Page 1 of 2 1 2 LastLast
Results 1 to 25 of 35
Thread: Unlock my car with key and ALARM sounds... WTH?
    More Like GrayGoose89 bluebullet89's Avatar
    Oct 2008
    Provo, UT/La Grande, OR
    623
    So just recently when i went out to hop in the Soup and go for a drive as i unlocked it the Alarm went off...
    I CAN unlock it from the passenger side and the alarm doesnt sound. it's getting kinda annoying having to unlock the car from the passenger side everytime though.
    Any ideas what the heck is going on?
    I did also notice that the door ajar light does not come one when the doors are open. the ONLY thing i did recently was replace some of the #74 LED's in the gauge cluster and jockey box... but i really dont see how that could affect anything..
    IDEAS???
    *1989 Toyota Supra 1JZ-GTE 5 speed swap
    AEM V2 | 3"Intercooler | Tanabe Hyper Medallion w/testpipe | Walbro 255 | Stock Twins | 15psi | 200amp Alt | 335whp, 350wtq
    2001 Audi A6 4.2 Quattro
    1998 Toyota Camry
    (^_^)
    Mar 2010
    Peoria, Illinois
    82
    Wish I could help ya, but i'm currently suffering from the same problem as well. It is definitely annoying having to walk around to the passenger side then walk back around to get in the car. I have no clue what it could be so I too need some help.
    SupraForums Member Rety1's Avatar
    Jul 2010
    P'burg, NJ
    19
    438
    my 87 is doing the same thing.. it doesnt always NOT sound the alarm when i unlock from the passenger side either..
    i've just been using the aftermarket alarm the previous owner had installed.
    although its a pain when i forget and lock the doors manually then arm the aftermarket alarm, cause it arms both alarms.. (unlocking the car with the key fob with factory alarm armed sets off the factory alarm..)
    *ive almost soiled myself doing that a few times.. lol
    ***i figure it may be something with the lock in the door, because ive tried unlocking with 3 different keys, at "varying unlock speeds" and nothing seems to work..
    '87, turbo, pearl white/burgundy, TEMS replacements, K&N filter, 3" driftmotion turbo-back exhaust, 18" Ruff racing R280 rims *titanium.
    *7/7/10*
  4. #4
    Dec 2004
    Keep staring i might do a trick
    437
    Theres a Plug/Sensor on the back of the lock cylinder they fall off over the years check to make sure yours is still on tight. Mine fell off on the passenger side and when i tried to unlock it from that side the alarm would sound plug the little plug back on all is well.
  5. #5
    Supra Hoarder... RazoE's Avatar
    Aug 2008
    gardena
    27
    957
    bypass the stock alarm box, and get an aftermarket alarm with remote locks..
    problem solved
    1986.5 Targa 5-speed Sportspackage - '91 7MGE
    1989 Targa 5-Speed White package - NA-GTE, BPU'd
    1992 Hardtop 5-Speed - 2JZ-GE
    2005 Scion xB - JDM-ish...
  6. #6
    Dec 2008
    NC
    302
    of all 10 mk3 Supras that i have owned, they all did this. I do what i do each time, I uninstall the factory alarm and if i plan on keeping that particular supra for a while, i will install and aftermarket alarm.
  7. #7
    SupraForums Member barkz's Avatar
    Sep 2010
    New Hampshire
    1,198
    seems like alot of these threads have been started lately, after it started getting cold, could this be a cold weather issue? i might be mistaken but i think between here and "the other" forum, theres been a few ALARM threads. cold....or coincidence?
    88 turbo
    bullet exhaust, HKS intake, MBC 14psi, Fidanza LW flywheel, KYB coilovers, AWESOME RACING STRIPES THAT ADD 1 BAGILLION HP!!!!!
    Pure adrenaline attached to a license plate
  8. #8
    Aug 2010
    chesterfield
    49
    seems mine only does it every once in a while, when i forget to bump it twice in the door, never happens when i do that.....
    89 turbo 5-speed:safc2, lex afm, rc 550s, 57trim ct26, manual boost controller, mhg, arp studs, 3in catless dp
  9. #9
    Oct 2008
    623
    Quote Originally Posted by Rety1 View Post
    I've got the original key and copy an i also tried those different ones. i'm hoping its the sensor/clip on the end of o the lock cylinder. i did search but wasnt able to find the same problem that i have. but thanks everybody.
  10. #10
    Apr 2010
    West Palm Beach, Fl
    6
    to DISARM factory alarm put key in driver side turn to lock position twice then go to passanger side and unlock. think that might have been what you ment by unlocking from passanger side but just to clarify.
  11. #11
    Aug 2009
    kittanning
    25
    214
    had the same problem with my 89 supra it was a short in the wireing you can try by hoocking a new ground that worked for me
    89 supra targa top, turbo, 5speed 7mgte (rolling project)
    90 supra targa top,turbo, tranny??? what tranny??? and motor what motor???? lol (life project)
  12. #12
    Aug 2009
    kittanning
    25
    214
    or just get rid of it for a better aftermarket one with remote
  13. #13
    SupraForums Member TweeT91109's Avatar
    Sep 2009
    Tampa, FL
    21
    634
    Both of the MK3's I had owned both had the horns removed. So I'm guessing they once had the same problem.
    1986 Toyota Supra Hardtop NA (Maroon) PART OUT http://www.supraforums.com/forum/sho...d.php?t=617292
    1989 Toyota Supra Pearl White Targa CT-26 Current Project
  14. #14
    LAGZILLA rustywhite7mgte's Avatar
    Jan 2005
    NEW YORK
    25
    733
    jdm rhd alarm.
    93 jza8042R
    92 jza70ttR
    Black Power..
  15. #15
    Oct 2008
    623
    UPDATE
    K well after over a YEAR of unlocking the passenger-side I found an 87 in a junkyard and took the plug/switch from the back of the lock mechanism and it looked like it was in really good shape.
    I pulled the one from my car (bad) and noticed that the Right wire (Green-Blue) was broken off the plug. Good news right? Well Replaced it with the newer one, made sure that the switch would turn with the key. It did but the alarm still goes off. I did notice if i lock the door from the driver side with the key from outside the car. the Alarm light will not come on but it does lock. Below are a couple pics of the plugs.
    BAD PLUG
    NEWER PLUG
    INSTALLED
    I JUST noticed, i think the newer plug only has two wires going to the plug, so not sure if thats my problem as to why it STILL doesnt work.
    Side-note I got the plug for free so i wanted to try and get it just working like normal before buying an aftermarket. If i must, I'll end up getting an aftermarket with remote lock. (Any suggestions for a decent one that wont cost me a wallet full?)
  16. #16
    Badder.Faster.Louder. Zumtizzle's Avatar
    May 2006
    NorCal
    4,571
    Autopage.
    Clifford.
    Viper.
    You can use an aftermarket alarm with the factory alarm with no issues.
    Welcome to my nightmare!
  17. #17
  18. #18
    Oct 2008
    623
    thanks Zum
  19. #19
    Supra Tech Bmettie's Avatar
    Mar 2010
    Florida Brevard
    31
    1,318
    Another option is to get an aftermarket keyless entry and wire it to the lock/unlock and arm/disarm circuits. I got a kit for $10 new and the factory alarm works great. I never had a problem with the key switches before the install but I'll never have to worry about them again because when I lock the doors with the keyless it arms the factory alarm and disarms at unlock. You'll have to isolate the unlock and disarm circuits on the car side so you can't disarm the alarm by reaching in and hitting the button on the door. And I wired a keyless hatch popper with a 12v solenoid to the same keyless module
    91 White Package Targa Turbo
  20. #20
    Moderator/Troll Slayer SupraTrey's Avatar
    Mar 2002
    Midwest
    34
    6,044
    Mine did that as well..... so I shaved the lock off on my last paint job. Problem solved.
  21. #21
    wish my lawn was emo bsmk3's Avatar
    Jun 2010
    indian head, MD
    150
    I had the same problem with my 89... the key was worn so i had a new one made and it stopped...
    build thread
    7mgte swap/3" custom down pipe/3" exhaust/HKS MHG/ARP head studs/ 3" intake pipe/K&N air filter/BLITZ BOV/ACT 6 puck UNsprung race clutch & pressure plate/3" drop springs/KYB struts/SS braided brake lines/cusco strut supports/custom short shifter/corbeau racinging seat/4 point racing harnesses/custom steering wheel/greddy profec A boost controller/A'pexi SAFC-2/MK4 16/9.5
  22. #22
    Oct 2008
    623
    Quote Originally Posted by Bmettie View Post
    You got a keyless entry for just $10? Cause I was looking at auto page 2-way aftermarket alarm of course with keyless and other features but that's 130. Should I just get a cheap keyless entry and spend the extra 180 on other parts?
  23. #23
    TheFastCoonAss Rajunz's Avatar
    Austin, Texas, USA
    6,271
    When my alarm did that, I just stuck the key in the ignition, turned it on and off awhile the alarm was blairing, and it reset everything. Never happened again.
  24. #24
    SupraForums Member kneedragger85's Avatar
    Dec 2008
    Boulder, CO
    811
    I'm guessing the OP reset his alarm by locking/unlocking the passenger door to no avail either?
    89 Supra: JDM 2JZ-GTE/R-154 on stock twins...SP63 & E85 over summer
    91 Cressida: VVT-i 1JZ-GTE/R-154 on stock single
    98 YZF-600R: My only 4-banger
  25. #25
    Oct 2008
    623
    Quote Originally Posted by kneedragger85 View Post
    Well After i set off the alarm, put key in ignition, wont start of course cause of Start kill, BUT if i go to the OUTSIDE of the driverside, lock and then unlock it resets. As of right now. If I lock/unlock from the outside driver using key, it will lock and unlock WITHOUT setting off alarm but it wont SET the alarm. from inside i lock using door button and try and unlock with key outside, and alarm sounds. if i'm not mistaken there is kind of a way to more FULLY reset the alarm or is that not true?
