+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 42 of 42
Thread: failed smog with RT DP...
  1. #26
    SupraForums Member
    Join Date
    Dec 2006
    Location
    Hollywood, California
    Posts
    107
    Quote Originally Posted by Supraman16 View Post
    Likely cause is that your cats cooled down significantly during the wait. Try and find a place where you don't have to wait so long...Darshana S..
    Try this ^^. Go early in the morning or something, but run it hot before u start the test.
    95' Supra TT 87k/miles (garage queen)
    89' Camry V6 90k/miles (daily)
    93' Camry V6 250k/miles (junked)
  2. #27
    EchoDeDupra Supradedupra's Avatar
    Join Date
    Oct 2003
    Location
    Tallahassee/Jacksonville/SFL
    Age
    26
    Posts
    4,100
    Acetone in the tank
    It's not what you have; it's what you know.
    Quote Originally Posted by exvelocity View Post
    Actually this car did catch fire at my shop,at that time it had more leaks than a torn off roof in a hurricane
  3. #28
    SupraForums Member
    Join Date
    Nov 2004
    Location
    sacramento
    Posts
    468
    Final update: passed with flying colors! Granted my car is legal and all, it still failed last time. All I did was drive hard with OD off on the freeway and went straight to the station after. My HC today was 57/84 and 23/49. Even better than two years ago. Hope this thread helps someone in the future.
  4. #29
    Junior Member
    Join Date
    Apr 2012
    Location
    currently: CA
    Posts
    125
    whats smog? LOL
  5. #30
    SupraForums Member
    Join Date
    Jun 2001
    Posts
    693
    Quote Originally Posted by shenofjo View Post
    Thanks for the update! We (Californians) really need to discuss and share this knid of information more often. There's no reason why these cars shouldn't pass without special procedures or tricks. Of course with added items such as cams or DP it takes a little more finese. I would like to see the changes on your CO's an NO's, could you post your other passing numbers?
    Your HC's are still somewhat high although granted you did pass. Maybe try wrapping the D/P for next time. The DP is a bare pipe and a larger diameter therefore the exhaust cools at a much faster rate. The R/T cat also has no heat shield to retain it's heat.
    passing is such a wonderful feeling!
    Choritsu-shi
  6. #31
    SupraForums Member
    Join Date
    Nov 2004
    Location
    sacramento
    Posts
    468
    Passing IS a great feeling. its amazing how something as simple as smog can get stressful...
    My final test results:
    15mph: CO2 15.1% O2 0% HC 57/84 CO 0.08/.49 NO 20/484
    25mph: CO2 15.1% O2 0% HC 23/49 CO 0.03/.46 NO 22/498
    What could be causing my heightened HC? and what type of heat wrap would you suggest for the RT dp?
  7. #32
    SupraForums Member
    Join Date
    Jun 2001
    Posts
    693
    Compared to your 2010 numbers, your HC's have gotten better although still somewhat high. I don't think the new cat or running a stock cat will make much difference on HC's.
    Any aftermarket exhaust wrap installed before the cat will help pre-heat the cat.
    I would remove all the carbon crap that builds up in the EGR pipes and behind the throttle body plate. Also using a scour pad, remove the layer of residue that builds up on the coolant temperature sensor.
  8. #33
    SupraForums Member
    Join Date
    Sep 2011
    Location
    San Jose
    Posts
    215
    Hey guys sorry to bring this back from the dead but...I failed smog. Talked to the guy was pretty helpful, said I'd need to run injector cleaners and probably a new cat. More opinions would be nice.
    Here's the story. Drove the car around, did a few pulls. Car is still in TTC mode. Still has the original cats with 180XXX miles. Just put in new plugs, new air filter, oil was still clean but unchanged.
    Here's the numbers
    15mph: CO2 14.1% O2 1.1% HC 52/114 CO 0.49/.19 NO 424/386
    25mph: CO2 14.3% O2 0.0% HC 36/36 CO 0.46/.04 NO 711/9
    Any help to pass smog would greatly be appreciated!
    Do-Luck Floor Support Bar Install
    http://www.supraforums.com/forum/sho...URE-EXTENSIVE*
  9. #34
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Orange County, California
    Age
    23
    Posts
    1,972
    Your NOx numbers are really high. I'd remove the EGR and clean it out.
    Also have you done all the good general maintenance? Cleaned TB, replaced pre-cat O2, etc. I like getting all that out of the way first and foremost.
  10. #35
    SupraForums Member
    Join Date
    Sep 2011
    Location
    San Jose
    Posts
    215
    Hrm...didn't try that yet Ryeno...just replaced the pre cat 02 with a borrowed sensor. Done all the general maintenance, only thing I'm failing on is the HC, I'll try to get around to cleaning the EGR and the TB. How do I clean those anyways?
  11. #36
    SupraForums Member
    Join Date
    Jun 2001
    Posts
    693
    Quote Originally Posted by JonHuang87 View Post
    Here's the numbers
    Just report back please...
    No, your HC's are high... resulting the high (but passing) NO's on the low speed test. Your NO's are low on the high speed test.
    What's TTC mode? Any sequential modification is tampering with the stock vacuum hose routing and vacuum conditions. I would check for leaks.
    High HC's are generally related to Ignition or Leaks of vacuum from PCV, EGR, Intake Manifold, Throttle body, even leaky intake/exhaust valves.
    High CO's are generally related to Fuel or faulty Fuel related part or clogged EGR related part. Your CO's are good... again I would check for leaks.
  12. #37
    SupraForums Member
    Join Date
    Sep 2011
    Location
    San Jose
    Posts
    215
    ok guys reporting back...as of right now...my HC are still too high. Checked for leaks went back to sequential (TTC true twin conversion), put in a brand new cat, as of right now it's looking to be an internal issue...but still going to look into cleaning the EGR and TB just haven't had time. I'll stay posted
  13. #38
    SupraForums Member
    Join Date
    Nov 2004
    Location
    sacramento
    Posts
    468
    Do you currently have rough idle?
  14. #39
    SupraForums Member
    Join Date
    Sep 2011
    Location
    San Jose
    Posts
    215
    it seems like it idles fine; that's the weird thing...the engine runs completely smooth, no hiccups no nothing.
  15. #40
    SupraForums Member
    Join Date
    Nov 2004
    Location
    sacramento
    Posts
    468
    how hard did you run your car before going in for the test? I ran mine pretty hard for a good 10 minutes on a lower gear to get higher RPM and then got straight in to the smog and had the guy test it for me right away. the difference in HC was from 90s to 50s. If you get a free retest, would suggest doing that.
  16. #41
    SupraForums Member
    Join Date
    Jun 2001
    Posts
    693
    this helps because it heats up the cats, making them more efficient. Although it shouldn't be necessarry to do this, besides he installed a new cat.
    Ughh... You didn't need a new cat.... your NO's were low on the high speed test. If the NO's are high on both high speed and low speed, then the Cats would be suspect. If your low speed HC's are still high, your NO's on the low speed with new cat may not have improved much. Can you post the results from your last test?
    Do you have a boost gauge, boost controller or SAFC that displays vacuum and boost? If so what is your vacuum at idle?
  17. #42
    SupraForums Member
    Join Date
    Sep 2011
    Location
    San Jose
    Posts
    215
    Don't exactly remember the numbers off the top of my head but here's something that's pretty approximate
    15mph: CO2 14.7% O2 1.1% HC 52/80 CO 0.49/.19 NO 424/386
    25mph: CO2 14.7% O2 0.0% HC 36/20 CO 0.46/.04 NO 711/9
+ Reply to Thread
Similar Threads
  1. Failed Smog on HC not sure why ??
    By rs88turbosupra in forum MKIII Technical
    Last Post: 12-21-2005, 03:05 PM
  2. Failed smog...
    By JtWo in forum MKIII (1986.5-1992)
    Last Post: 07-24-2005, 07:16 PM
  3. Failed smog- need some info?
    By twinturbozs in forum MKIII (1986.5-1992)
    Last Post: 05-06-2004, 05:04 AM
  4. failed smog
    By ridah in forum MKIII (1986.5-1992)
    Last Post: 01-14-2004, 01:46 AM
  5. Smog problems, it failed :(
    By orvacian in forum MKIII (1986.5-1992)
    Last Post: 05-14-2003, 07:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
