+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 34
Thread: It's Back!! SP Built A340E Toyota Transmission w/ UPGRADED 2nd Gear Sprag
  1. #1
    Was 9sec STOCK motor 6spd Reid@SP's Avatar
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    SP Re-Released Built Auto A340E Transmission
    This is the transmission that started it all!! Originally found in SP01 and Marko's infamous white Supra, the Built Toyota Transmission was the pioneer for drag racing and street cars in the early Supra years. Due to the number of inquiries we have received regarding this product, the Original Built Auto Toyota Trans is now Officially Re-Released!!!
    The single reason that we have decided to bring back the Toyota-based transmission is our new UPGRADED 2nd Gear Sprag (which is the well known weak point of the factory trans).
    Transmission Specs:
    • Replace low, intermediate, and overdrive sprags regardless of condition or mileage
    • Custom-made UPGRADED 2nd gear sprag (known to be the culprit for ALL Toyo trannies) with high-energy friction material
    • Upgraded Billet Aluminum 6061 Forward Apply Piston
    • Alto clutches, koleen steels, additional clutches added over stock number of clutches
    • New upgraded Lexus pump
    • Deep Lexus pan for added capacity
    • Modified valve body and trans case including machining for O-rings (instead of using the paper gasket which has been known to fail under higher pressure)
    • Tranny is 100% disassembled, every part inspected and measured
    • Valve body modified for line pressure changes
    • Bushing kit replacing ALL bushings
    • File a small angle on the pump body crescent
    • New Hi-flow filter
    • Buff drums
    • Upgrade spacer plate and accumulator springs with custom replacements
    • Flush and check all solenoids
    • Reassemble and pressure check engagement of every gear
    Trans Cooler:
    An upgraded trans cooler is HIGHLY recommended but not included. There are too many variables depending on where the user wants to install the cooler and the space available. I will likely determine a stock location upgraded but for the time being, a cooler will be left up to the customer to determine. We can supply any specific trans cooler requested.
    Torque Converter:
    No Torque Converter is included with the transmission, the price includes the trans uprade only. We offer our SP Converter which is specifically designed and built for the Supra Turbo. Your SP Converter is custom built and tailored for your particular setup based on your goals and modifications. Even if you do not purchase our Torque Converter with your SP Auto Trans, it is highly recommended that you replace/rebuild your converter to prevent premature failure.
    Pricing:
    • SP Built Auto A340E/A341E Transmission $3399
    • SP Torque Converter (built to customer application specs) $999
    • Package Price inc. SP Transmission & SP Converter $4299
    Note: We HIGHLY recommend using an engine management system that can monitor and control trans line pressure such as the ProEFI or AEM v2. Systems such as the AEM v1, Motec, and Haltech just to name a few, do NOT have the ability to control this transmission properly.
    This is not just an upgrade. It is an upgrade and a complete rebuild to new specs. Taking orders now!!
    Reid
  2. #2
    spracingonline.com DentGuy's Avatar
    Join Date
    Aug 2008
    Location
    Building an engine that someone else will take credit for
    Age
    31
    Posts
    2,146
    That's funny Reid, we were just talking about auto transmissions today
    Bob W.
    ProEFI GT4276 1174whp 932tq @39psi
  3. #3
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    Quote Originally Posted by PDRguy06 View Post
    I thought about you when I was putting this together Bob. Larry has been working with our trans builder regarding the upgraded 2nd gear sprag. This is the single part that truly sets this apart from the rest. The stock sprag is what ALWAYS breaks regardless of whatever slight tweaks or modifications are made to them. Now Vanessa has a cost effective trans option!!
    Reid
  4. #4
    Super Moderator
    Piss me off. I dare you.
    FYRARMS's Avatar
    Join Date
    Jul 2001
    Location
    In your nightmares.
    Posts
    18,738
    Mmmmmm... Beefy SP trans, 3600 stall, and a PT6265 w/QSV would make one bad-assed and durable street combo!
    2003 Z06: AFR heads, FAST90, Comp Cams, Borla headers/exhaust, RPS twin clutch
    Miatas: #1 choice of fags worldwide.
  5. #5
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    Quote Originally Posted by FYRARMS View Post
    That's pretty damn close to what Vanessa will be doing! Hot chicks and hot cars
    Reid
  6. #6
    Junior Member
    Join Date
    Oct 2010
    Location
    Cincinnati, Ohio
    Posts
    142
    this is great i was just searching the whole forums yesterday for info on a340e
    is it cool if i slap this in my mk3?
  7. #7
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    Slap it in a Hyundai if you like!
  8. #8
    SupraForums Member
    Join Date
    Oct 2006
    Location
    cali
    Age
    33
    Posts
    1,183
    very nice
  9. #9
    Join Date
    Aug 2008
    Location
    Age
    31
    Posts
    2,146
    Is the price you list for the transmission an upgrade price? or do you receive a whole new trans
  10. #10
    SupraForums Member turbomike76's Avatar
    Join Date
    Sep 2007
    Location
    louisiana
    Posts
    1,477
    Foward facing piston??
  11. #11
    www.spracingonline.com Sound Performance's Avatar
    Join Date
    Feb 2001
    Location
    Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
    Age
    47
    Posts
    10,890
    Quote Originally Posted by turbomike76 View Post
    Yes, it has the upgraded forward apply piston too!!
    Sound Performance
    630-893-5002
    DO NOT PM ME!!!
    Email - XXSUPRAXX@AOL.COM
    Instant Messenger - XXSUPRAXX
    Text or Cell Phone - (630) 205-6690
  12. #12
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    Either a core is supplied or there is a core charge.
    Reid
  13. #13
    Join Date
    Aug 2008
    Location
    Age
    31
    Posts
    2,146
    Quote Originally Posted by Reid@SP View Post
    Reid
    Careful lol
  14. #14
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    Quote Originally Posted by pdrguy06 View Post
    careful lol
  15. #15
    Na Zdrowie DakaDan's Avatar
    Join Date
    Feb 2001
    Location
    Chicagoland, 60457
    Age
    32
    Posts
    1,077
    What brand is your convertor? Who builds it?
    1995 Supra Turbo- SOLD
    67GT40, 264/272, SP 4" Midpipe & Downpipe, HKS Ti Exhaust, AEM tuned by Larry @ Sound Performance, SP Built Trans with 4k TC, etc etc...
    2002 Dodge Ram Quad Cab 4x4
    Stock....
  16. #16
    SupraForums Member
    Join Date
    Sep 2009
    Location
    my world
    Age
    27
    Posts
    625
    nice! was any test done on the strip with this setup? and why alto clutches and not blue kevlar ones?
    and.. by what you've done this auto should be indestructible in my hands? ;p
  17. #17
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    Quote Originally Posted by DakaDan View Post
    We have our own converter builder. He specializes in turbo vehicles and has done so for many high HP cars including a number of V8 turbos.
    Quote Originally Posted by SUPRASSS View Post
    Larry will have to comment on this one for you. Nothing is indestructable though! We redesigned the transmission to be absolutely as strong as possible.
    Reid
  18. #18
    Sold the RSP :( J. Cooper's Avatar
    Join Date
    Apr 2008
    Location
    29 Palms, CA
    Posts
    1,674
    Reid,
    Whats the core charge looking like? Also waiting for some test results...
    Thanks,
    Jeremy
    - Jeremy
    On the hunt...
  19. #19
    Join Date
    May 2006
    Location
    Dekalb, IL
    Age
    24
    Posts
    6,328
    Quote Originally Posted by J. Cooper View Post
    Reid,
    Thanks,
    Jeremy
    Jeremy, the core charge is $1000 if one is not provided.
    Reid
  20. #20
    Join Date
    Apr 2008
    Location
    29 Palms, CA
    Posts
    1,674
    Holy crap man. Ok, i'll definitely have to send one of my cores in.
    When should we be expecting some results to come out and further clarification on other members' questions above?
  21. #21
    SupraForums Member YeA 2jZ's Avatar
    Join Date
    Sep 2008
    Location
    SC Land, FL
    Posts
    651
    what kinda hp numbers can this hold ? Is this also for the regular GE auto ?
    2JZ-NA going T
  22. #22
    Join Date
    Apr 2008
    Location
    29 Palms, CA
    Posts
    1,674
    Whats the turnaround time on this once you have the core?
    2 day edit: Reid! You alive man? lol...
    Jeremy
  23. #23
    SupraForums Member AXA's Avatar
    Join Date
    Feb 2002
    Location
    Miami Fl./Dominican Republic
    Age
    35
    Posts
    607
    Reid how much WHP you think the new tranny will hold with the new updates and upgrades?
    If you don't know maybe a whp guest estimate will be fine.... Maybe you haven't tested to it limits yet...
    Jose Savinon.
    Supra Twin Turbo.
  24. #24
    SupraForums Member XSFSPD's Avatar
    Join Date
    Feb 2001
    Location
    Utah
    Age
    35
    Posts
    380
    Another question is this trans ability to hold power vs a 4L80E built by you guys or Rossler with a stand alone trans controller. Just thinking outside the box with all my auto trans issues I have had. I hve a built auto now (yes a competitor) but it seems to be holding my power fine but does not shift worth a carp but I think that is due to the AEM v2. Hope to be headed your guys way sometime this year for a ProEfi/Flexfuel system and better trans control. Still considering a 4L80E and not worrying about the trans again through.
    Thanks!
    '97 Supra Sound Performance Billet 6765 / Titan S2 Trans w/Titan 4000
    705whp@28psi E85
  25. #25
    Ticketing Ricers Evrywhre SaleenKiller's Avatar
    Join Date
    Sep 2004
    Location
    Box On The Corner Under The Bridge
    Posts
    1,466
    This is awesome, Reid. With all the clean auto's popping up lately, this is def a bright light for those that have them.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
