1jzgte VVTi JZX100 harness diagram
+ Reply to Thread
Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 26 to 50 of 103
Thread: 1jzgte VVTi JZX100 harness diagram
  1. #26
    Join Date
    Sep 2011
    Location
    jordan
    Posts
    5
    hi
    i have been workin on my engine for a week but its not runnin yet the pins you said i should ground them they are already grounded somehow the engine is already in the car so here is what i did for today but still no luck
    blue connector i powered all the grey 12 pin connector 2 and 7 powered 5 to starter pcm 9 14 22 are powered but the rest grounds in the connectors are grounded already so waht i am facing now that i dont have any injectors pules or sparks any ideas?? !!!!! help
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #27
    SupraForums Member frankdms's Avatar
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    Glad I could help. Let me know you like the setup.
    Quote Originally Posted by sam2002 View Post
    hi
    1jzgte VVTi revolution
  4. #28
    Join Date
    Aug 2011
    Location
    south carolina
    Posts
    56
    It's a 1jz vvti just like in the pic going into a 01 Tacoma 2 wheel drive. My truck gross weight is 2700lbs. It had a 2rzfe manual but, I wanted a turbo and a auto tranny and money wise this was a better solution. A rebuild kit to the the 2rzfe to hold 12lbs is around 1200$ and a turbo kit 2000$ and machine work 600$. So I picked up the 1jz for 1800 the inter cooler and piping $200 the fan , trans cooler, couple of gauges, hoses , clamps, oil change, ect... 300$ all I got left is to finish the wiring , high pressure fuel pump, drive shaft shortened,3in exaught, oil pressure gauge, new rack and pinion (i want power steering back) so about 800$ and the 1j still would have more power
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #29
    Join Date
    Sep 2011
    Location
    jordan
    Posts
    5
    its jzx100 chaser we made it work for now but we have another problem the engine start to lean down after 3000+ ?!!! i did not separate power source for the injectors and the coils is that a problem ?? could it be a fuel cut?? i did not add more boost to it,do you have any ideas?? thank you
  7. #30
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    Power to the coils and injectors would not be a problem for the motor to run. For future diag watching the current it would just make things easier to find a misfire. 3k is right in the peak tq with low rpm, check to make sure the afm is not dirty. I pm'd you as well.
    How lean? How are you monitoring the a.f ratio? Is all the OE toyota fuel controls hooked up?
  8. #31
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
  9. #32
    jdm junk collector ROPADOPA's Avatar
    Join Date
    Dec 2004
    Location
    FLORIDA
    Age
    46
    Posts
    475
  10. #33
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    1jzgte VVTI Pinout
    This should help.
  11. #34
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    Found the swap to have been sold with a GE ecu not a GTE. Its a wonder that it ran as well as it did.
  12. #35
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    JZX110 ECM pinout diagran
    This should help as well. This diagram is for the 2001+ 1jzgte VVTi with the DBW.
  13. #36
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    JZX part numbers
    Cooling System
    Toyota Part number - Description
    16400-46210 - Radiator (for hydro fan)
    16371-46020 - Water pump Pulley (non hydraulic fan)
    16361-46060 - Water Pump Mechanical Fan
    16210-46030 - Water Pump fan clutch
    16100-49845 - Water pump (non hydraulic fan)
    16912-46020 - Hydraulic Fan (Shroud)
    16960-46020 - Hydraulic Fan (motor)
    16911-46010 - Hydraulic Fan (Fan)
    16929-46010 - Hydraulic Fan (Actuator Solenoid)
    89429-32010 - Hydraulic Fan (Temperatue probe)
    16913-46020 - Hydraulic Fan (Fan bracket)
    89257-14010 - Hydraulic Fan (ECU)
    16939-46010 - Hydraulic Fan (Waterpump Pulley)
    16090-49017 - Hydraulic Fan (Waterpump)
    16927-46020 - Hydraulic Fan (High pressure line)
    16571-46030 - Upper Radiator Hose
    16572-46100 - Lower Radiator Hose
    90916-03092- Thermostat
    Engine Mechanical
    13101-88400 - Pistons
    13201-46030 - Rods
    13011-88400 - Rings – full set
    11704-46020 - Bearings – crankshaft
    13204-46020 - Bearings – connecting rod
    15100-46030 - Oil Pump
    11115-88410 - Head Gasket
    04111-46032 - Engine Gasket kit
    90910-02102 - Head Bolts
    90201-11018 - Head bolt washer
    17177-88400 - Intake manifold gasket (to head)
    17179-88400 - Intake manifold gasket (to manifold)
    17173-88400 - Exhaust manifold gasket (need 2)
    11213-88400 - Cam cover gaskets Intake
    11213-88400 - Cam cover gaskets Exhaust
    90105-06133 - Cam Cover bolts x16
    90210-07001 - Cam Cover bolt washer x16
    90916-02305 - Serpintine Belt
    13568-49025 - Timing Belt
    16620-46020 - Serpentine belt tensioner
    Engine Peripherals
    78180-1B090 - Throttle cable
    12361-42050 - 89+ Motor mounts
    12315-88400 - Engine Brakcet LH
    12311-88400 - Engine Brakcet RH
    Drivetrain
    13405-46030 - Flywheel
    90910-02103 - Flywheel bolts
    31250-14183 - Clutch Pressure plate
    90363-12002 - Clutch Pilot bearing
    90363-45012 - Clutch Throw out baring
    90119-08302 - Clutch pressure plate bolts
    31111-14110 - Bellhousing
    33403-29135 - Speedometer drive gear for 4.1 diff
    Power Steering
    44403-14020 - Power Steering high pressure line
    90401-16014 - Power Steering Union Bolt
    04446-30120 - Power steering pump gasket kit
    44320-14231 - Power steering pump
    Engine Electrical
    89420-24040 - Map sensor (1JZ)
    89421-12111 - Map sensor (2JZ)
    89615-22040 - Knock sensor
    90919-05006 - Crank position sensor
    90919-05007 - Cam position sensor
    89452-22080 - Throttle position sensor
    89424-28010 - Intake air temp sensor
    89422-20010 - Water temp sensor
    89465-29435 - O2 Sensor
    89621-22030 - Igniter
    27060-46010 - Alternator
    22270-46070 - Idle speed control valve
    Filters
    90915-20001 - Oil Filter (Same as V6 Camry)
    23300-46050 - Fuel Filter
    17801-46060 - Air Filter (Same as Supra/Soarer)
    JZX100
    90919-01194 - Spark Plugs (denso?)
    90919-01195 - Spark Plugs (ngk?)
    JZX90
    90919-01180 - Spark Plugs(denso?)
    90919-01181 - Spark Plugs(ngk?)
    info was found at jzx100, hope it helps.
  14. #37
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    Here is a great site to look up specific OE part numbers
    http://toyota.epc-data.com/
  15. #38
    Join Date
    Sep 2011
    Location
    jordan
    Posts
    5
    hi guys i am workin on a 1jzgte vvti jzx110 now
    i wonder if you have a the jx110 pin out???
    if you have any tips to make it work?? wiring diagram ? more info about the ecu pin out
    i wonder if you have any idea if the ecu have any kind of key protection ?? any kind of info ganna be so useful thank you for help for the last time again
    thaks all
  16. #39
    Join Date
    Dec 2004
    Location
    FLORIDA
    Age
    46
    Posts
    475
    eeewww , fly buy wire ^^^^^^^ lol
  17. #40
    Join Date
    Sep 2011
    Location
    jordan
    Posts
    5
    ok
    i just made the jzx110 workin with out changing anything it works just fine and great i wll post some new pics and ecu pin out in case some body needs it
    if any one have a question you can ask
  18. #41
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    Post #35 has the pinout. I have diagrams in JAP/Russian, Working on that.
    thaks all
  19. #42
    Join Date
    Sep 2011
    Location
    jordan
    Posts
    5
    do you think the auto gear ganna work fine??? i wonder if i have to wire any wires to the shifter inside the car?? never did befor
  20. #43
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    ^ I believe another member has done the 2jzgte vvti setup and just (if I remember right- ) wired the trans wiring to fool the ecu into thinking it was in 3rd gear to get around the auto stuff. Interesting how similiar the jzx110 (1j vvti) and the 2j vvti pinouts are on the JDM stuff.
    I will try to find the thread about it.
  21. #44
    SupraForums Member kneedragger85's Avatar
    Join Date
    Dec 2008
    Location
    Denver, CO
    Posts
    903
    Quote Originally Posted by frankdms View Post
    I've heard about it as well. Some guys use an on/off switch wired to the NSS when cranking, then flip it off for normal driving.
    89 Supra:
    - Winter build: Built 3.0L VVT-i 2JZ-GTE, PTE6870, GSC S2's, Ethanol, and all of the boost...
    - Old Setup (going into the Cressida): JDM 2JZ-GTE/R-154 with a SP63, GSC S1's, & 633rwhp @ 30psi tapering to 21psi on E60 Click here to enlarge
    91 Cressida:
    - VVT-i 1JZ-GTE/R-154 with a 20G-hybrid CT-15b
    97 240SX:
    - SR20DET, HKS 264's, and GT2871R
    98 YZF-600R:
    - The other 4-banger
  22. #45
    Join Date
    Jul 2010
    Location
    Malaysia
    Age
    33
    Posts
    38
    since SF has provided me with alot of knowledge I would like to share this.....
    heres the JZX100 wiring diagram from the russian manual....translated it using google translate...anybody would lend a helping hand?
    and i used ur wiring guide to start my vvti....
    it runs rich and doesnt want to go in boost...when i rev it, it marks the floor with black smoke....
    looked at the diagram ensures that the exhaust sensor & solenoid has to be supplied with ign on the diagram #6 grey socket pin no 10&11
    as i hooked the power for that wire, the car doesnt want to start....any ideas?
  23. #46
    Join Date
    Jul 2010
    Location
    Malaysia
    Age
    33
    Posts
    38
    for JZX100 ECU pinout and auto box pin out, do visit this facebook page. its all there...
    http://www.facebook.com/pages/UltraW...42?ref=tn_tnmn
    will add more info as soon i get new info....
  24. #47
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    ^ Good job! I have the original russian/jap diagrams as well, but gave up on russian translate...
  25. #48
    Join Date
    Jul 2010
    Location
    Malaysia
    Age
    33
    Posts
    38
    better of doing the russion....if you do it long enough...youll get used 2 it...
    no way for the JAP...theres so many not understood characters....
    any ideas on what would be my problems?
  26. #49
    Join Date
    Jan 2010
    Location
    denver
    Posts
    501
    If it is loading up on fuel I would look into a boost leak first. Check to make sure the TPS range and voltages are correct, check to make sure the ECT (engine coolant temp sensor) condition and resistance at what ever given temp the engine is at. See if unplugging the maf sensor changes the condition.
    I can do specific pinpoint tests and give you values for anything you want to check as well. Did you keep the diag port? If you have the eng lt wired you can check for codes as well to help find a starting point.
    Try to see if those checks yield anything.
  27. #50
    Join Date
    Jul 2010
    Location
    Malaysia
    Age
    33
    Posts
    38
    yupp....i didnt remove the diag port....could you help me out with the pinpoint test?
    starting to scratch my head.........
    thanks a lot in advance
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. anybody have a Chaser VVTI wiring diagram?
    By jz_killa_t68 in forum 1JZ/2JZ Swap
    Last Post: 01-24-2012, 09:39 AM
  2. MAF diagram for a vvti 2jz-ge
    By BoostCreep in forum Naturally Aspirated
    Last Post: 12-03-2008, 12:42 AM
  3. emanage VVTI wiring diagram
    By TDaxGav in forum MKIV Technical
    Last Post: 04-20-2005, 08:39 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
