Im changing my water pump tomorrow. Wanted to check out on how to properally burp or bleed the coolant lines for these cars. Searched this forum, couldnt find a guide on here so I thought I would share this one. Also shows you how to check/replace thermostat. Lots of photos.
http://mkiiisupra.net/bbs/showthread.php?t=13619&highlight=guide+coolant
Water pump components: http://www.cygnusx1.net/Supra/Library/TSRM/MK2/manual.aspx?S=CO&P=3
key words: Coolant replacement, bleed coolant, burp coolant, Change coolant, how to clean radiator, how to clean rad, how to drain rad, how to flush rad, how to flush radiator, flush coolant, thermostat, stat, how to replace thermostat, how to test thermostat, how to check thermostat, how to test thermostat at home, bubbling noise, bubble sound behind firewall, bubble sound, bubble sound while running, engine block coolant drain plug location, block coolant drain location, coolant drain plug locations, heater matrix, coolant drain plug photo, coolant drain plug pic, how to change coolant, how to bleed coolant, water pump components, water pump, how to replace water pump, water pump parts
