is a fact. I've had it for so long and never does it go off like that. I think it has to do with the stock security system... I think my viper alarm is wired into the stock system. The red light from the stock security system stays solid when I arm the car using the viper remote.
  6. #5
    SupraForums Member Macleod's Avatar
    Join Date
    Jul 2002
    Location
    Houston,Tx
    Age
    39
    Posts
    210
    I'm not sure what system I have other than stock, but I am having this problem too, however, twice, once 2 months ago, and once yesterday my alarm went off while I was driving. I've had my Supra for almost 7 years now and this has never happened until now. When this happens, I am locked in the car and flipping the door lock does nothing. If I turn the car off it will not start back up. What the hell is going on?
  7. #6
    SupraForums Member rivdog's Avatar
    Join Date
    Dec 2006
    Location
    Va Beach
    Posts
    433
    My alarm was doin this and I have a viper aswell. After doing some trouble shooting I noticed that the hood sensor switch wire was routed through the same compartment that the winshield wiper motor is in. When I did the clutch pedal mod I had to take that panel off so thats when I noticed that the motion of the wiper motor rubbed the insolation on the wire creating it to ground setting the alarm off. It would very from time to time when it went off and it was because the wire was being moved around by the motor. Shitty install....check your wiring and where it routes through. It could be your sensitivity aswell. When it goes off what does it show on your key remote? (that will help you narrow the sensor down if your having a short)
    [IMG]Click here to enlarge[/IMG]
    .....what were we talking about again?
  8. #7
    Join Date
    Nov 2009
    Location
    Earth
    Posts
    2,152
    Unfortunately I don't have a pager alarm, but I will check my hood sensor.
  9. #8
    Join Date
    Aug 2010
    Location
    Vancouver, BC
    Posts
    562
    i think it might be my hood sensor as well. shitty connection maybe... good idea riv!
  10. #9
    SupraForums Member Nazar's Avatar
    Join Date
    Mar 2001
    Location
    Kingston, NH.
    Posts
    557
    Make sure the Disarm wire is hooked up properly at the drivers kick panel. If there is a problem with the disarm wire it will make the Factory alarm go off.
    94 TT 6-Speed HKS2835 Twin Kit
    Past Supras, Too many to list.
  11. #10
    Join Date
    Nov 2009
    Location
    Earth
    Posts
    2,152
    What exactly does the disarm wire connect to?
  12. #11
    SupraForums Member scoobydrivin219's Avatar
    Join Date
    Aug 2004
    Location
    Hubert, NC
    Age
    32
    Posts
    72
    if it's the factory horn, then that is your factory alarm going off. Either something on the aftermarket alarm is triggering it, or its just going bad
  13. #12
    Join Date
    Mar 2001
    Location
    Kingston, NH.
    Posts
    557
    Disarm wire is used to turn off the factory alarm system when you unlock the doors via your aftermarket remote control.
  14. #13
    Join Date
    Nov 2009
    Location
    Earth
    Posts
    2,152
    I realized that my security system light just stays on when I arm the car. It does not flash but stays lit continuously. Is that an indication of anything?
  15. #14
    SupraForums Member kiro1968@yahoo.com's Avatar
    Join Date
    Jul 2009
    Location
    Behindyou
    Posts
    833
    Quote Originally Posted by chopstickz View Post
    yes, means your system is screwed...ahaha, on a serious note refer to TSRM Vol.2 Page: BE-158 about your secruity light. I'm busy this week, if your still having problems with it by next week, look me up and I can come over to help you figure out whats wrong with it. ^_^
    1993 Toyota Supra Black NA 5spd -> TT Engine Swap 5spd
  16. #15
    Join Date
    Nov 2009
    Location
    Earth
    Posts
    2,152
    Please come help me Roy. lol Help me install my W58 too
  17. #16
    Join Date
    Jul 2009
    Location
    Behindyou
    Posts
    833
    lol...thought you done the w58 already? I should be free again starting monday so I can help you out then. PM me when you're free ^_^ and we'll figure something out.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
