This is what a cracked coil pack looks like and what it does when it's bad.
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 37
Thread: This is what a cracked coil pack looks like and what it does when it's bad.
  1. #1
    SupraForums Member
    Join Date
    May 2002
    Location
    Long Island
    Age
    37
    Posts
    999
    I was troubleshooting an issue with the car and found that several of the coil packs were cracked. I read a post where some members were not sure where to look for the cracks and what it would look like if the coil was in fact bad. The cracks are typically under the rubber boots at the tip. Mine were cracked from the tip under the boot almost all the way up the entire post. If your coil is cracked the spark will exit the side instead of the end of the post and ground out like this. I hope this helps out a little.
    93 Royal Blue/Grey Typhoon #1716
    Best time 12.1 at 108mph, 1.7 60ft, 23lbs, c16, no launch.
    92 Raspberry/Raspberry Typhoon #1312
    93.5 Silver TT Supra, APU Auto 601rwhp 605ft-lbs @24psi 6300rpms
    98 RSP, build pending
    92 Typhoon Black #2212 sold
    Click here to enlarge
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Time for change
    Join Date
    Apr 2002
    Location
    Albany, NY
    Age
    35
    Posts
    6,868
    Nice shot man.
  4. #3
    Join Date
    Jul 2009
    Location
    Edmonton
    Posts
    59
    Wow talk about good timing...
    I just recently went BPU and with the turbo's boosting 16lbs at WOT my car is "hiccuping" so to speak. I've never experienced misfiring, does this sound like misfiring?
    I suspect its my coilpacks because they werent in the best shape when I got the car serviced last.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member slither's Avatar
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    39
    Posts
    6,785
    Be interested to see what it does with the plug plugged in
  7. #5
    ELITECUSTOMBODY exvelocity's Avatar
    Join Date
    Dec 2002
    Location
    Jacksonville Florida
    Posts
    6,552
    did you have weird misfire? I'm trying to figure out breaking up from around 2100 rpms through 2700,tried swapping coils,new plugs,no change
    _Stefan B
    elite custom body + paint
    Click here to enlargeClick here to enlargedo what's right,not what's easy
    Need professional advice or opinion on body/paint/assembly or cosmetic related issues?Just ask.
    http://www.facebook.com/ELITECUSTOMBODY
  8. #6
    SupraForums Member
    Join Date
    May 2002
    Location
    Long Island
    Age
    37
    Posts
    999
    Yes the car breaks up starting at 16psi and the powerband goes flat. At first i thought the tps was the culprit but after testing i have ruled that out and went to the ignition system. I wont have the new packs until tuesday but i am a betting this is my problem as i have checked for boost leaks and found only two vac leaks wich have been repaired. All six of mine are shot just like this one.
  9. #7
    SupraForums Member
    Join Date
    Apr 2008
    Location
    Houston
    Posts
    1,257
    Cool pic. I read that you can use some heat shrink to fix that problem.
    93 Baltic Blue (6spd) hardtop - PT6870 - 10.1CR - E85 - AEM Infinity6 - 940hp/830tq - 3000lbs
    97 White SC300 - BWR
  10. #8
    From the land down under Mr Ree NZ's Avatar
    Join Date
    May 2008
    Location
    Wellington, New Zealand, 6023
    Age
    43
    Posts
    3,250
    drfitmotion sell a set of sleeves to put over the stems, then the engines heat shrinks them to a tight fit.
    Only about $5 too so worth a try if you have cracked stems
  11. #9
    SupraForums Member
    Join Date
    Apr 2008
    Location
    Houston
    Posts
    1,257
    ^^^There you go...
  12. #10
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,657
    I chased a misfire issue for many months and even drug my car 1100 miles to TX with a hit or miss, literally. I finally found out what the problem was, cracked coil packs and it was arcing on the head causing major misfire issues. I put new coilpacks in the car and had no other issues. It sucks too because all those people in TX and nobody offered any advice to what was wrong with the car or offered to help. It was a miserable trip for me due to car issues.
    1994 Red/Black TT
    86K miles
    Roller...6 speed swap coming soon
  13. #11
    Newbie
    Join Date
    Aug 2011
    Location
    Bangkok
    Posts
    67
    Wow you need MSD coils
  14. #12
    SupraForums Member
    Join Date
    Mar 2009
    Location
    tampa
    Age
    40
    Posts
    1,229
    Quote Originally Posted by exvelocity View Post
    Stefan i having the same issue but from 1000rpms to 2500 rpms .if you find out what was your problem please let me know ,i will do the same....Thanks.....Omar
    New toy on the build
    1994 mazda fd lsx ,twin 6766's
    4l80e low boost 10xxwhp
    high boost 16xx
    618 whp 492 ft @ 22 psi (Low Boost)on pump gas ,
    stock block ,more power coming soon ,stay tuned
    Tuned by Alpha @ Induction Performance SOLD
  15. #13
    SupraForums Member LarsFuglsang's Avatar
    Join Date
    Aug 2011
    Location
    Thailand
    Posts
    329
    I just upgraded my coils to high power coils
  16. #14
    SupraForums Member
    Join Date
    Jan 2007
    Location
    Wilmington NC
    Age
    28
    Posts
    1,458
    Quote Originally Posted by thrustn View Post
    Didnt fix anything in my case. I glued and heat shrunk them. When the coils go bad just replace them.
  17. #15
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    39
    Posts
    6,785
    What I was getting at is if the path is to the head, you will see the symptoms jason seen e the problem will not only be under boost but at any rpm. You would essentially would be driving with a coil pack unplugged
  18. #16
    Join Date
    Dec 2002
    Location
    Posts
    6,552
    mine usually starts acting up when hot and before any boost ,half the time in regular stop & go traffic sounds like STi,lol
  19. #17
    SupraForums Member
    Join Date
    May 2002
    Location
    Long Island
    Age
    37
    Posts
    999
    Just an fyi for everyone who is thinking of buying new coil packs. I just purchased six new forecast coil packs for $311 shipped and they work great. The car starts and boosts better than before! The parts have a one year warranty as well! I got them from partsgeek.com and If you spend 299 or more put the code save15 in to save 15 bucks! I tried to buy the beck and arnelys first but they are backordered for at least two weeks. The total for them was 292 shipped and you saved 10 bucks with the code save10 on orders over 250! If these packs last 50,000 miles i would have no replacing them again. I know guys say oem phr .....but who wants packs on their car with 100k on them....! I would rather buy these and have new packs on the car at 50k rather than run them up to 100k plus it would take an eternity for most of us to put 50k on our rides anyhow!
  20. #18
    SupraForums Member
    Join Date
    May 2010
    Location
    WA state
    Posts
    239
    thats some good feedback spoold up. I went with the OEM because i couldnt find any reviews, but next time i need one I might go with those. Have people had good luck with epoxy repairs on the cracks and having that fix break up issues?
    CJG
  21. #19
    Proud MKIII Owner 871JZ's Avatar
    Join Date
    Aug 2008
    Location
    Taneytown, MD
    Posts
    2,408
    Quote Originally Posted by slither View Post
    Same here...
    '89 Supra, 1JZ-GTE, PowerFC, SP67DBB, HKS 256 Cams, Dual Walbros, 880cc Injectors, Tial 44, Rush Racing Anti-lag, Competition Clutch, R154, Tein Coilovers, etc!
    '95 Eagle Talon TSI AWD, Built Motor, Built Trans, Ball Bearing GT35R, DSM Link V3, 465 AWHP and 390 Torque On Pump Gas!
    '03 Cadillac DeVille DTS
    '01 Lexus IS300
    Struggling to build a turd is what most 7M owners are all about, along with avoiding rodknock and BHG's.
  22. #20
    SupraForums Member ssao1's Avatar
    Join Date
    Feb 2006
    Location
    Santa Rosa, NorCal
    Posts
    1,054
    Stefan,
    What is the injector and ecu setup on the car?
  23. #21
    Inline for the win Suprafied's Avatar
    Join Date
    Dec 2001
    Location
    Dublin, OH
    Posts
    4,731
    Weird,
    I am chasing a similar issue on a friend's car. Inconsistent and random misfire at idle and consistent misfire at 5700-6k RPM, if under boost. Coils have 50k miles on them and ohm out acceptable per TSRM.
    DP
    Do more with less......
    '95 Toyota Supra TT 6-spd Targa JRR/MoTeC M130 , AP 3.4L, SP F1, Tilton, Precision, Recaro, HKS ID, Boostlogic, PHR, ETS....
    My Build Thread
    '16 Lexus IS350 AWD F-Sport
    '09 Dodge Ram 3500 QCLB Dually 6.7 CTD EFI Live by Anarchy
    '05 Toyota Camry XLE
  24. #22
    SupraForums Member
    Join Date
    May 2002
    Location
    Long Island
    Age
    37
    Posts
    999
    Did you check the coils when hot? My coils ohm'd out at 1.2ohms piece. I thought it was strange that all of the coils were dead even but all were out of spec. Its very easy to see the arc. Just do what i did.
  25. #23
    SupraForums Member
    Join Date
    May 2010
    Location
    WA state
    Posts
    239
    You tried that with al the coils and only the one acted like that?
    CJG
  26. #24
    The Great Kruso Kruso's Avatar
    Join Date
    Mar 2002
    Location
    Sugar Land, TX
    Posts
    3,869
    Money shot, looks pretty cool.
    1991 MKIII Toyota Supra 1JZ, the "official" FFIM MKIII- Officially stolen.
    1994 MKIV Toyota Supra Single T70, Fuel, MAP ECU, RPS 6 puck................Sold.
    1993 MKIV TT w/ 79k original miles APU
    2011 Toyota Tundra 5.7 Rock Warrior
    Click here to enlarge Originally Posted by Zach90Turbo Click here to enlarge
    When I put 7M in the search it only came up with blown head gasket threads.
    "There is so much good in the worst of us, And so much bad in the best of us. That it behooves all of us Not to talk about the rest of us."
  27. #25
    Supra Enthusiast
    Join Date
    Mar 2009
    Location
    The Eagle has landed
    Posts
    2,072
    Quote Originally Posted by Vlads2jz View Post
    2 friends of mine heat shrunk theirs and they are working just fine at 700rwhp+. I guess if its minor then the heat shrink will work because their cracks were nothing like above.
    With that crack above I would replace them all with the superspark coils.
    Vlads, were your coils cracked really bad?
    4 digits on pump&meth is not impossible (low boost)
    Real hp is measured at the wheels.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Bad coil pack???
    By BurnMac42 in forum MKIV (1993-1998)
    Last Post: 06-20-2007, 09:53 PM
  2. how bad of a miss will i have with a bad coil pack?
    By soupdog89 in forum MKIII Technical
    Last Post: 12-21-2006, 05:27 PM
  3. Coil Pack Bad?
    By RB76 in forum MKIII (1986.5-1992)
    Last Post: 11-22-2006, 02:18 PM
  4. Bad #1 coil pack?
    By Mk3_300 in forum MKIII (1986.5-1992)
    Last Post: 08-03-2004, 01:19 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
