Used scotch bright to remove tint glue and scratched windows
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 33
Thread: Used scotch bright to remove tint glue and scratched windows
  1. #1
    SupraForums Member
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    342
    Took the old tints off and the glue stayed on.. Someone had the bright idea of using scotch bright and wd40. Now I got the glue off but I scratched the window.. Luckily I only attempted one.. What can I do to fix this before I retina it? I was looking at glass polishing kits
    Any local things I can pick up to get this polished out?
    Click here to enlarge
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member Kracin's Avatar
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    wut?
    so you used a scotch brite pad or someone else did?
    there are glass polishing kits, are you sure its the glass or did you just leave a small amount of residue with scratches on it? not too sure about a scotch brite pad scratching up glass.
    if it is indeed scratched, polishing kit for a DA polisher runs about 40
    Click here to enlargeClick here to enlarge
  4. #3
    Ex-hardtopper Boostrush's Avatar
    Join Date
    Nov 2005
    Location
    New Jersey
    Age
    40
    Posts
    1,920
    One thing I learned about polishing slight scratches in glass, was to use toothpaste. When I was much younger, I worked in woodworking; scratches in glass were common and this was the trick to polish out the scratches. I would try it in a small area and see if it works for you!
    Greg
    GJK Photography
    1993.5 APU Hardtop 6-speed (sold 9/7/12)
    2008 Acura TL-S Carbon Bronze Pearl
    PS3 Username - Suprahuman
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    Quote Originally Posted by Boostrush View Post
    won't work, toothpaste then and now are very different, glass as well as glass compounds. best bet is an actual glass polishing kit like diamondx
    people use toothpaste now for things like waterspot removal, not glass polishing
  7. #5
    SupraForums Member
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    342
    Thanks guys! Would the stuff they use to polish your headlights work?
  8. #6
    SupraForums Member
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    342
    Where can I get a kit locally? I'm trying to get this done tomorrow before I tint my windows Monday
  9. #7
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    Quote Originally Posted by BoostJunky287 View Post
    headlights are plastic, so no (headlight polish kits are for plastic that is).
  10. #8
    Join Date
    Sep 2003
    Location
    NE
    Posts
    4,813
    it will be local to you as soon as you get it delivered...
    http://www.autogeek.net/diglclsy.html
  11. #9
    SupraForums Member
    Join Date
    Nov 2010
    Location
    Hawaii
    Posts
    468
    if you have a steam cleaner use that and the tint will peel off with ease with no glue left behind. If you wanna remove the tint from the other windows.
    07 Tacoma DCSB TRD Sport w/TRD supercharger
    94 hardtop 6 Speed
  12. #10
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    3,938
    This stuff called De-solve it will remove all kind of glue. If that doesnt work, then laquer thinner it is.
    Al
    94TT Auto, 6466
    9.95@133.80 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    9.57@142.42 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    10.56@132.36 built motor, 28 psi, Sept 2000
  13. #11
    SupraForums Member
    Join Date
    Dec 2009
    Location
    fresno, ca
    Posts
    2,040
    Spray windex onto the glue and let it set for a like 5 minutes or so.
    Come back with a blade from a carpet knife and scrub the glue off.
    To get more grip with the blade since its kinda small, use a plier that has a locking mechanism.
    You won't scratch the glass if you just glide the blade across the window. I tried it and it works every time.
  14. #12
    SupraForums Member
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    342
    ok guys my concern isnt the glue on the windows and the tints is already peeled off my concern is my oem glass that on the car and its scratched so i want to polish it up before i retint it, my buddy owns a detail/tint shop so well mess with the glue there but for now i need to get the scuff of the glass cause it s really bothering the shit outta me..
    thanks again for all the input
  15. #13
    SupraForums Member
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    342
    also using a blade you can go so far because the side rear windows and the rear hatch window you have to use something else because youll scratch the perforated lining on the edge of the windows and heater lines on the back hatch
  16. #14
    SupraForums Member HotSoup's Avatar
    Join Date
    Feb 2002
    Location
    North Carolina
    Age
    38
    Posts
    9,655
    which window did you scratch?
    1994 Red/Black TT
    86K miles
    Roller...6 speed swap coming soon
  17. #15
    Function over form
    Join Date
    Oct 2005
    Location
    TX
    Posts
    2,465
    Quote Originally Posted by Kracin View Post
    what? you can use toothpaste for waterspot removal? i have some serious waterspots where the weather strip is under the hatch and haven't been able to get those off with anything. guess it won't hurt to try this.
    2JZ-GE | Turbonetics T66 | AEM
  18. #16
    SupraForums Member slither's Avatar
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    39
    Posts
    6,785
    Guys the damage has been done already. Get glass polish and the correct bonnet and hope for the best.
    Fwiw. I simply pull the tint off, spray with a lite coating of pure ammonia and come back a few mins later to get tint off.
    AboveFab(supra fabrication)
    Feel free to text me with any questions/tech/advice/info. Its quicker and more personal than pms and you are sure to get a quick response. 434-470-2700
  19. #17
    SupraForums Member
    Join Date
    Aug 2009
    Location
    Brooklyn
    Age
    31
    Posts
    376
    try calling or stoping by some glass shops
    I dont know where you live, i know one in Bk on 18ave and benson ave "SafeLight"
    post pone you tinting untill you get it fixed
    or just replace the glass 2732 Atlantic Ave Brooklyn, NY 11207
    (718) 827-7021 these guys usualy have everything they come and change it for you too
  20. #18
    SupraForums Member
    Join Date
    Jul 2002
    Location
    Tampa, FL
    Posts
    5,152
    Anytime I've removed tint, I used 409 or Windex (anything w/Ammonia)... dissolves the glue and no need for scraping/scratching. Definitely get/use the right scratch remover for the job or go to a pro, for the window that's already been damaged.
  21. #19
    SupraForums Member AllenO's Avatar
    Join Date
    Sep 2006
    Location
    Tennessee
    Posts
    10
    Check out Griots Garage. They sell some pretty good glass polish that will most likely do the trick. Of course you'll want to use a random action orbital with a felt pad for best results. I'd give that a try and if you can't get it yourself give safelite or one of the other glass repair companies a call for some help. Best of luck!
  22. #20
    SupraForums Member Idrv2yota's Avatar
    Join Date
    May 2009
    Location
    USA
    Posts
    299
    Try JC Whitney.com they sells glass polishing kit. Goo Gone does the trick to take off the glue residue after peeling off the tint film.
  23. #21
    SupraForums Member
    Join Date
    Apr 2011
    Location
    san diego
    Posts
    163
    Probably easier and cheaper to just replace the window. Do you have any pics of the damage?
    93.5 jdm 61mm pt powered alpine silver on HRE 540
    85 ae86 gts 530whp first ever k24 corolla
    86 ae86 gts daily
    71 te27
    69 ke10
    <3 TOYOTA
    www.jspfab.com
  24. #22
    Join Date
    Oct 2010
    Location
    Australia/USA
    Age
    28
    Posts
    5
    dam that sucks
  25. #23
    SupraForums Member
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    342
    Thanks guys really appreciate it, tinting the car now. My buddy days u won't see it once the tint is done. I told him what if I do and decide to polish out the window? He said hell redo the tiny for free. BTW You guys in the area that need any detailing tint or any other cosmetic interior work done go to Steve at Tintmax in bayside! Nicest guy and hell really take care of you! Tell him Emil with the supra sent you! Total win
  26. #24
    adammackintosh.net agm's Avatar
    Join Date
    Feb 2009
    Location
    West Coast Canada
    Posts
    5,782
    waterspot removal eh....... brb
    sounds like a nice guy
    -adam ส็็็็็็็็็็็็็็็็็็็
    701whp/517wtq pump/meth, revs to the freaking moon son (tuned by bill)
    rps header, hks t51r kai, rps triple carbon, open dump, 4" exhaust, aem v2, gsc s2 cams, ported head, dualsprings, titanium retainers, shimless buckets, +1mm valves, 8500 rpm rev limit.
    sample vid: http://www.youtube.com/watch?v=hHeSk4StvpM
  27. #25
    SupraForums Member
    Join Date
    Nov 2008
    Location
    NYC
    Posts
    342
    Got the glue off, ended up using thinner and steel wool. The drivers window was the one that had damage it really annoying me because u can still see the scratches.. Gonna call safe light tomorrow since I just called them and they are closed today cause they didnt pick up. Anyone have a extra window lol? The other thing is that the windows are Von etched and I would like to keep the original..
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. window tint glue residue removal
    By Ranger498 in forum Mobile Electronics (I.C.E.) and Lighting
    Last Post: 01-10-2009, 07:50 PM
  2. glue for windows?
    By Ravan17 in forum Elmhurst Toyota Scion
    Last Post: 04-28-2008, 10:38 AM
  3. How to remove glue off gauge cluster?
    By whitelex03 in forum MKIV (1993-1998)
    Last Post: 12-10-2007, 01:51 PM
  4. scratched windows
    By a70 in forum MKIII (1986.5-1992)
    Last Post: 05-14-2003, 11:48 AM
  5. remove glue from headlights
    By Anarchy in forum MKIV (1993-1998)
    Last Post: 01-29-2003, 09:13 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
