+ Reply to Thread
Results 1 to 2 of 2
Thread: Injector modification
  1. #1
    SupraForums Member wbrinsonw2's Avatar
    Join Date
    May 2004
    Location
    Naples, FL
    Posts
    266
    After looking into a economical solution to fuel injectors I've come across something interesting in regards to fuel injector modification. (not flow modification)
    Below you have a standard Siemens DEKA 625cc injector that fits a "domestic" style 14mm rail
    and here you have the same injector but has been modified to fit an 11mm rail.
    Has anyone attempted this modification before or have any insight on it. Doesn't appear to be to difficult but you never know.
  2. #2
    SupraForums Member Juhanis's Avatar
    Join Date
    Sep 2003
    Location
    Los Ghettos, California
    Age
    31
    Posts
    2,770
    i have a friend with a gte powered sc300 that's running modified 14mm injectors. he hasnt had an issue with it at all. i'm sure i could do this to 14mm injectors on my lathe.
    Sisu Research & Development, Specializing in Expandable Fuel Injector Sales/Production.
    I'm currently not taking any new orders. I do plan to still build injectors in the future.
    Feel free to pm me if you have any questions.
    stable:
    90 supra, bw s366, 272 cams, srd 1400cc, e85, front/rear bbk, 2jz, megasquirt diypnp
    91 eagle talon tsi, bw s258, forged 6 bolt, built close ratio trans, PTT twin disc, evo brakes
+ Reply to Thread
Similar Threads
  1. 7MGTE modification?
    By planemos in forum MKIII (1986.5-1992)
    Last Post: 02-22-2012, 04:56 PM
  2. Intake Manifold Modification Top Feed Injector Swap
    By ophidicus in forum MKIV (1993-1998)
    Last Post: 09-10-2009, 10:35 PM
  3. Rim modification
    By Shawn R in forum MKIV (1993-1998)
    Last Post: 09-30-2006, 11:09 PM
  4. Crankshaft modification
    By WongSetupSupra in forum MKIII Technical
    Last Post: 09-25-2004, 09:16 PM
  5. Modification Order
    By i3oca in forum Shops & Part Reviews
    Last Post: 04-26-2002, 01:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
