FS: 98 GS300 w/ Single 2JZGTE
+ Reply to Thread
Results 1 to 4 of 4
Thread: FS: 98 GS300 w/ Single 2JZGTE
  1. #1
    SupraForums Member
    Join Date
    May 2006
    Location
    South Florida
    Age
    41
    Posts
    274
    UP for sale is a 1998 Lexus GS300 with a non vvti 2JZGTE single swap. It is alpine silver with black leather interior. The car has a clean title and all matching vin stickers. It has 188,500 miles on the chassis, I don't know the mileage on the swap, the swap was done by a previous owner. Compression test was done and it is 165 psi across the board. It was dynoed and made 304 WHP @ only 9 psi. The car is my daily driver at the moment.
    About the swap:
    A non-vvti 2jzgte engine was swapped in the car by a previous owner. All gauges inside work(tach, speedo, temp,fuel ) no check engine lights. The car is running on 2 ecu's, the stock 2jzge and the stock jdm 2jzgte ecu that controls the engine and transmission. Car is running an Aristo transmission with an external B&M transmission cooler with nylon -6 AN lines and an fittings.
    Car specs
    Exterior:
    TTE front lip
    Rear spoiler.
    6K HID.
    Yellow fog lights
    Updated taillights.
    Window tint.
    New front windshield.
    Interior:
    Black leather interior.(7 out of 10, no tear on the leather, looks good for the mileage)
    Alpine radio with lcd screen.
    LCD screens on the headrests.
    Custom made gauge display with boost and AEM wideband gauger
    All Power windows and locks working properly.
    AC blows cold, a/c compressor was replaced just a year ago.
    Suspension
    Tein Stech springs with KYB struts( Installed at 176K miles)
    G35 18" wheels w/ hubcentric rings.
    New lower ball joints and tie rod ends. (Installed at 176K miles)
    Daizen steering rack bushings.(Installed at 176K miles)
    New upper front control arms. (Installed at 178K miles)
    New OEM suspension brace.(Installed at 176K miles)
    Engine.
    JDM 2JZGTE with a single turbo kit.
    USDM camshafts.
    Polished valve covers, intake manifold, throttle body and upper water neck.
    Turbo: 57 mm turbo with .68 a/r turbine housing with a v-band downpipe.
    Turbo blanket.
    EMUSA 38 mm wastegate( Installed at 176K miles)
    Fuel dampener bypass AN nylon line.
    Walbro fuel pump.
    3" front mount Intercooler with 2.5" hot side and 3" cold side aluminum piping.
    Tial blow off valve.
    Custom vband 3" downpipe.
    Blitz Nur spec dual exhaust.
    Maintenance:
    New OEM Timing belt, aisin water pump with cams and crank seals. (178K Miles)
    Valve stem seals. (178k Miles)
    New radiator with slim fans and custom aluminum overflow tank.
    New rear rotors and ceramic pads.
    SOLD
    Pics
    Blitz exhaust, crack on rear bumper
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    May 2006
    Location
    South Florida
    Age
    41
    Posts
    274
    Interior
    Some wear on the front seat
    All gauges and warning lights work
    Engine bay
  4. #3
    SupraForums Member
    Join Date
    Feb 2010
    Location
    Southflorida
    Posts
    407
    I'm very interested please call me at 954-295-4927 thank you
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member romir123's Avatar
    Join Date
    Jun 2009
    Location
    Miami Fl.
    Posts
    490
    Bump for great sf member.
    Saw this car many times its in great shape. Glws
    ASE master tech L 1 advanced engine performance / Toyota master tech / Honda gold level tech
    Our supras, who art in the driveway, hallowed be thy name, thy speed has come, thy will never be done, on the road as it is on the mind, give us this day your daily beauty, and forgive us our speeding, as we forgive those who drive slow, and lead us not into incarceration, but deliver us from the five-o ....amen
    A beautiful Supra Prayer by: Kris Paczedlik
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. F/S 93 gs300 2jzgte
    By twincamturbo in forum Florida For Sale/Wanted
    Last Post: 01-02-2011, 10:06 PM
  2. 2jzgte in a gs300
    By GS300TT in forum MKIV (1993-1998)
    Last Post: 08-07-2005, 12:07 AM
  3. gs300 2jzgte swap
    By twin turbo GS in forum MKIV (1993-1998)
    Last Post: 08-06-2004, 12:10 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
