how much boost on close to stock 2jzgte engine
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 34
Thread: how much boost on close to stock 2jzgte engine
  1. #1
    SupraForums Member
    Join Date
    Jul 2010
    Location
    in the middel off nowhere
    Posts
    689
    i have a 2jzgte jap spec engine. it is almost stock. the thing i have done on it is.
    fmic
    cat back system (still have the 1 kat closest to the engine)
    run ttc
    how much boost should i reach on the engine 0.75 bar or 0.9 bar
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Nov 2010
    Location
    North America
    Posts
    155
    You can run full decat, and all the mods for bpu in the world... Your still going to be at stock Jdm boost until you manually or electronically raise it.
  4. #3
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    689
    but it is strange, when the hose there goes from the 1 turbo to the wastgate fell off, the engine boost 1.5 bar, how is that possible when you say that only way to raise boost is manually or electronically??
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member roadtalontsi's Avatar
    Join Date
    Oct 2005
    Location
    dallas
    Age
    31
    Posts
    839
    that would be a form of raising it manually. lol
    93' 6spd 60mm -487whp & 431wtq 18psi & 93* self tuned
    10' C63amg Weistec stage 2 538whp 534wtq
    02' Trans am ws6
    94' rx7
  7. #5
    SupraForums Member
    Join Date
    Aug 2011
    Location
    Maryland
    Posts
    232
    accedently maunally... haha
  8. #6
    2JZ swapped! Fletch124's Avatar
    Join Date
    Jul 2004
    Location
    Reno NV
    Age
    27
    Posts
    879
    Its not the engine that you need to worry about. Worry about those ceramic jdm turbos. Correct me if im wrong but isnt the consensus that running anything more than 14psi(~.9bar) is detrimental to the turbos life span.
    WW Evo 8
    Dinan S3-R supercharged/intercooled E46 M3 6MT = sold
    95 blk/blk TT 6-speed Supra = sold
    WW Evo 8 = sold
    PTE6765dbb 2jz Mk3 Supra = sold
  9. #7
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    689
    i now that about the turboes. but what is the right answer to my questions?
  10. #8
    Found E85 NOT in NJ! twinturbosupra94's Avatar
    Join Date
    Jul 2004
    Location
    Wayne, NJ
    Age
    29
    Posts
    5,251
    Quote Originally Posted by supra mkiv View Post
    If you know that, then you should stay around 14psi and not go above that too often. 14psi is about .97 Bar.
  11. #9
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    689
    yes but that was not my questions. the questions was with the changes, what should the boost be 0.75 bar, which is std setup. or 0.9 bar because of the exhaust change?
  12. #10
    Join Date
    Jul 2004
    Location
    Wayne, NJ
    Age
    29
    Posts
    5,251
    .9 bar. Not even sure how this is a question. You can run .9 bar on a stock setup with no modifications....
  13. #11
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    689
    yes but I've talked to some people. who says the changes I've made on the car, it should have 0.9 bar without any kind of boost controller on the engine. while others say that as long as I have mounted the cat mountet, it leaves the only standerat boost setup at the 0.75 bar. so just wanted to hear who was right?
  14. #12
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Orange County, California
    Age
    26
    Posts
    2,145
    Quote Originally Posted by Fletch124 View Post
    more like 1 bar or is it 1.2 bar? one of the two.
  15. #13
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    689
    Quote Originally Posted by Ryeno View Post
    here in denmark we run fin with 1.2 bar..
  16. #14
    adammackintosh.net agm's Avatar
    Join Date
    Feb 2009
    Location
    West Coast Canada
    Posts
    5,782
    I would keep it below 40-50 psi on a stock longblock
    Stock jdm turbos I would keep 16-18psi
    -adam ส็็็็็็็็็็็็็็็็็็็
    701whp/517wtq pump/meth, revs to the freaking moon son (tuned by bill)
    rps header, hks t51r kai, rps triple carbon, open dump, 4" exhaust, aem v2, gsc s2 cams, ported head, dualsprings, titanium retainers, shimless buckets, +1mm valves, 8500 rpm rev limit.
    sample vid: http://www.youtube.com/watch?v=hHeSk4StvpM
  17. #15
    SupraForums Member JZA86's Avatar
    Join Date
    Sep 2008
    Location
    Orlando FL
    Posts
    881
    So glad I found this post before I started a new one...
    I have a JDM 2jzgte swap in my Supra
    Mods are
    -Megan Racing Downpipe 3"
    -Greddy Power extreme Exhaust 3.75"
    -No Catalytic Converters
    -FMIC
    And I'm seeing 18-19psi (1.3-1.39 bar)
    Is there a malfunction.... I've checked all vacuum hoses they look fine..
    I know the stock twins can't handle this amount of boost. And I'm getting boost/fuel cut in 3rd gear..
    Click here to enlarge" border="0" />
    86 Toyota AE86 GT-S Hatch (2015 Project)
    93.5 Toyota Supra Targa
    01 Toyota S-Runner TRD Supercharger GEN II
    02 Lexus GS430 (SolD)
    07 Yamaha YZF-R1
    09 Lexus LS460L AWD EXEC PKG
    13 Lexus GX460
    16 Lexus RC-F
    CCW LM5/V160/Precision 6766/AEM V1
    MY MKIV BUILD THREAD
    http://www.supraforums.com/forum/sho...d.php?t=604477
  18. #16
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Age
    26
    Posts
    2,145
    The JDM non VVT-i twins overboost without a restrictor ring placed in the exhaust.
  19. #17
    Join Date
    Sep 2008
    Location
    Orlando FL
    Posts
    881
    Ok sorry to ask, but what is a the restrictor ring and where do I get one..I don't want to invest a lot of time in the twins but I need them to last until I get all the minor details handled...
  20. #18
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    67
    Posts
    13,495
    I don't know if you can buy one but they're easy to make. The restirctor ring goes into the exhaust pipe or downpipe; easiest to install one at one of the joints in the exhaust system. It's just a stainless steel plate with a hole in it, say 2" hole. The overboost is caused by exhaust that is too free flowing and wastegate too small.
    Nick 95 6sp
    Twin Garrett GT2860's w/TiAL exhaust housings, WG's and BOV's, on V-band moded HKS twin manifolds, AEM v2, AEM WB, ID1000's,
    AEM meth/water spray kit, GSC S1 cams, ported head Ferrea valvetrain, +0.020" CP pistons w/crown & skirt coatings, Carrillo H-beams,
    OS Giken triple clutch & Super Lock LSD, Racelogic TC, TRD gen2 catback
    street wheels: Veilside EvoV 9-1/2"F X 10-1/2"R with 265/35F & 285/35R NT05's
    track wheels: CCW LM5 10"F X 11-1/2"R with 285/30F & 315/30R R888's
  21. #19
    SupraForums Member
    Join Date
    Nov 2010
    Location
    North America
    Posts
    155
    I ran full decat, intake, 4inch catback, mines Ecu, fuel line bypass, cam gears set to -4 +1, on Jdm 6spd and guess what?
    I ran 11-12 psi all day after... Until guess what I did to get 18-20 psi?? And never over boosted once without a restrictor ring mind you.. Why?
  22. #20
    Join Date
    Sep 2008
    Location
    Orlando FL
    Posts
    881
    Ok I'll try that hopefully this works...I have a greedy Profec B spec II, I'm assuming that installing it won't help to lower the boost since it over boosting due to the exhaust..
  23. #21
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    689
    who is right?????
  24. #22
    SupraForums Member
    Join Date
    Nov 2010
    Location
    North America
    Posts
    155
    Who was right? Your friends are. .09 bar to .75 bar is your concern here on supra forums. So what are you going to do now?
    Does Denmark have race gas?
  25. #23
    SupraForums Member
    Join Date
    Jul 2010
    Location
    Posts
    689
    yes who are..
    one sad, that with my change on the engine, it should reach 0.9 bar on full trottle.
    the other sayes because i have the first cat on the car, it should reach 0.75 bar on full trottle..
    who is right???
  26. #24
    SupraForums Member
    Join Date
    Nov 2010
    Location
    North America
    Posts
    155
    To Jza86: dont be sorry for asking, we're all learning something new everyday. So why would having an exhaust cause you to over boost? What does over boost mean? How do you know you are "over boosting"?
    A restrictor ring is a term only used in Europe/Australia due to sea level/altitude that played a factor during certain seasonal weather conditions. If anyone was to make a restrictor ring, how come the Japanese has never made one yet alone heard of one?
    Electrnic boost control is a good thing, but I'm starting to think you guys are posting questions here without even reading mkiv.com tech articles..
  27. #25
    SupraForums Member
    Join Date
    Nov 2010
    Location
    North America
    Posts
    155
    To supra mkiv: trust me Im coughing, what does your boost gauge say before you ask who is right..
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Replies: 8
    Last Post: 11-27-2010, 01:03 PM
  2. WTB: 2JZGTE stock engine
    By kevganzon in forum For Sale/Wanted
    Last Post: 07-29-2005, 04:42 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
