Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: Rear Camera install
    SupraForums Member brianbri6's Avatar
    Sep 2006
    Chicago, IL & Beach Park, IL
    28
    113
    Rear Camera install
    this is my OEM looking reverse camera install thread since I didnt see any post of a rear camera on a supra I posted my own. this camera came from a backup camera of a RAV4 on ebay the link is below. I paid $25 plus shipping and got it with in a week and a half from hong kong its not plug and play as in you will have to fabricate some type of bracket to hold the camera in place but the spacing is correct for the opening of the license plate light without having to make mods to the rear bumper. all I did was trim plastic off the original light bracket glue n screwed the camera on the bracket and filed down some extra plastic so I can screw the original light socket in. took me about 4 hr because I like 2 do things slow.
    Ebay Reverse Rear View Backup Camera RAV4
    Bumper removal
    tools:
    10mm socket with a Universal Joint
    phillips head screwdriver
    flat head screwdriver
    you are going to have remove the inside rear trunk panels 4 phillips head screws on the back side and 8 phillips head screws on each sides to get to the two gold 10mm bolts on each side to loosen the bumper, remove tail lights which is held down by two 10mm bolts on each side, on the corner of where ur tail lights were there is a 10mm bolt on each side remove it. there is approx 11 plastic black phillips head screws around where u remove the tail lights. remove all of them and carefully remove the retainers. remove the 3 phillips head screws holding the license plate light on the bumper. go under the car to remove a 10mm bolt on the bottom corners of the bumper, while ur still down there is gonna b a black strip with 4 phillips head screws remove them and be careful not to bend the bar use a flat head to carefully pray it loose. there is 1 more clip under the bumper right under the exhaust to fully remove the bumper. to be continued.
    this is the spacing and the video feed above it is what it looks like from the camera
    rear view backup back up camera
    "La Negra"
    SupraForums Member Nissayota's Avatar
    Apr 2011
    Miami, Fl
    28
    300
    nice
    05 Altima SE-R / daily
    95 2JZ S14 drag/drifter
    SupraForums Member benzo555's Avatar
    Jun 2005
    H-Town
    1,165
    Very nice install and oem look!
    97 Supra TT Limited Edition 6spd BPU
  4. #4
    SupraForums Member j_mejia17's Avatar
    Aug 2010
    Chicago
    243
    Nice write up Brian. I'm definitely gonna hit u up when I get a chance to do this. What head unit do you have?
    Live simply. Love generously.
    Care deeply. Speak kindly.
    Leave the rest to God.
  5. #5
    SupraForums Member Northstar's Avatar
    May 2005
    Orlando
    4,053
    Great write up! One of these days I'll replace my stock stereo! lol
    Ryan
    '94 Single 6 Speed
    '03 Acura CL Type-S 6 Speed
    Instagram
    My RR Supra Build| HRE | Ridox |& More...
    Quote Originally Posted by HellBringer View Post
    Not driving and/or modding a Supra is like not banging your hot, horny girlfriend/wife in hopes she'll be more appealing to her next boyfriend/husband.
  6. #6
    SupraForums Member warranty's Avatar
    Nov 2003
    Silicon Valley, CA
    156
    Very nicely done, and great find on that stock Toyota rearview camera which is nicely hidden.
  7. #7
    Sep 2006
    28
    113
    Quote Originally Posted by j_mejia17 View Post
    It's a generic Chinese double din head unit from ebay. which im replacing for a carputer and removing the stock A/C controls. im putting in touch screen monitors and A/C controls. its all part of modernizing the supra with todays technology that we have on cars now esp the luxury cars. so ima retrofit everything I can. so there is alot more to come. im just getting started.
  8. #8
    SupraForums Member 94Singledout's Avatar
    Aug 2009
    Jersey
    417
    Thats a nice clean look OP I was thinking of doing that too just went a diff route...don't mean to threadjack And bump up an older thread ... Just ran across this and just giving these Guys another option on where to mount it. If it's a problem I can take the pix down.
    "KoloskiBuilt" '94 supra tt 6 speed, Precision 7275
  9. #9
    SUPRA 7 2JZPWRD's Avatar
    Aug 2007
    Tempe, Arizona
    2,147
    That's an awesome spot!! Hows the view? Can you see a good amount when backing up?
    1998 TOYOTA SUPRA TURBO QUICKSILVER 6SPD, ADV.1, BPU+
    1997 TOYOTA SUPRA TURBO 6SPD, TOP SECRET CUSTOM WIDEBODY
    1995 TOYOTA SUPRA TURBO 6SPD, 67MM, FULLY BUILT, IFORGED, PROEFI e85
    2014 NISSAN GT-R PREMIUM, DAILY BEATER
  10. #10
    Aug 2009
    Jersey
    417
    the view is really good .. you just have to take your time installing it, because you never know what side is up on these lil cameras. So all i had to do was wire it up and mark the top of the camera and then installed it that way. I think its a clean spot, but on the other hand you loose the ability to pop your trunk from outside (i never did anyway, i always use the handle from inside)
  11. #11
    SupraForums Member kingerm's Avatar
    Sep 2001
    SoCali
    922
    How do you go about telling your display to switch over to the camera when you put it in reverse?
  12. #12
    RoastBeefCurtain Commando PM-Performance's Avatar
    Dec 2004
    Tierra de los inmigrantes, PA
    33
    5,975
    interesting write up. I wouldnt mind trying something like this for a small investment cost. Seems to be a cool/cheap project although how much do you use it when backing up?
    Do you manually need to switch to camera when backing up? Or hook it into a reverse wire to have it switch over?
    09 G37X
  13. #13
    Aug 2009
    Jersey
    417
    i basically did it just to have it, that camera is a pyle and it only cost me 39.99 from ebay. And i do have a manual switch and i can turn it on anytime i want.
    To be honest out of the 9 or 10 months i have it, i have only used it once while parking. So its basically just to say i have a rear view camera haha. the only time i use it is when we have cruises and i turn it on to see your buddies car behind you .. take some cool pix and stuff. Thats about it.
  14. #14
    extreme V PRIME of V(t) agm's Avatar
    Feb 2009
    West Coast Canada
    5,575
    time to install a go-pro in the hatch keyhole
    -adam ส็็็็็็็็็็็็็็็็็็็
    701whp/517wtq pump/meth, revs to the freaking moon son (tuned by bill)
    rps header, hks t51r kai, rps triple carbon, open dump, 4" exhaust, aem v2, gsc s2 cams, ported head, dualsprings, titanium retainers, shimless buckets, +1mm valves, 8500 rpm rev limit.
    sample vid: http://www.youtube.com/watch?v=hHeSk4StvpM
  15. #15
    May 2005
    Orlando
    4,053
    Quote Originally Posted by 94Singledout View Post
    Nice mod with the camera! I like the idea.. Ill probably do the same just to say i have a rear view camera lol... Can you take pics of your display when you turn your rear camera on? thx!
  16. #16
    SupraForums Member RedSoup's Avatar
    Jul 2011
    San Diego, CA
    350
    Thanks for the mini write up. Planning to do this soon since my head unit supports it.
    97 USDM | 2JZ-GTE | T78 | 1200cc | AEM EMS | Auto | 100% Self-Built & Tuned
  17. #17
    Junior Member
    Apr 2009
    Las Vegas, NV
    140
    Thanks for the write up Brian, I have an old Pioneer AVIC-N2 which has a rear view camera, but isn't as clean as yours, so I'm planning on replacing them.
    1) Does that backup parking guide line a feature of the camera or your head unit?
    2) Is there a reason why you installed the camera on the left side vs. the right? It would seem to be that if you installed it on the right, you would be more centered.
    Thanks.
  18. #18
    SupraForums Member kane93tt's Avatar
    Sep 2010
    QC, Canada
    790
    Blog Entries
    1
    Received mine today from hongkong, nice unit for the price, will try to mount it next season by only removing one of the 2 taillight to run wire and connect backup light trigger and remove the licence plate light by the licence plate hole (JDM rear bumper)... nice find !
  19. #19
    Member
    Oct 2008
    az ca tx
    3,166
    nice install thanks for sharing man
  20. #20
    Junior Member
    Apr 2009
    Las Vegas, NV
    140
    Just got my camera!
  21. #21
    Jul 2002
    Huntley, IL
    32
    477
    The backup camera in my car is also in the keyhole. I love it.
    1995 TRD Widebody - 56K miles
  22. #22
    SupraForums Member supra650's Avatar
    Dec 2003
    Seattle
    240
    I use this camera quite often for my installs. Gives a nice oem fit and finish.
    http://iatft.com/Pages/detail_rvc1150_camera.htm
    This is my second favorite if you dont have room to drill. They even have a version with a 6mm stud so it bolts to the rear bumper.
    http://iatft.com/Pages/detail_rvc1100.html
  23. #23
    Sep 2006
    28
    113
    Quote Originally Posted by kingerm View Post
    the head unit has a reverse wire and i connected it to the reverse light wiring so when i kick it in reverse it automatically switches the display. I am going 2 use it more once i replace the rear view mirror with a lcd because i am going 2 black out my rear window. my next project is to remove the side mirrors and replace them with cameras and have LCD's in the dash my goal is to black out all the windows except the front of course.
  24. #24
    SupraForums Member BoostLee's Avatar
    Oct 2008
    STL
    1,083
    Nice!
    '94 RHD TT Supra HardTop Auto SOLD
    '94 RHD TT Supra RZ HardTop 6spd (Garage Queen)
    '98 Toyota Camry (Daily beater)
  25. #25
    Sep 2010
    QC, Canada
    790
    Blog Entries
    1
    Quote Originally Posted by brianbri6 View Post
    I understand you can tint u to 95% ther ear windows and rear quarter windows, some peoples will also put 50 to 95% tint for the front windows, but BLACK OUT ? Tint will lets you see dangerous angles and crazy drivers arriving fast. You'll be in some serious accdent or easily prevented small ones if you totally black out your windows....
  1. MKIV Rear View Camera ANYONE???
    By Roadie8105 in forum Mobile Electronics (I.C.E.) and Lighting
    Last Post: 08-22-2011, 03:55 PM
  2. Replies: 4
    Last Post: 08-06-2007, 10:31 PM
  3. Pioneer Avic d3 with XMTraffic and Rear backup camera
    By INFINITE in forum Mobile Electronics (I.C.E.) and Lighting
    Last Post: 08-03-2007, 09:28 PM
  4. Rear quarter Sub install??????
    By agndrs in forum Mobile Electronics (I.C.E.) and Lighting
    Last Post: 04-28-2006, 11:09 AM
