ok, here's the deal. whenever the car is cold it idles fine, will cruise fine and WOT is a blast. Once it warms up the idle and WOT is still fine, the only thing that changes is the cruise/off idle rpm. As soon as it warms up it starts to sputter under light throttle or anything above idle. When it sputters it goes hella lean (like 16+).
Things i've checked:
vacuum is good
timing is right
dizzy is good, cap and rotor are good
maf is good
ecu has been swapped and same problem
coil is good, new plugs
injectors ohm out no more than 14.5 when hot (will be swapping to a set of injectors that ohm out to 14.1-14.2 when cold tomorrow)
stock o2 sensors are fine
has an safc but i took the safc out of the loop and still has the issue
the only thing i haven't checked/changed is the TPS. this only happens when the ecu comes off warm up and the afr levels out to 14.5-15.3. this started the other day when on my way to work in the morning.
Car is all stock usdm 2jzge with no y pipe cat and a straight exhaust
working on getting a youtube video uploaded
vacuum is good
timing is right
maf is good
