t56 tranny swap
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 49
Thread: t56 tranny swap
  1. #1
    Join Date
    Feb 2009
    Location
    mentor,oh
    Posts
    60
    t56 tranny swap
    I posted this in the southwestern regional part as well. As are trannies are getting more expensive and harder to come by a company called arizona performane is looking for a donor mkiv 6speed to mok-up a T-56 conversion kit for us. They can be reached at arizonaperformance@cox.net
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    HardTopper Matty95'Coupe's Avatar
    Join Date
    May 2010
    Location
    CT
    Age
    37
    Posts
    464
    Cool idea, V160 can handle a shitload more power though...
  4. #3
    SupraForums Member
    Join Date
    Apr 2010
    Location
    Arkansas , us
    Posts
    185
    True, but for about half the price you can halve a six speed.. the only thing catchy is that will the conversion be worth it?
    Click here to enlarge 24lbs of boost and decreasing >:)
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    May 2010
    Location
    CT
    Age
    37
    Posts
    464
    Hopefully this will come to fruition and we'll see! I'm deff curious, I already have a V160, but still interested, just not enough to "donate" it haha...
  7. #5
    Super Moderator Wreckless's Avatar
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,069
    A T56 swap is pointless unless you can match (preferably undercut) the cost of an R154 5-spd swap. The R154 can be done with a couple simple mods and otherwise all Toyota OEM parts. It also uses an external slave cylinder not a POS internal slave cylinder like the LS1 T56's.
    But I'll be sticking to my 7-second proven Getrag V160
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
    Click here to enlarge Originally Posted by KING Click here to enlarge
    Who would have ever thought.....the impact an automobile can make.....
  8. #6
    SupraForums Member 11C20's Avatar
    Join Date
    Apr 2009
    Location
    Moco, MD
    Posts
    1,783
    ^^^^ I was just about to ask how strong the T56's are compared to the Getrag and how much if any better than the R154.
    “The difference between drug dealers and whores: whores sell the same crack over and over again.” Charlie Sheen
  9. #7
    Join Date
    May 2010
    Location
    CT
    Age
    37
    Posts
    464
    Good point Wreckless! I'd rather have an R154 than a T56 too... Likewise the R154 can handle more power than a T56 too. I never knew they had an internal slave that sucks... LS1 guys complain about the forks sucking too I guess they bend with an upgraded clutch. Also they snap tailshafts in the 450-500hp range, granted they have more torque than an equal HP supra but shit... Age old saying "you get what you pay for" and I'd pay for another V160 if I had to do it again.
  10. #8
    Join Date
    Feb 2009
    Location
    mentor,oh
    Posts
    60
    The whole point of this is to replace the getrag. The v160 can handle alot of power its been proven time and time again, but no matter how strong they are they still wear out. My v160 has 100,000 miles on it with a completely stock car and the tranny grinds shifting from 2nd into thrd. The cost for these transmission keep getting higher and higher. Summit racing sells a T-56 that can handle 700ftlbs of trq for $2700 and they can be rebuilt by just about anyone for $500.
  11. #9
    SupraForums Member Hurrakaine's Avatar
    Join Date
    Oct 2002
    Location
    Philly burbs
    Age
    33
    Posts
    6,143
    ^ for the price of that, you could have 7 R154's that can handle the same power.
    1997 RSP/Black Bpu 6 speed
    1997 Black Auto TT BPU #1
    2008 Lexus IS-F
  12. #10
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    9,069
    Quote Originally Posted by jafo101 View Post
    *REPLACE* a Getrag?!?!? Are you high?
    Why not get your Getrag rebuilt for less than that T56, and have a 7 second proven buttery smooth awesome 6-spd for the next 100k miles?
    So you'd spend $2700 on a trans, a fuckload of time/money on a custom driveshaft, flywheel, clutch & clutch fork/release setup, custom bellhousing, slave cylinder setup (hope it's an external one!) crossmember, etc etc it goes on. Then you've got a double overdrive 6-spd that'll get along with the V160's 3.133:1 rear end ratio about as well as Tabasco sauce & vaginas do.
    So now you've gotta go down to the smaller 200mm ring gear TT auto/NA diff pattern to get a final drive ratio that's worth a shit with a T56. Granted, you could sell the grindy Getrag, 6-spd driveshaft, clutch, and diff.
    So
    $2k going rate for grindy getrag
    $400 for DS
    $1k for diff
    $500-1000 for your clutch depending.
    So you've got 4K in your pocket. So you buy that T56 from Summit and you've got $1300. Then you need a custom bellhousing to make the T56 bolt to a 2JZGTE. Say you go the cheap route and do a simple plate conversion for $500 or so. Then you get a clutch *and* flywheel set up for real power to suit your wacky custom combo that's all 100% custom, which isn't going to be cheap and we both know it. Call it $1k and that's being REAL conservative.
    Now we're $200 in the red. Then you need a custom driveshaft to suit, also not cheap for strong stuff but we'll call it cheap at $500. Then you need to go buy a TT auto or NA rear diff with a decent LSD, be real generous and say it's $1k. Now we're $1700 in the red and we're not even counting all the cussing and fucking around that goes with making an engine, trans, & clutch all get along when they were never meant to.
    At which point you've got a Getrag's rebuild's worth of money into an inferior driveline and a fuckload of back-and-forth making it work and machine shop costs and all the other shit involved.
    If you've got all that stuff and can fabricate all that stuff, good for you. Use it to do work to buy the right stuff to keep your Supra at it's best, most valuable, and (most importantly) most enjoyable to drive.
    Because even if you can break even money-wise to have a T56 into your Supra, your Supra just took a 5k hit in market value.
    The T56 might be a worthwhile conversion to someone going from W58 or R154.
    But a T56 replacing the Getrag is fucking stupid. Always has been, always will be. End of story.
  13. #11
    Join Date
    Feb 2009
    Location
    mentor,oh
    Posts
    60
    Your absolutely right It would take alot of effort fitting a T-56 tranny. But options are getting fewer and fewer. 5 years ago did you think a v160 would sell for 7 grand? what about 4 dollars for a gallon of gas? My point is in another 5 years these trannies arent going to be around. I could have mine rebuilt for about $3500 but when doing a search, alot of people arent happy with the rebuilds. So then you look for used ones but you never know what kind of condition there in. Right now this shop is looking for a donor car to try to figure this out. In the end if it doesnt work out, at least we tried.
  14. #12
    Join Date
    May 2010
    Location
    CT
    Age
    37
    Posts
    464
    ^^ Wreckless FTW lol... OP I have a fully swapped NA, I put the V160 in after I had fun breaking my W58 in half... Listening to all arguments even if your theoretical swap was available I still wouldn't go back and change that, my 2nd-3rd grinds too (bad 3rd gear syncro) getting it rebuilt for about 800$ fOr now double clutch works very well most people can't even tell I'm doing it
  15. #13
    SupraForums Member ophidicus's Avatar
    Join Date
    Apr 2008
    Location
    Massachusetts
    Posts
    955
    If your going with Tremec at least go with a TKO600 they are way stronger than a T56 and can hold 600 Trq all day long but I digress as an R154 would be way easier to swap in and makes way more sense.
    1995 Single Turbo 6 Speed Hardtop
    Turbonetics Hurricane 7268 / HKS 272 / RC 1000cc / Haltech PS2000
    Click here to enlarge Click here to enlarge
  16. #14
    Twin Meister
    Moderator
    KenHenderson's Avatar
    Join Date
    Feb 2002
    Location
    SoCali
    Posts
    9,879
    Quote Originally Posted by Wreckless View Post
    So
    $400 for DS
    $1k for diff
    Post of the year!
    That's my boy, Jeff. Schooling SF one member at a time...
    Ken.
    "Replacing the V160"...WTF?
    www.sp-power.com
    HKS 3.4L: 1110 all-boost whp/839 lb-ft @ 2.6KG/CM^2
    1994 "SP ENGINEERING" TWIN HKS GT3240 TOYOTA SUPRA TURBO
    1985 Toyota Celica Supra P-Type 5MT
    1991 Toyota Supra Turbo Hardtop/Sunroof 5MT (BPU)
    1993.5 Toyota Supra Turbo Hard Top (BPU)
    1995 Toyota Supra Turbo 6MT (APU)
    2006 Toyota 4Runner Limited V8
    2010 Lexus IS-F
    2016 Lexus IS 350 F Sport
  17. #15
    SupraForums Member Kracin's Avatar
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    there are lots of trannies left.
    think about it this way.
    for every car that gets wrecked, a tranny gets sold. the transmissions outlive the cars by far, in the end, there will be more transmissions left, than supras
    Click here to enlargeClick here to enlarge
  18. #16
    Join Date
    May 2010
    Location
    CT
    Age
    37
    Posts
    464
    Plus OP 3,500$ for your rebuild is pretty freaking steep, (I have the same 3rd gear syncro prob as u my re-builds gonna be 800$) I got a used V160 wi 30K miles for 3,400
  19. #17
    SupraForums Member
    Join Date
    Mar 2009
    Location
    tampa
    Age
    40
    Posts
    1,229
    I trade you my r154 with marling crawler internals for your grinding v160
    New toy on the build
    1994 mazda fd lsx ,twin 6766's
    4l80e low boost 10xxwhp
    high boost 16xx
    618 whp 492 ft @ 22 psi (Low Boost)on pump gas ,
    stock block ,more power coming soon ,stay tuned
    Tuned by Alpha @ Induction Performance SOLD
  20. #18
    ELITECUSTOMBODY exvelocity's Avatar
    Join Date
    Dec 2002
    Location
    Jacksonville Florida
    Posts
    6,552
    Jeff, da man! Right on us usual.
    OP,not too long ago I was thinking of buying all 6 speed transmissions that Toyota had in stock nationwide,thinking that supply was very low and prices going up,since Getrag filed bankrupcy ,I had a friend of mine ,that runs local Toyota parts department check if there were 50 transmissions were available, the answer was "yes",so I had him check if there were 100 available,sure enough, they had plenty, needless to say I didn't want to follow through with my idea.
    BTW, I want to go the opposite in a way,lol .I've been thinking of running V160 with LS6 motor in my 69 Firebird
    _Stefan B
    elite custom body + paint
    Click here to enlargeClick here to enlargedo what's right,not what's easy
    Need professional advice or opinion on body/paint/assembly or cosmetic related issues?Just ask.
    http://www.facebook.com/ELITECUSTOMBODY
  21. #19
    SupraForums Member turbomike76's Avatar
    Join Date
    Sep 2007
    Location
    louisiana
    Age
    34
    Posts
    1,652
    How about the tranny in the new 5.0 mustang? It's a getrag Mt82... Has anyone looked into these units for a replacement for the supra?? Just throwing it out their... I really don't know much about these mt82"s
  22. #20
    SupraForums Member Griffon's Avatar
    Join Date
    Apr 2005
    Location
    Portland Oregon
    Age
    32
    Posts
    671
    Jafo101 are you going to be selling your v160? I could use it to replace my w58 in my na-t, grinding or not its got to be better then the w58
    1993.5 Toyota Supra TT 6 speed! Stock for now ;)
    1995 Supra SE NA-T Hardtop (Sold)
    1997 Singled TT BL Auto.. APU Supra (Sold)
    1993.5 Supra NA 5 Speed (Sold)
  23. #21
    Join Date
    Apr 2009
    Location
    Moco, MD
    Posts
    1,783
    Quote Originally Posted by turbomike76 View Post
    Not sure what the pricing is on those and plus not sure if anyone knows the limits etc.... I'm sure in time more info will become available.
  24. #22
    SupraForums Member
    Join Date
    Nov 2005
    Location
    Springfield
    Age
    28
    Posts
    702
    The amount of work and time involved in finding a replacement and getting it to work simply isn't worth it.. Just get a rebuild and enjoy your day. If you're one of the auto guys going to a V160.. it'll be well worth it if you just save and go with the 6spd that BELONGS in your car, or like someone mentioned above, the R154 is a few hundred bucks and handles plenty of power for a street friendly setup for someone on a budget. Anything else just seems like a waste of time.
  25. #23
    Proud MKIII Owner 871JZ's Avatar
    Join Date
    Aug 2008
    Location
    Taneytown, MD
    Posts
    2,408
    Are you having that thing gold plated or something?
    '89 Supra, 1JZ-GTE, PowerFC, SP67DBB, HKS 256 Cams, Dual Walbros, 880cc Injectors, Tial 44, Rush Racing Anti-lag, Competition Clutch, R154, Tein Coilovers, etc!
    '95 Eagle Talon TSI AWD, Built Motor, Built Trans, Ball Bearing GT35R, DSM Link V3, 465 AWHP and 390 Torque On Pump Gas!
    '03 Cadillac DeVille DTS
    '01 Lexus IS300
    Struggling to build a turd is what most 7M owners are all about, along with avoiding rodknock and BHG's.
  26. #24
    GOT BOOST? 2JZ_MA70's Avatar
    Join Date
    Aug 2002
    Location
    Ohio
    Age
    38
    Posts
    551
    I dont know where you get the idea that the T56 is fragile... Yes if you go for the stock camaro or mustang transmission you will break it easy.....
    I see vipers putting way more torque than any supra will ever make through those fragile t-56 transmission and occasionally they do break but at that power level you probably will be splitting the case on the v160...
    The T-56 Magnum is like all the best parts of the T-56 family in one package... It has hydro pump, viper spec input and output shafts, custom gear ratio's, updated shiftforks etc...
    If you think that the r-154 can handle anything over 600lb of torque you are on borrowed time. Even with upgrades the wear in the transmission is so accelerated its just stupid. Put a aggressive clutch and good tires with one piece drive-shaft and you are going to spit gears all over. I have done it 3 times. Each costing me ~$1000 to rebuild.
    Realistically if you look at torque ratings the R was rated at 280lb the (Getrag transmissions similar to the v160 are rated at ~400lb) So 700 manufacturer rating is not that bad.
    As far as the money aspect of it... You posted it just right...
    Your existing parts are ~2500-5000 depending on condition.
    The transmission is a wash... (worse case)
    1.Bellhousing Quick Time ~600 (SFI 6.1)
    2.Clutch... either respline the disk or get new one... Custom or not its the same price... 7" quarter master multiplate will cost you ~1000 If you get 1JZ Spec Super Twin ~1500 new or 600-700 used. No matter what you spend on the clutch you have to do the same on the V-160. So cost will offset.
    3.Shaftmasters.com will get you get you aluminum drive-shaft for ~400
    4. Transmission Mount... That is tricky as no one has fabricated one.
    5. Shifter location...
    6. Hydro TOB McLeod ~400
    total cost is 4000-5500
    Is it for everyone? no its not... But you make it sound like its totally out of the question. Also you are getting new vs used/rebuild. SFI 6.1 Bellhousing that will save your legs if the clutch explodes!!! People spend more than that on the clutch alone....
    Full swap for the V-160 new is $5000 for the trans $1000 clutch/flywheel, $500 drive-shaft,....
  27. #25
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    Quote Originally Posted by 2JZ_MA70 View Post
    fyi... supras are putting down more power on v160s than the vipers are on t56s
    why would you care about torque if its going in a supra.. stop making excuses, its a shitty idea
    600hp is borrow time on an r154? you don't even know what you are talking about and want to make ridiculous claims lol, even if you have screwed up 3 transmissions. hooking with sticky tires and a driveshaft with no give combined with bad driving... of course you can screw up a trans. enough hard launches the wrong way and youll have to rebuild a v160 too, ive seen those happen also... not to mention you can pick up marlin crawler race r154s for a lot less than a t56 and still be able to handle as much.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. tranny t56 conversion
    By jafo101 in forum SouthWest Forum
    Last Post: 04-24-2011, 01:20 AM
  2. Borg warner T56 6 speed swap?
    By 9secsupra in forum MKIV (1993-1998)
    Last Post: 04-22-2011, 12:16 PM
  3. Replies: 0
    Last Post: 08-20-2010, 10:50 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
