Interesting read at the bottom of page 5 (post # 75).
I wonder if they still have 1st gear thrust washer woes...
Can you use the R154 input shaft on the AR5?The input shaft is 1" longer according to the link the OP posted... you need to buy a special bellhousing spacer or swap input shafts for the shorter one.
The Jeep/Dodge AX15 5-speed, the Jeep NV3550 5-speed, the Jeep NV1500, the Toyota R150F & R151F, the 87-92 Toyota Supra Turbo R154, the Isuzu AR5 and the Pontiac Solstice\Saturn Sky\Chevy Colorado\ GMC Canyon MA5 5-speeds all share the same case to bellhousing bolt pattern (Large Pattern). As such there are a number of possibilities that can be had when a 5-speed is desired:
All of the large pattern transmissions:
#1. Novak Enterprises: Adapter plate for AX15 to GM 4-speed bellhousing. Connects all except NV3550 to same.
#2. 94-95 Dakota 2.5L bellhousing: Connects all to any K car based 2.2L-2.5L L4 in a RWD application.
#3. 96-00 Dakota 2.5L bellhousing: Connects all to any Jeep 2.5L L4. Because of it's GM 60 degree V6 inherited bolt pattern, also works with any Buick FWD V6 and supercharged V6, any Chevrolet 2.8/3.1/3.4 V6, any Cadillac 4.1/4.5/4.9 V8 and with a minor modification, any Olds Aurora DOHC V8 and Cadillac DOHC Northstar V8. Also bolts to any Isuzu 3.2\3.5 DOHC V6.
#4. 88-99 Jeep 4.0L L6 bellhousing: Connects all to any AMC 290/304/343/360/390/401 V8 and any 72 and later 232 L6 and 258 L6.
#5. 94-99 Dakota 3.9L V6 Bellhousing: Connects all to any 3.9L V6 and any 273/318/340/360 V8, Magnum 5.2\5.9 V8, 5.7L Hemi V8 and Jeep 2.8L CRD Turbo Diesel.
#6. 96-04 Toyota Tacoma 3.4L V6. Also works with Toyota 3.0L V6
#7. 86.5-92 Toyota Supra Turbo 7M-GTE. Also works with Toyota 5M-GE.
Also Not shown:
01-04 Jeep Liberty 3.7L V6 bellhousing: Connects all to any 3.7L V6 and 4.7L V8.
03-04 Jeep Liberty\TJ 2.4L bellhousing: Connects NV1500 to 2.4L SOHC\DOHC Neon\SRT-4\PT Cruiser L4 (See info at #11)
Isuzu Trooper 3.5 V6 AR5 bellhousing: Connects all to any Isuzu 3.2\3.5 V6
04-05 Chevy Colorado\ GMC Canyon MA5 bellhousing: Connects all to any Vortec 2800 L4, 3500 L5 and 4200 L6
06 Pontiac Solstice\ Saturn Sky MA5 bellhousing: Connects all to any Ecotec 2.4L
88-95 Toyota Landcruiser: 1L, 2L and 2L-T Turbo Diesel truck bellhousing connects to R series transmissions.
Aftermarket:
Advance Adapters: Bellhousing for AX15 to Chevrolet-Buick-Olds-Pontiac V8 and Buick V6. Connects all except NV3550 and Pre 1996 R150 and R151 to same. www.advanceadapters.com
Advance Adapters: Bellhousing for Pre 1996 R150 and R151 to Chevrolet-Buick-Olds-Pontiac V8 and Buick V6. www.advanceadapters.com
Advance Adapters: Bellhousing for NV3550 to Chevrolet-Buick-Olds-Pontiac V8 and Buick V6.
Advance Adapters: Adapter plate for AX15 to Ford bellhousing. Connects all except NV3550 to same.
Advance Adapters: Adapter plate for NV3550 to Ford bellhousing.
Swift Machine: Adapter plate for NV3550 to GM 4-speed bellhousing. www.swiftmachine.com
Suzuki Only Supply: Adapter plate to bolt R series to Suzuki 1.3\1.6. www.rock4xfabrication.com/ringr.htm
AR Engineering: Adapter plate to bolt Mopar Small Block V8 bellhousing to a Mopar 225 Slant Six. Can be used in conjunction with a Dakota V6 bell to bolt all of the long shaft tranismissions to the Slant Six. www.arengineering.com/
Jeep AX5, Toyota G52, G58, W55, W56, W57 and W58 5-speeds all share a common face pattern on the case (Small pattern). As such, any 88-99 Jeep 2.5L bellhousing (NOT Dakota) will bolt a Toyota W series transmission to a 60 degree GM bolt pattern.
All of the small pattern transmissions:
Input shafts lengths vary.
Pre 1995 R150\R151 = 6.5"
1996 up Toyota R series = 7.5"
AX15 = 7.875"
87-92 Turbo Supra R154 = 7.25"
AR5 = 8.2"
MA5 = 7.5"
NV3550 = 7.875"
NV1500 = 8.6"
AX5 = 7.5"
Toyota W series = 6.5"
Toyota G series = 6.5"
Advance Adapters makes an extra long pilot bearing when using a slightly shorter input shaft tranny with a bellhousing that had a longer one. Obviously you can't put the longer input shaft trans into a Toyota bell that had a shorter one. Unless a spacer is used or the input shaft is swapped.
The transmissons and bellhousings can be split up into two categories. SHORT SHAFT\SHORT BELL and LONG SHAFT\LONG BELL. They cannot be easily mixed without modifications.
All AX15's, AR5's, MA5's, NV3550's, R154's and Toyota R150's (built after 1996) are LONG SHAFT\LONG BELL. To use one of these in a SHORT SHAFT\SHORT BELL application requires a 1" spacer available from Dellow Automotive or Castlemaine Rod Shop in Australia. Of course, any bellhousing combo one can think of is also available from them...
www.dellowauto.com.au/catalogue/DellowAutomotive.pdf
www.rodshop.com.au/
ALL Toyota R150's and R151's built before 1996 are SHORT SHAFT\SHORT BELL. These CANNOT be used in a LONG SHAFT\LONG BELL application or with LONG SHAFT\LONG BELL adapter plates.
Example of a LONG SHAFT transmission hooked up to a SHORT BELL with a Dellow Automotive spacer
The Jeep AX5's 7.5" input shaft does not allow it to be used with the Toyota G and W series bellhousings unless a spacer is fabricated OR the input shaft is swapped between them. (Apparently the short 6.5" G and W series Toyota input shaft can be made to work in an AX5 case and vice versa). The one exception is shown below.
The Jeep NV1500 has the longest input shaft of the group at 8.6".
Trans First Second Third Fourth Fifth
AX15 - 3.83 2.33 1.44 1.00 0.79
AR5 - 3.753 2.26 1.37 1.00 0.729
MA5 - 3.753 2.26 1.37 1.00 0.729
R150 - 3.83 2.062 1.436 1.00 0.838
R151 - 4.31 3.32 1.52 1.00 0.83
R154 - 3.25 1.95 1.30 1.00 0.75
NV1500- 3.85 2.25 1.48 1.00 0.80
NV3550 - 4.01 2.32 1.40 1.00 0.78
Front bearing covers are interchangeable between the Toyota R series, AX15, MA5, and AR5. NV3550, AX5 and W series are not interchangeable. The 92 and earlier Jeep AX15 front cover is aluminum and takes a hydraulic throwout bearing. The 93 and later AX15 uses an external slave and clutch arm. It's cast iron. The Toyota front cover has a shorter nose of a smaller diameter and is also cast iron.
So... there's no shortage of parts for these gearboxes. Any good shop can rebuild them and they are still not that expensive.
