Should I heat wrap my downpipe?
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 59
Thread: Should I heat wrap my downpipe?
  1. #1
    Join Date
    Oct 2009
    Location
    Anaheim, CA
    Posts
    37
    Just got my divorced down pipe couple days ago. Was wondering if I should heat wrap it. I just bought the heat wrap, but its pretty expensive themotech wrap with spray $75. I want some opinions and your inputs on this. Is it beneficial or is it overkill? Cars pretty much bone stock.
    1987 SUPRA 7MGTE HKS TURBO EXHAUST, BIC RECIRCULATED DDP, APEXI AIR INTAKE. ----->Sick of this ride <------
    1973 DATSUN 240Z (49% complete) 1JZ in progress
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SF Contributing Member 87supramario's Avatar
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,364
    Not unless your planning on wrapping it for the track then taking it off after. Or you dont drive in rainny or humid conditions and you park it indoors, in a sealed & heated garage.
    Recently I had to replace my aftermarket header because it was wrapped and because the wrap was collecting moisture then getting hot then collecting moisture over and over... It started to crackle. A hole was punctured and I tried to tac weld it shut but after hitting the shell of the weld off, the whole weld caved in lol.
    Wrapping your exaust will distroy even brand name tubing years later. This same thing happend to a Honda buddy of mine with his $1000+ DC sports header only two years later.
    Click here to enlarge
    Resurrection complete. Build thread-> http://www.supraforums.com/forum/sho...surrection-1JZ
  4. #3
    Question to suit. 220's Avatar
    Join Date
    Dec 2002
    Location
    Anywhere, USA
    Posts
    2,997
    I've never had a problem with wrap on my header, been over 2 years, daily driver.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,655
    I had my downpipe wrapped for 4 years and no issues....also wrapped my dumptube. There are alot cheaper options out there for wrap but I do like the paint for the wrap though.
    1994 Red/Black TT
    86K miles
    Roller...6 speed swap coming soon
  7. #5
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,364
    Mind you it wouldnt surprise me if the climate diffrence betwine Canada and south U.S. would make a diffrence in this case.
    Paint? What do you do spray the pipe before wrap?
  8. #6
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,655
    Quote Originally Posted by 87supramario View Post
    After
  9. #7
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,364
    So this way the wrap doesnt soak up the water... This sounds better. The wrap itself in my case tore appart like a dried out rag with ease. Previous owner probably never coated the wrap.
  10. #8
    Join Date
    Apr 2011
    Location
    Not Canada
    Age
    31
    Posts
    3,628
    Quote Originally Posted by HotSoup View Post
    Is there a special paint you use? Got any pics?
  11. #9
    Join Date
    Oct 2009
    Location
    Anaheim, CA
    Posts
    37
    Yeah the only reason I could think of wanting to wrap this downpipe up is because the downpipe sits close to the transmission and might produce more heat around that area :/. Yes or no? Can I go without it? or better just wrapping it now and not worry later?
  12. #10
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,655
    Quote Originally Posted by DegreE_v.2.0 View Post
    http://www.summitracing.com/parts/THE-12002/
  13. #11
    Join Date
    Apr 2011
    Location
    Not Canada
    Age
    31
    Posts
    3,628
    You can definitely go without it. It's not critical. Wrapping is just an option.
    I'll be wrapping mine down to about 10 inches or so.
  14. #12
    SupraForums Member destrux's Avatar
    Join Date
    May 2010
    Location
    PA
    Posts
    467
    I painted my pipes with VHT ceramic before I wrapped them and it does a good job at preventing them from rusting. I would stick with only wrapping stainless pipes though. Mild steel will corrode very quickly.
    87' w/ 1JZGTE, W58, Holset HY35W
  15. #13
    Join Date
    Oct 2009
    Location
    Anaheim, CA
    Posts
    37
    Quote Originally Posted by destrux View Post
    This downpipe already got some surface rust. I bought it from one of the guys at supramania. The deal was a steal. Came with all the options 2nd bung for wideband, flex section, rerouted wastegate. Only thing the previous didn't do was get a good coating on it to prevent rust.
  16. #14
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,655
    my reccomendation would be this:
    Blast or sand the rust off the downpipe
    paint with the paint I posted above
    wrap the pipe
    paint on top of the wrap with same paint
  17. #15
    MUDKIP FARMER OvenRude's Avatar
    Join Date
    Mar 2002
    Location
    Minneapolis MN
    Age
    31
    Posts
    3,138
    I would suggest ceramic coating over a heat wrap.
  18. #16
    Join Date
    Oct 2009
    Location
    Anaheim, CA
    Posts
    37
    wrap the pipe
    Your talking about this :
    This is the exact same kit I bought. Alright guess I am going to get started with sanding and paint this thing quick. I am trying to get this on today and take it for a spin. Thanks for the inputs.
  19. #17
    not a poopra anymore! suprajztwenty's Avatar
    Join Date
    Oct 2009
    Location
    Corinth TX
    Age
    30
    Posts
    1,095
    +1, this is the kit i have on my DP, i had more than plenty for mine and a buddies car. mine was 2nd and i had enough to do a 50% overlap from the top of the DP to the end of the mini highflow cat. nothing difference to note but i sure dont have any issues with rust here in tx.
    i only did mine because it was going to go to waste anyways. i had left over spray even after painting the wrap, so i did the underside of my turbo shield and it seemed to make a difference on the intake charge hose.
  20. #18
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,655
    The stainless zip ties are a pain in the ass to install, not to mention costly. I use stainless worm clamps from Lowes.
  21. #19
    Supra Tech Bmettie's Avatar
    Join Date
    Mar 2010
    Location
    Florida Brevard
    Age
    35
    Posts
    1,718
    Safety wire!!!!! At least 0.080" diameter
    Dont forget the pliers
    91 White Package Targa Turbo
  22. #20
    Join Date
    Oct 2009
    Location
    Anaheim, CA
    Posts
    37
    wrap the pipe
    So I took your advice and did all of the above. It turned out well, but I used 2 cans of that thing. The paint was very thin compared to your block paint that supports 2000F which has more can in the can. It barely covered the downpipe and the clamps were too small. I had to get some clamps from a local shop because the ones that came with the kit only covered 2 1/4 tops. So I total up the wrap kit to be 100 dollars (the kit $75, clamps 10.00, extra can of hi coat spray 10 and misc bolts and 02 bung 5.00. That paint is extremely thin, so it took a quite a few coats to make it look good. Everything turned out great I painted it, wrapped it, sprayed again for the seal and boom I let it dry last night outside. Unfortunately because of the unpredicatable F**Kn weather, we had a little minor rain/sprinkle. I was at class before I realized that I better get home quick and get it out of there. I got home took it in and it wasn't too bad. Wasn't soaking wet, but just to make sure I used a blow dryer at it for about 15 mins. Gonna wait a few more hours just to let it settle before I do the install.
  23. #21
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,655
    I dont understand why it took you two cans. I did my 5" downpipe,dumptube and exhaust housing, and redid my 5" when I sold it....a little goes a long way.
  24. #22
    Join Date
    Apr 2011
    Location
    Not Canada
    Age
    31
    Posts
    3,628
    Quote Originally Posted by s30gtte View Post
    pics?
  25. #23
    Join Date
    Oct 2009
    Location
    Anaheim, CA
    Posts
    37
    Maybe I am just trigger happy and use alot of paint :/. Either way it turned out good. I covered the downpipe and then I wrapped it, and sprayed over again with the wrap. It took about 1 1/2 cans.
  26. #24
    Join Date
    Apr 2011
    Location
    Not Canada
    Age
    31
    Posts
    3,628
    I like it.
  27. #25
    Join Date
    Oct 2011
    Location
    in my supra
    Posts
    279
    absolutely I would
    huge reduction in temps
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. DEi's Heat Wrap
    By ReI86 in forum Shops & Part Reviews
    Last Post: 02-22-2006, 04:06 PM
  2. Heat Wrap my downpipe
    By Ascari_2 in forum MKIV (1993-1998)
    Last Post: 12-29-2004, 05:37 PM
  3. Turbo wrap/heat shield.
    By Internexus in forum MKIV (1993-1998)
    Last Post: 10-01-2004, 01:20 PM
  4. heat wrap headers? or not?
    By Oni mkiv in forum Naturally Aspirated
    Last Post: 01-17-2004, 08:24 PM
  5. Turbo Heat Wrap Question
    By tntperformance in forum MKIV Technical
    Last Post: 08-13-2002, 09:40 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
