+ Reply to Thread
Results 1 to 21 of 21
Thread: 7mgte airflow issues
  1. #1
    SupraForums Member supra87maniac's Avatar
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    Lately my car has been overheating at 60 mph+, so instead of starting a BHG thread I had it checked out. Compression is fine, coolant flow is optimal so the diagnosis was NO BHG. But he informed me that I have an airflow issue. Not enough air is passing through the radiator. It's a huge aftermarket radiator with OEM shroud and clutch fan. I have my intercooler tilted a bit and its fairly thick, but I have seen V-mount set ups so i figured this wouldn't cause this kind of issue. Has anyone else had airflow issues like this? Any suggestions to fixing this would be great and of course tilting the intercooler to maximize airflow is first on my list.
  2. #2
    Junior Member
    Join Date
    Mar 2009
    Location
    Seattle
    Posts
    140
    What brand radiator is it? Have you tried a coolant flush?
  3. #3
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    Godspeed radiator, it's been flushed.
  4. #4
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    I just read up on radiators. It seems that larger radiators aren't very good at drawing air through them and they just act like a huge heat soak (the radiator i have is huge). I live in a hot climate, what radiator do you think is the best for keeping these hot cars cool. Also, fans. OEM clutch fan or electric fans? I was leaning towards a fluidyne radiator with flex-a-lite fans. Or maybe just going back to an OEM radiator.
  5. #5
    Moderator/Troll Slayer SupraTrey's Avatar
    Join Date
    Mar 2002
    Location
    Midwest
    Age
    34
    Posts
    6,040
    Noone has a bigger IC and Radiator setup than I and I have no issues. Replace your waterpump, get a new fluid cuppler (fan clutch) and install some E-Fans...... I bet your problem will go away.
  6. #6
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    I will just buy some electric fans and give you guys an update, it has a new waterpump 200 miles ago and the clutch fan seems fully operational. So you guys don't think my IC mounted at an angle has anything to do with it? I tried looking around and couldn't find anyone having restricted airflow problems that caused their vehicles to overheat. Also, do you suggest pusher or puller fans? The puller fans I plan on getting will have me getting rid of my OEM shroud because I plan on buying the flex-a-lite fans with the built in shroud. Suggestions?
  7. #7
    Slowly but Surely BlackWidTan's Avatar
    Join Date
    Aug 2003
    Location
    Brooklyn, NY
    Age
    26
    Posts
    1,402
    Air in the cooling system?
  8. #8
    ///M3 > MKIII 1QwikMK3's Avatar
    Join Date
    Oct 2001
    Location
    Rons front yard :-(
    Age
    33
    Posts
    2,296
    At 60mph the e fans are more of an air flow restriction than anything else. You are pushing way more air through the radiator than the fans can draw. Do you still have the A/C condenser on the car? If so there could be some build up of stuff between it and the radiator.
    So when you say overheating, do you mean the gauge is running near or into the red? or is it just creeping up higher than usual? I see you are in Texas, I lived in AZ for a couple years and my car generally ran hotter than in WA.(over halfway on the temp gauge) I ended up bypassing the thermostatic switch for the aux. fans so they'd come on with the ignition on, I also ran a 160 degree t-stat and after that I never had any issues, temp was always where it was before. I also vented the hood a little by spacing it up on the hinges, but I wouldn't really recommend doing that.
    The IC could be playing a part, air flow might be slowed a little bit through it with it tilted. Hard to say though, you'd just have to try mounting it straight up if you can.
  9. #9
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    Well, just an update. Stilll waiting on my new fans. I will update if it worked. Im gonna run them on a toggle switch through some relays. The temp just stays a quarter before max, doesn't peg out.
  10. #10
    Make My Day supranasty's Avatar
    Join Date
    Sep 2004
    Location
    Queens,NY
    Posts
    421
    Stock 10 blade fan is fine .
    Try a water pump,fan clutch,thermostat,and radiator cap. Then jack the front of your car and burp the system with the radiator cap off.
    High horsepower cars do it on stock fans...
    Electric fans are great to save space when the stocker doesn't fit with the shroud.
    89 5spd ct26 12.21 @112
  11. #11
    Where to now? SMP142's Avatar
    Join Date
    Mar 2006
    Location
    Tacoma, WA.
    Posts
    693
    sounds like air in the system maybe. i would burp it again. i did remove the hood seal along the firewall and also shimmed the hindges to allow a gap for air flow. deff made the engine bay cooler.
  12. #12
    Join Date
    Oct 2001
    Location
    Rons front yard :-(
    Age
    33
    Posts
    2,296
    Quote Originally Posted by supra87maniac View Post
    Right on, I'd toggle the auxillary fans too.
  13. #13
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    I also have no heat shields on my aftermarket turbo, would it be a world of difference to get a turbo blanket? And horsepowerfreaks is being painfully slow about shipping my fans so it will be a while.
  14. #14
    yup, reefed it
    Join Date
    May 2009
    Location
    Seattle
    Posts
    609
    Wish I saved a pic of the hood some guy cut vent holes in the underside of at the rear, but they weren't visible from outside, nice and stealth. Think it was in a build thread...
    Checked your timing?
  15. #15
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    Ok, put the car at an incline and bubbles came out like no tommorow. New problem though, after I bleed the system and the coolant level stays good for five minuted straight I turn the car off and the coolant starts overflowing and bubbling out of the radiator. How could air be getting in there after shutting it off?
  16. #16
    Join Date
    Sep 2004
    Location
    Queens,NY
    Posts
    421
    When you finish burping the system top off coolent and put the radiator cap on.
    A Hot engine with no radiator cap will boil over when you shut it off always.
  17. #17
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    Forgot about this thread. It was a leaky heater core. Smelled coolant in the car when the heater was on and found the carpet to be wet. It was also the reason the cooling system kept getting air in it. GT auto of Vidor TX is full of idiot mechanics who couldn't diagnose a simple problem that I had to figure out on my own. Their diagnosis sent me on the wrong path, looking for problems that didn't exist. Lesson learned.
  18. #18
    SupraForums Member
    Join Date
    Jan 2009
    Location
    Kootenays, BC, Canada
    Age
    26
    Posts
    1,174
    Nobody wants to fix a leaking heater core because you always must tear out the whole dashboard
  19. #19
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    After I changed the heater core it still overheats, it was leaking though so at least I got it taken care of. So I aked my good friend who has been a mechanic for 35 years and he told me to check my catalytic converters. I took my exhaust off and the catalytic converter is clogged pretty damn badly (the one at the downpipe). I was also looking around at other people having problems with their cats and all the symptoms match. I didn't check my newer seamless cat, but after reading about buying a cheap cat and how it can collapse under boost I am going to check it out too. I will update when I actually have the money to get a new exhaust. Im thinking about the driftmotion downpipe and exhaust.
  20. #20
    Join Date
    Dec 2009
    Location
    Texas
    Posts
    482
    Fml!
  21. #21
    475RWHP 449TQ and climing QWIKSTRIKE's Avatar
    Join Date
    Nov 2002
    Location
    not there yet
    Age
    52
    Posts
    5,405
    Quote Originally Posted by SupraTrey View Post
    I don't know about that Trey I think I am right up there with you. 12x24x4 IC and a CSF 3" Aluminum radiator.
+ Reply to Thread
Similar Threads
  1. 2jz swap issues - airflow signal
    By outrider in forum 1JZ/2JZ Swap
    Last Post: 03-30-2010, 06:28 AM
  2. 7mgte supra issues
    By Skee1234 in forum MKIII (1986.5-1992)
    Last Post: 07-16-2009, 08:10 AM
  3. Many issues need help..... 7mge to 7mgte
    By 1bad89supra in forum MKIII (1986.5-1992)
    Last Post: 01-11-2009, 10:00 AM
  4. Help! rebuild 7mgte Issues?!?
    By Woodlockashell in forum MKIII (1986.5-1992)
    Last Post: 10-03-2008, 10:01 AM
  5. 7mgte issues
    By idrivetoys in forum MKIII Technical
    Last Post: 02-10-2007, 03:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
