Best Oil for 2JZ-GTE
+ Reply to Thread
Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
Results 1 to 25 of 208
Thread: Best Oil for 2JZ-GTE
  1. #1
    Junior Member
    Join Date
    Jan 2011
    Location
    California
    Posts
    116
    I'm about to change the oil on my supra, and I was wondering what oil you guys use? Or what you guys think is the best. Also what oil filters do you guys use or reccomend? My supra engine is all OEM so far. Any thoughts or suggestions would be appreciated.
    Thanks, SC FAMILY
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Time for change
    Join Date
    Apr 2002
    Location
    Albany, NY
    Age
    35
    Posts
    6,868
    After this comment I encourage people not to post.
    OP, please search there are about 30 posts on this subject.
  4. #3
    SupraForums Member
    Join Date
    Sep 2010
    Location
    somerset ,ma
    Posts
    1,988
    I dont blame him for posting this...
    I went through the same dillema when I bought mine at first.
    Yes there is ALOT of information out there on this, but alot of it is unclear. People are running alot of different weights and brands depending on mods. Some are using heavy oils, or Rotella.
    to the OP, id suggest a high end synthetic such as amsoil in 10w-30. In stock form, and normal climate conditions theres no need to run anything but what toyota reccomends ( which should be right on a sticker next to your oil cap )
    1993.5 Ren Red TT 6spd targa
    PTE6766 on RPS manifold , AEM V1, Tuned by Alex @ GSD
    Click here to enlarge
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member
    Join Date
    Dec 2009
    Location
    fresno, ca
    Posts
    2,050
    Quote Originally Posted by Tim1137 View Post
    mobile one extended performance from wal-mart. i think thats good enough, your not taking the car to the race track every day, so you don't need to spend $100 dollars on oil. for filter i just use the supreme fram filter and thats it.
  7. #5
    SupraForums Member Kracin's Avatar
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    Quote Originally Posted by choua01 View Post
    both of you should do as much searching as the OP. times have changed DRASTICALLY since toyota recommended using a standard oil in the car and at that weight.
    the difference between using a thicker oil and thinner oil depends on the climate your car is driven is most as well as oil clearances with the bearings. theres a lot more to it than "i think thats good enough" that you should both (and op) read up on that is discussed in multiple threads.
    what is the right oil for one car, could be the wrong oil for the same car in a different location that is used completely different.
    also, choua01, just because you think spending 35 bucks on oil (5 quarts of 7 dollar quarts) is not great, no idea where you got 100 from. but whatever... you can think about the fact that using a good synthetic, like amsoil, german castrol, or any of the others mentioned that have been discussed about, will save you lots of money in the long run through doing less oil changes and buying less regular oil. not to mention a synthetic will not break down like a regular oil, which is far better for a car that doesnt see very many miles either. its worse for the car to drive it seldom, than to drive it often.
    if you want a standard answer. then go ahead and use the oil that toyota recommends, but remember, that recommendation came from a standard that is no longer the same. and there are better choices you can educate yourself about.
    Click here to enlargeClick here to enlarge
  8. #6
    Junior Member
    Join Date
    Jan 2011
    Location
    California
    Posts
    116
    Alright cool cool, thanks for suggestions. So I'll just go find a nice 10-30 and a fram. Thanks, SC FAMILY
  9. #7
    Time for change
    Join Date
    Apr 2002
    Location
    Albany, NY
    Age
    35
    Posts
    6,868
    Making another thread, makes it more clear every time...
  10. #8
    SupraForums Member
    Join Date
    Dec 2009
    Location
    fresno, ca
    Posts
    2,050
    i've done plenty of search in here on oil and it's confusing,... you have people suggesting go to wal-mart and you have people recommending royal purple, amsoil.. and on. your right about time has change since the recommended oil was given to this cars.
  11. #9
    SupraForums Member
    Join Date
    May 2008
    Location
    Texas
    Posts
    1,857
    I personally use Royal Purple 5W-30 or 10w-30 and Purator Pure One Oil Filters I pay about $60 per oil change but to me its worth it.
    Good luck and you will be safe like everyone posted above with a good quality Synthetic Oil as far as Brand its up to you.
  12. #10
    Junior Member
    Join Date
    Jan 2011
    Location
    California
    Posts
    116
    Alright I just got back from kragens. I decided on royal purp 10-30 and some random k&n filter
  13. #11
    SupraForums Member KooK's Avatar
    Join Date
    Feb 2003
    Location
    Des Moines, IA
    Age
    32
    Posts
    170
    Personal Choice: Royal Purple
    Good Choices: Mobil 1, Amsoil, Valvoline synthetic just to name a few.
    Your cheapest and easiest bet will probably be Mobil1 at Walmart.
    Your more expensive and semi-difficult to find choice is Royal Purple (standard 5w30 and 10w30) at most auto stores.
    Your most expensive and hardest to get choices are Royal Purple (racing), and Amsoil typically; at least around here.
    "That the automobile has practically reached the limit of its development is suggested by the fact that during the past year no improvements of a radical nature have been introduced."
    (Scientific American January 2, 1909).
  14. #12
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Orange County, California
    Age
    26
    Posts
    2,145
    Unless you plan on tracking your car i.e. generating a lot of high heat for prolonged periods of time I don't see any reason to go with royal purple or amsoil unless you like throwing money down the drain.
    NA cars = Mobil 1
    Turbo cars = Mobil 1 synthetic
    @ wal-mart
    xxxx-xxxd3 oil filter @ the dealership.
  15. #13
    Registered User
    Join Date
    Mar 2009
    Location
    Ft. Worth, TX 76148
    Posts
    285
    From My expierence Mobile 1=CRAP! Even their 10w40 is super thin when at operating temp. Keep in mind it gets HOT in Texas! I have used Rotella T6 5w40 with much success! It's also one of the cheapest synthetics at about $20 per gal at wallmart!
  16. #14
    SupraForums Member nazbr7's Avatar
    Join Date
    Aug 2007
    Location
    IL
    Posts
    1,273
    I plan on running 10w30 amsoil and toyota filter. I haven't heard anything bad about amsoil or the toyota filter.
    1994 Red 6spd Supra Turbo
    1998 Quicksilver 6spd Supra turbo
    Click here to enlarge Originally Posted by grandporschegt Click here to enlarge
    clearly your teacher has never run 35 psi on 2.75 a gallon gas.
  17. #15
    SupraForums Member xnofear6988x's Avatar
    Join Date
    May 2009
    Location
    Buffalo
    Posts
    332
    I couldnt see oil being a big issue especially on an oem car. Mobile one is good enough and all anyone should ever need unless maybe you're really into high performance racing. Im at bpu and mobile one is all i ever use along with a decent filter (don't use fram).
  18. #16
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Age
    26
    Posts
    2,145
    Quote Originally Posted by poboy69 View Post
    you want to use the thinnest oil possible.
  19. #17
    The "Tactileneck"
    Join Date
    Dec 2008
    Location
    OK
    Posts
    1,168
    Quote Originally Posted by Ryeno View Post
    But, to add something usefull to this thread, here you go OP: There are people on here that swear by Mobil 1, there are people on here that swear by Valvoline Race, there are people on there that swear by Rotella 15-40, Amsoil, Brad Penn, Royal Purple, and on and on and on.
    Personally, I prefer Royal Purple. It has great ratings as far as flash points, additives, and such go, and if you go to the Toyota dealership there's Toyota oil, and then Royal Purple sitting right next to it.
  20. #18
    SupraForums Member
    Join Date
    Sep 2009
    Location
    my world
    Age
    30
    Posts
    714
    i use syneco 20w50.its 120 dollars.but im going back to their 10w30 because i dont race my car anymore and i like doing more frequent oil changes
  21. #19
    SupraForums Member
    Join Date
    Jun 2007
    Location
    Panama City, FL
    Age
    34
    Posts
    1,088
    I would definitely not use a fram filter. OEM filter end of story!!
    1995 6spd 6766 tuned & built by DoubleDTuning *SOLD*
    1993.5 TT 6spd WB Hard Top *SOLD*
    The Moment of Greatness Is Not the Action.
    It's the Decision That Allows the Action to Occur.
  22. #20
    SupraForums Member
    Join Date
    Jun 2007
    Location
    Panama City, FL
    Age
    34
    Posts
    1,088
    $120 for an oil change??? Jesus does that include the hooker??
  23. #21
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Age
    26
    Posts
    2,145
    Quote Originally Posted by Adr3naline View Post
    snip
    Explain yourself? The thinner the oil the more viscous it is, the easier it can flow and easier it can get into all the little nooks and crannies. So you want to use the thinnest oil that keeps your oil pressure in spec.
  24. #22
    BLACKOUT
    Join Date
    May 2004
    Location
    NOO YORK
    Age
    38
    Posts
    1,846
    I personally use amsoil with either purolater or toyota filter .....
  25. #23
    The "Tactileneck"
    Join Date
    Dec 2008
    Location
    OK
    Posts
    1,168
    Explain yourself?
    Sure. You're pretty much 100% wrong. The "thicker" an oil is the better it will handle high stress loads and heat. Also, your first post, and then this post:
    Are two completely different things to say, even though ^^^^^ this is like I said pretty much entirely incorrect.
  26. #24
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    actually you are both wrong lol. there is a reason you dont just throw 20w-50 in a track car and call it a day.
    its been explained more than couple times.
    and ryeno, i would love to hear your take on oils too
    make sure to draw some diagrams or take pictures while your at it, they help make the whole experience more enjoyable
  27. #25
    SupraForums Member
    Join Date
    Aug 2009
    Location
    Colorado
    Posts
    208
    love the oil debates....
    AMSOIL 10/30 and J series toyota filter for my big single
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. 1JZ-GTE & 2JZ-GTE Oil Pan The Same?
    By 1JZ_Cressida in forum 1JZ/2JZ Swap
    Last Post: 04-14-2011, 07:22 PM
  2. Curt need price on a 2jz-gte short block, oil cooler, oil pump
    By SupTek in forum Part Ordering Information
    Last Post: 06-20-2007, 09:46 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
