+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 75
Thread: AEM's NEW Wideband Failsafe Gauge!!! MVP Motorsports
  1. #1
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    The Wideband FAILSAFE Gauge provides the ability to accurately tune AFR, while actively protecting your engine by constantly monitoring AFR curves and activating a user-defined failsafe strategy if it runs lean.
    The Wideband FAILSAFE Gauge is a Universal Exhaust Gas Oxygen (UEGO—“you-way-go”) controller with an internal boost sensor, an internal data logger and a full color Organic Light Emitting Diode (OLED) display. It includes technology to activate a failsafe strategy in the event AFR falls outside of a user-defined operating window. If the AFR falls outside of the set operating window, the Wideband FAILSAFE Gauge triggers a user defined output function that can save an engine from catastrophic damage.
    WHY YOU WANT ONE
    This product is a must have for all tuned performance engines, either forced induction or naturally aspirated, fuel injected or carbureted. Any high performance vehicle owners who want a highly accurate AFR tuning tool with logging and a protection strategy that can save an engine from catastrophic failure will want this FAILSAFE device.
    WHAT IT DOES
    After the engine is tuned and a safe operating window of AFR is established, the Wideband FAILSAFE Gauge continually monitors AFR and boost or vacuum to make sure that AFR does not fall out of the defined operating window at a given boost or vacuum level. If the Wideband Failsafe detects an out of range AFR reading, the gauge triggers a low side output (ground signal with a 1.5 amp draw max) that can save your engine from catastrophic damage.
    Use the gauge’s intuitive software to configure the low side output, create a user-adjustable time delay strategy to prevent false alarms, and customize the gauge lighting to flash and alert the driver if an alarm is triggered.
    Use the gauge’s intuitive software to configure the low side output and create a user-adjustable time delay strategy to prevent false alarms.
    AEMdata On-Board Data Logging AFR Plot.
    Use the Auto-Set Limits Feature to speed the set up process.
    Intuitive Gauge Configuration Tool.
    PM OR POST UP FOR SUPRAFORUMS PRICING!!!!
    Regards,
    Robert
  2. #2
    SupraForums Member
    Join Date
    Sep 2011
    Location
    Virginia
    Posts
    356
    I am liking the sound of the new UEGO....aem digital gauges are what I am slowly collecting for my car and have been wanting the UEGO and am glad I held off of buying the previous version now that this is out!!!
    '94 6speed MKIV FSR Street Fighter 6266
  3. #3
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    Shoot me over a PM with your address for a personal quote!
    Regards,
    Robert
  4. #4
    SupraForums Member
    Join Date
    Sep 2010
    Location
    somerset ,ma
    Posts
    1,988
    Is this a complete replacement for the AEM EUGO wideband including sensor and gauge and everything, or is this something you would buy in addition to your existing wideband?
    1993.5 Ren Red TT 6spd targa
    PTE6766 on RPS manifold , AEM V1, Tuned by Alex @ GSD
  5. #5
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    Direct from the AEM site:
    WHAT IT INCLUDES
    The 52mm (2-1/16”) Wideband FAILSAFE Gauge includes a Bosch 4.2LSU AFR wideband sensor for monitoring and feedback of AFR and an on-board boost sensor to read vacuum or boost pressures up to 29 PSIG. Both boost and AFR can be displayed in real time on the gauge’s face using the full color OLED screen and 24 three-color sweeping LEDs. The gauge includes a low side output for triggering a failsafe strategy in the event AFR falls outside of the operating window (example strategies below), and an RPM input to log RPM for tuning purposes.
    Regards,
    Robert
  6. #6
    Engmaineer kamiraa's Avatar
    Join Date
    Dec 2007
    Location
    Houston / Chicago
    Posts
    2,276
    Quote Originally Posted by Robert@MVP View Post
    WHAT IT INCLUDES
    Regards,
    Robert
    ability yet to run a NTK Wideband sensor yet? Something race fuel friendly instead of the bosch?
    Looks awesome from what you posted. Pretty impressive setup.
  7. #7
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    No NTK sensor as of yet. I personally run an Analog UEGO on my vehicle and have put 6 full tanks of race fuel(C16) through it and the sensor is still working fine. Even the NTK sensor will eventually fail due to race fuel it will just last much longer.
    Replacement AEM Bosch Sensor - $79
    Replacement NTK Sensor - $215
    Typically speaking the NTK sensor will last about 3 times longer running race gas. So regardless you will still end up spending the same amount of money in the long run to replace sensors. The NTK is just more convenient as you don't have to replace it as often.
    Regards,
    Robert
  8. #8
    Boost Addicted. 4wd-eclipse's Avatar
    Join Date
    Apr 2008
    Location
    Muscat - OMAN
    Posts
    1,009
    Robert would you please PM me the price?
    MK
    *95 JDM Supra TT 6-Speed Hardtops .. Stock block/head, 6766 BB, HKS twin gates mani, 2 Tial MVS gates, HKS F-Con V Pro, AFK, RLTC, SafeGuard KC, HKS 264s, GReddy 3 Row, ID1000cc, Weldon, KB BAP, HKS Drager with 3.5" exhaust, Volk TE37, GReddy Big Brakes, ...
  9. #9
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    Sure thing, headed your way now!!
    Regards,
    Robert
  10. #10
    Super Moderator Letsride's Avatar
    Join Date
    Apr 2003
    Location
    NC
    Posts
    680
    Same for me Robert......thanks!
    "You know what? This will decimate all,
    after, you put about fifteen grand in it or more.
    If we have to, overnight parts from Japan.!!"
  11. #11
    SupraForums Member
    Join Date
    Jan 2005
    Location
    Staten Island,NY
    Posts
    282
    Robert,
    Please PM me a quote shipped to 10301.
  12. #12
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    PM's sent!
    Regards,
    Robert
  13. #13
    SupraForums Member rex03's Avatar
    Join Date
    Mar 2002
    Location
    San Antonio, Texas
    Age
    40
    Posts
    1,909
    Shipped to 78250 please. Thanks!
    'good friend will help you move, a great friend will help you move a body.'
    www.myspace.com/rex03
    ~1994 Black Toyota Supra 6-speed TT {SOLD}
    ~1993.5 Anthracite Toyota Supra Auto Turbo {SOLD}
    ~1997 Ren Red Toyota Supra TH-400 Turbo
  14. #14
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    PM's sent/replied!
    Regards,
    Robert
  15. #15
    Junior Member
    Join Date
    Feb 2008
    Location
    Ireland
    Posts
    140
    Does this wire into the stock ecu or do you need an aem ecu to make use of the fail safe feature?
    Carlo AKA Jellybean
    TRD Technocraft Japan built TRD3000GT No.26
  16. #16
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    The gauge comes with a USB cable that runs from gauge to laptop for viewing purposes. A standalone EMS is not necessary to make use of the Fail Safe Feature.
    Regards,
    Robert
  17. #17
    Start of a new term Smart Ass's Avatar
    Join Date
    Jan 2004
    Location
    SNORE-Cal cuz its boring up here
    Posts
    3,604
    Shipped price to San Francisco 94118 please
  18. #18
    SupraForums Member
    Join Date
    Oct 2010
    Location
    Santa Cruz, CA
    Posts
    266
    quote to 95060 please
  19. #19
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    PM's sent.
    Robert
  20. #20
    SupraForums Member LeeC's Avatar
    Join Date
    Dec 2006
    Location
    Baltimore, MD
    Posts
    983
    price to 21221 please
    93.5 Anthracite 6spd - s372r, Stock Motor w/ GSC s2 - 850 on E
    Quote Originally Posted by White Supra View Post
    So........ when you're sitting at a light with some cute big titty chick in the passenger seat and some Ls1 is revving next to you, what do you say? "Honey, If we were moving I'd really show him what's up?"
  21. #21
    2JZ S13 Flicktitty's Avatar
    Join Date
    Jan 2005
    Location
    Kicking Xtoefields ass in Bowling.
    Posts
    2,064
    just curious on the price. 53051
    1989 Nissan 240sx 19,000 Original miles | 2JZ-GTE | PT6266 | Titan 3500 Stall | FIC 750s | AEM EMS V2 | Sound Performance Tuned.
    WTB: 1997 - 2001 Lexus GS300/GS400/GS430
  22. #22
    SupraForums Member GRIM_MKIV's Avatar
    Join Date
    Feb 2007
    Location
    Earth
    Posts
    507
    I'm interested as well
    Robert, please PM the price shipped to 19720
  23. #23
    SupraForums Member PedoBear's Avatar
    Join Date
    Aug 2009
    Location
    Fremont
    Posts
    2,337
    price to 94560
    Tuned by: LS Fabrication
  24. #24
    SupraForums Member Linus's Avatar
    Join Date
    Nov 2008
    Location
    Sweden
    Posts
    406
    PM price, shipping to Sweden, please.
  25. #25
    MVP Motorsports
    Join Date
    Jan 2004
    Location
    Bridgeport
    Age
    26
    Posts
    1,653
    PM's sent!
    Regards,
    Robert
+ Reply to Thread
Similar Threads
  1. NEW PRODUCT!! AEM AQ-1 Data Logger at MVP Motorsports!!
    By Robert@MVP in forum MVP Motorsports, Inc.
    Last Post: 05-25-2011, 06:43 PM
  2. NEW Innovate Motorsports Wideband Gauge!! MVP Motorsports
    Last Post: 12-05-2010, 03:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
