Can i buy an aftermarket 7mgte wiring harness ?
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: Can i buy an aftermarket 7mgte wiring harness ?
  1. #1
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    i own a 89 supra 7mge. I just bought a 7mgte engine. I need a wiring harness but idk were to buy one. Ive tryed the for sale section and ebay but they all sell to fast.
    89 Supra Targa top 3.0
    Click here to enlarge
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Addict raysupra's Avatar
    Join Date
    Jan 2010
    Location
    NC again
    Age
    28
    Posts
    1,116
    I can build you one. so can drtweek
    -Parker-
    1985 MKII:-2jz/R154/AEM EMS2
  4. #3
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    how much would u charge
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Con Clavi Con Dio mattsplat72's Avatar
    Join Date
    Mar 2006
    Location
    Mt Vernon WA
    Posts
    1,263
    Dr Tweak quoted me 700 for a 1j to 7m harness
    Don't need cheap plastic trinkets to tell me my car is red.
  7. #5
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    no way ill make my own or wait till i find one.
  8. #6
    Moderator/Troll Slayer SupraTrey's Avatar
    Join Date
    Mar 2002
    Location
    Midwest
    Age
    38
    Posts
    6,151
    Quote Originally Posted by xMJTx Turner xMJTx View Post
    Change your damn signature. That is the most annoying fucking thing I have seen..... ever.
  9. #7
    SupraForums Member 57trimMKIII's Avatar
    Join Date
    Jun 2010
    Location
    Roanoke, TX
    Posts
    2,418
    Try PM'img sideways, he might be able to help you.
    http://www.supraforums.com/forum/mem...93655-sideways
    By the way... "you gotta pay to play" with these cars...
  10. #8
    Join Date
    Jan 2010
    Location
    NC again
    Age
    28
    Posts
    1,116
    Depends what you want done to the harness.... if you just want GTE plugs ... if you sent a harness its like 300$.. pretty simple.. and i'd send everything back.
  11. #9
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    whats the difference between the ge and the gte wiring harness jw
  12. #10
    Just some newb. funky_monkey58's Avatar
    Join Date
    Aug 2006
    Location
    st cloud mn
    Age
    29
    Posts
    1,327
    Surprisingly lots of things, everything with the ignition, and the afm wiring, and I think the gte has 2 knock sensors vs 1 not 100%
    Slowest supra in the midwest.
  13. #11
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    ok thanks so i need a 88 wiring harness and ecu right ? the enignes a 88 and my cars a 89.
  14. #12
    SF Contributing Member 87supramario's Avatar
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,374
    I may be able to have plugs for you soon. I'm waiting for my adapted harness to arrive and it comes with all the GTE grey plugs you need. I have no use for the grey plugs because I need the yellow plugs. Once I get the harness, I'll ask you if you still need em.
    Does your new 7mgte come with an ECU? Is your car manual or auto?
    Resurrection complete. Build thread-> http://www.supraforums.com/forum/sho...surrection-1JZ
  15. #13
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    it will be automatic with the 7mgte and theres no ecu. so what ever harness i get i will find the matching ecu
  16. #14
    SupraForums Member NoefearSupra's Avatar
    Join Date
    Apr 2011
    Location
    Ohio
    Posts
    467
    the harness depends on your ecu not your motor. atleast im pretty positive on that statement. Get an 87 88 ecu.. seems to be the easiest to find and get the same harness for those years. But you could get an 89+ ecu and get an 89+ harness as well. your choice.
    1986.5 N/A 5-Speed Hardtop 3.0 - SOLD
    1987 Turbo 5-Speed Targa Top 3.0 - SOLD
    1990 Turbo 5-Speed Targa Top 3.0 - SOLD
    1990 Turbo Auto Targa Top - SOLD
    2001 Audi TT APR Stage 3 - 27 psi - 368awhp/342torque (bigger and better things soon to come)
  17. #15
    SupraForums Member 91SUPRA-B's Avatar
    Join Date
    Oct 2002
    Location
    near Waco, TX
    Age
    37
    Posts
    1,433
    Quote Originally Posted by funky_monkey58 View Post
    Yes GTE has 2 knock sensors and GE only has one.
    TX2K9 MKI-MKIII Street Class Champion
    TX2K10 MKI-MKIII Modified Class Champion
    PM me for MkI - MkIII parts
    91T targa 5spd (Road Racing at TX2K since 2007, and DFW May meet '09)
    90 N/A targa 5spd (my first MK3)(sold to bmk3)
    89 N/A -> turbo swap minus engine and tranny
    87 N/A 5spd (beater, needs engine)
    87T targa 5spd (parts car/frame damage)
    87 N/A (parts car, no engine, tranny, or a straight panel on it)
    87 N/A targa auto (FOR SALE has new HG and timing belt)
  18. #16
    Supra Moderator Zumtizzle's Avatar
    Join Date
    May 2006
    Location
    NorCal
    Posts
    4,595
    Quote Originally Posted by raysupra View Post
    What exactly would you do for 300? Sounds like a steal but step by step?
    Welcome to my nightmare!
  19. #17
    SupraForums Member SPOOLN30's Avatar
    Join Date
    Apr 2006
    Location
    MILK-TOWN, WI
    Age
    36
    Posts
    747
    The problem with buying used 23 yr old wiring is well their 23years old. Most likely you will have brittle/broken wires and same with the connectors from the heat and oils that leak on to it. I've had some harnesses that looked ok but once I started moving the harness around all I heard was crunching and cracking. You'll probably have to chase broken wires. So spending $700 for a new harness is well worth it IMHO. Heck Dr Tweak did a couple of my friends and also my own harness. He does really good work.
  20. #18
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    ok thanks guys. whats the difference between the gray and yellow plugs?
  21. #19
    SupraForums Member Jostar's Avatar
    Join Date
    Aug 2004
    Location
    Chicago IL
    Age
    36
    Posts
    3,230
    I would pay the 700 bux & not deal with the electrical gremlins that may plague you.. yeah 700 bux is a ton of money but the headaches that you are gonna avoid are worth it..
    Getting out Boosted by Turbobozzer... for now...
  22. #20
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    im just going to buy a old set and get the plug ends and make my own. i think if not ill just use the wiring harness i bought to look at.
  23. #21
    Join Date
    Jan 2010
    Location
    NC again
    Age
    28
    Posts
    1,116
    Quote Originally Posted by Zumtizzle View Post
    300 is very genaric... could be more expensive or cheaper... just depends what i get... If said customer has a 7mge/auto tranny... and wants a gte/auto harness and provides the materials..I would depin sensors from one harness and rebuild wires as needed... reloom solder shrink wrap...I'd probably do that for 400$... not too bad.. might take 7 hours :-) customer pays shipping yadda yadda... I do wiring.. its easy and fun.. and 400$ is a reasonable price for me and a SF memeber...
    I haven't really extended my services to anyone on here.. but I would like to.
    I can estimate a job's cost just by knowing what needs to be done.. pretty straight forward.
  24. #22
    Join Date
    Jan 2012
    Location
    Stugis MI
    Posts
    52
    if i have a 7mge with auto trans. will the ecu work with the 7mgte engine
  25. #23
    Join Date
    Mar 2006
    Location
    Mt Vernon WA
    Posts
    1,263
    No, stop being lazy and reSEARCH. All of this has been covered Ad Nauseum.
  26. #24
    Join Date
    Apr 2006
    Location
    MILK-TOWN, WI
    Age
    36
    Posts
    747
    ^ LOL.
    No you can't use a non-turbo ECU.
  27. #25
    THE LAST NA SupraCooled's Avatar
    Join Date
    Mar 2009
    Location
    Bohemian Grove, CALIF
    Posts
    1,228
    anything is possible......we could possible go to the moon in the next 60 years,just like we did 50 years ago
    distributor powers turbo, distributor less 7mge, it canbe done if it has not already....but just swap electronic wiring it is easier fabrication
    WTB ASAP: ABS COWL/DASH harness, glove box striker, wheel bearing dust cover FL.
    WTS: NEW AND USED SPEEDO CABLE, 83710-14700, 89+ 7MGE INJECTORS, AND RADIATOR SHROUD
    WTB: 340E TRANS, 3:73+ DIFF, NA ENGINE HARNESS, AFTERMARKET DOWNPIPE AND EXHAUST, WIPER SPRAY NOZZLE, BRAKE CYLINDER, FLOOR MATS, HEATER VALVE, GAS TANK LID, HOOD STRUTS, REAR STRUTS, TRUNK STRUTS, TRUNK SEAL, OEM CD PLAYER, MAROON INTERIOR PARTS, STEERING WHEEL, WHITE TARGA TOP, WHITE HOOD, ANTENNA AND MOTOR, DRIVERS DOOR LOCK, DRIVERS WINDOW SWITCH, KEY IGNITION SHROUD, GLOVEBOX SHROUD, FUEL SENDER GAUGE, BLOWER MOTOR, THERMOSTAT HOUSING, AND A GOD DAMN WORKING CUP HOLDER.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. i need a 7mgte wiring harness
    By lunar0utlaw in forum MKIII (1986.5-1992)
    Last Post: 07-02-2009, 12:42 PM
  2. 7MGTE Wiring Harness
    By VroomHiss in forum MVP Motorsports, Inc.
    Last Post: 12-08-2008, 11:57 AM
  3. Aftermarket Headunit Wiring Harness
    By ThomsonCharm in forum Naturally Aspirated
    Last Post: 06-05-2002, 12:53 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
