How to tell if Oil is going to turbo?
+ Reply to Thread
Results 1 to 11 of 11
Thread: How to tell if Oil is going to turbo?
  1. #1
    XECUTOR usccox's Avatar
    Join Date
    May 2007
    Location
    Oklahoma
    Posts
    208
    How can i tell if my turbo is getting oil?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member cyberBird's Avatar
    Join Date
    Apr 2008
    Location
    Cincinnati
    Age
    27
    Posts
    1,850
    Pull off the oil feed line and put it in a clear bottle then pull the EFI relay in the fuse box and have someone crank over the car a few times. Your oil line should spit out a bunch of oil if it's properly feeding.
    1995 N/A-T hardtop - s366 / BL 4" titanium / SP ffim / AEM v1 / WORK XD-9 / Tein Flex / HKS / TiAL / TRD / APR / Cusco /
    2014 BRZ limited 6mt - Greddy SP Elite / KW v1 / Enkei Raijin / HKS / STI / Perrin
    Click here to enlarge
  4. #3
    Join Date
    May 2007
    Location
    Oklahoma
    Posts
    208
    Thx...will try it out.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member Kwiktoy's Avatar
    Join Date
    May 2003
    Location
    MI
    Posts
    495
    If the engine hasn't run for a while, it may take quite a bit of cranking, so be patient.
  7. #5
    Join Date
    May 2007
    Location
    Oklahoma
    Posts
    208
    OK...its gettiNg oil. It seems to get too hot....burning/smoking my Turbo blanket. Is this normal. How do I know what's too hot. Exhaust gas temp?
  8. #6
    SF.com Member #0000000023
    Join Date
    Feb 2001
    Location
    Costa Mesa
    Posts
    1,362
    Heh, there's a lot easier way to see if it's oil if you've been driving on it. I don't think a turbo would even make it 1 mile without oil pressure.
  9. #7
    SupraForums Member FLINTSTONESKID's Avatar
    Join Date
    Apr 2005
    Location
    Reading PA
    Age
    39
    Posts
    7,705
    ^^^huh??? ok?
    anyhow,i bet the smoke/burning you are seeing is either from a low quality blanket or from assembly and oil on your hands. take the blanket off and run like that for a bit, itll burn off surface crap quickly and if it doesnt smoke, its the blanket, i have owned shitty ones that do
  10. #8
    Join Date
    May 2007
    Location
    Oklahoma
    Posts
    208
    can't be low quality...ordered straight from MVP! The turbo seems to get really, really hot...much hotter than before i put the cams in. I realize it will get VERY hot...but the smoke makes me worried. No leaks from anywhere i can see. The turbo has been rebuilt and the return line is good to go.
  11. #9
    SupraForums Member jcieslik's Avatar
    Join Date
    Apr 2008
    Location
    Dallas
    Posts
    278
    Rebuilt turbo huh? Oil seal maybe. Unless it was a brand new cartridge I would never trust a rebuilt turbo. I have wasted my time in the past with those and have learned the hard way they are not worth it.
  12. #10
    Join Date
    May 2007
    Location
    Oklahoma
    Posts
    208
    Ouch....but yes...whole new exhaust backend that I sent to majestic.
  13. #11
    Time for change
    Join Date
    Apr 2002
    Location
    Albany, NY
    Age
    35
    Posts
    6,868
    You put cams in and it's running too hot. Well you're now burning fuel in the exhaust.
    Could be cam timing, or ignition timing.
    With low ignition timing trying to get my idle low, I could get my turbo to glow at 1000 rpm idle.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. what oil and oil filter for mkiv Turbo
    By tectyl in forum MKIV (1993-1998)
    Last Post: 11-10-2011, 02:31 AM
  2. oil pressure turbo feed line psi.. oil reducer??
    By supraracer01 in forum MKIII (1986.5-1992)
    Last Post: 04-27-2010, 06:49 PM
  3. Replies: 6
    Last Post: 10-01-2005, 10:28 PM
  4. Replies: 6
    Last Post: 02-08-2003, 08:33 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
