2jz engine block id
+ Reply to Thread
Results 1 to 3 of 3
Thread: 2jz engine block id
  1. #1
    Join Date
    Sep 2011
    Location
    Lemon Grove, CA
    Posts
    8
    2jz engine block id
    I'm shopping for a 2jzgte engine block an need to know if anyone on her knows what the various digits below the "2JZ" block identifier mean.
    I need a USDM block and not a JDM block and according to the state of california they can tell the that difference as well as build date based on that number. They MAY also be able to distinguish between N/A and turbo basedon those numbers.
    According to the toyota dealer, there are no vin numbers in the block id. If u look up the vin of a toyota car, however it will give you the block number. The downside if you cannot trace the car from the block.
    The following is what I do know:
    1. The 2jz n/a block lacks the turbo oil supply ports and oil squirters on the pistions
    2. The 2jz n/a head lacks the turbo cams, water neck location, cam sensors, port spacing, and port sizes of the turbo and has a 5m,6m,7m style distributor location.
    3.The jdm head lacks the egr cooler, 2 ports at rear of the head for egr, egr cooler mounting holes, egr ports at intake and exhaust sides of head, egr port and cams of the usdm motor.
    4.The items above are easily observable, how can the date, n/a vs turbo, us vs jdm block origin be identified or distinguished from another via the block id number.
    5.This info AFAIK is not provided to the dealers.
    6.The new blocks purchased from the dealer lack numbers at all, so that is a non starter.
    7.So far, all block numbers are of 7 digits.
    8.So far, all block start with a 0 or 1.
    Can anyone shed light on this?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    The Great Kruso Kruso's Avatar
    Join Date
    Mar 2002
    Location
    Sugar Land, TX
    Posts
    3,866
    Some Lexus 2JZ's are stamped with the Vin# on the side of the block, I had one on my previous SC300.
    1991 MKIII Toyota Supra 1JZ, the "official" FFIM MKIII- Officially stolen.
    1994 MKIV Toyota Supra Single T70, Fuel, MAP ECU, RPS 6 puck................Sold.
    1993 MKIV TT w/ 79k original miles APU
    2011 Toyota Tundra 5.7 Rock Warrior
    Click here to enlarge Originally Posted by Zach90Turbo Click here to enlarge
    When I put 7M in the search it only came up with blown head gasket threads.
    "There is so much good in the worst of us, And so much bad in the best of us. That it behooves all of us Not to talk about the rest of us."
  4. #3
    Join Date
    Sep 2011
    Location
    Lemon Grove, CA
    Posts
    8
    where on the block? and are you sure it was the vin?
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. 2jz engine block sleeves?
    By Horacio Ramos in forum MKIV Technical
    Last Post: 06-13-2005, 11:53 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
