+ Reply to Thread
Results 1 to 15 of 15
Thread: kalford cams in a 1j?
  1. #1
    anyone ever use a set of kalford cams in their 1j?
    looking into a set just wondering what the power band was like
  2. #2
    call da amberlamps Zach90Turbo's Avatar
    Join Date
    Apr 2002
    Location
    UNT
    Posts
    4,798
    Kelford will make any grind under the sun, so there's no way we can tell you how they'll run without more information. To be perfectly honest, I've got BC 272 cams in my 1J and they're fantastic bang for the buck. Readily available and not expensive.
    Experience: that most brutal of teachers. But you learn, my God do you learn.
    C. S. Lewis
  3. #3
    A Lowe's length in front RacerXJ220's Avatar
    Join Date
    Dec 2002
    Location
    Alabama/ Seoul, Korea
    Age
    32
    Posts
    1,363
    Just an example, but the GSC S2 cam lobes were too big for the 1J head (I tried it already), as the intake cam sits about 2mm forward when using 2J cams.
    Different cams, who knows.
    The width of the lobes will be the deciding factor, not the grind of the duration.
    VRP74TBB w/ ETT, 880cc, Stinger 4424, A1000, 272's, ACT eXtreme, 1mm OS valve dual spring ferrea everything and ported 1JZ head, 2.5L block. 27+PSI on 93 + meth 50/50, SP QSV. ???rwhp.
    635rwhp on old 2J block.
  4. #4
    Madd Tyte JDM yo ® flubyux2's Avatar
    Join Date
    Jun 2002
    Location
    Spring Hill, Fl
    Age
    32
    Posts
    6,971
    The 2jz cams have a larger front journal that needs to be machined before it can drop into the head.
    That sucks the s2's need to have the head clearanced on the 1jz setup...
    IMO, $800 for a set of gsc cams isn't terrible, especially considering the gains vs other cams.
  5. #5
    ********* 1JZ-87M-GTE's Avatar
    Join Date
    Feb 2009
    Location
    Milwaukee WI
    Posts
    1,230
    That sucks. I've been wanting to run machined gsc s2s on a 1jz, oh well I guess I'll Just build a 2jz next time.
    '87 Turbo Supra 1JZ
    '95 SC300
    Quote Originally Posted by Zach90Turbo View Post
    The 7M can make 1000whp like a shovel can drive a nail. It'll do it, but in the end nobody's going to be very happy.
  6. #6
    Join Date
    Apr 2002
    Location
    UNT
    Posts
    4,798
    I sent GSC a set of stock 1JZ cams about a year and a half ago so they could offer a 1JZ option. After over a year of promises I gave up and just bought some BC cams.
  7. #7
    Join Date
    Jun 2011
    Location
    Los Angeles, CA
    Posts
    45
    How much horse and torqe did you go up by with the 272 cams?
  8. #8
    Join Date
    Dec 2002
    Location
    Age
    32
    Posts
    1,363
    I dunno. 10.3mm lift on the exhaust, 9.3mm lift on the intake with 1mm OS valves, and I rev it to 9,000.
    I never did a stock cams comparison, but 272's help in high RPMs I've heard
  9. #9
    Join Date
    Feb 2009
    Location
    Milwaukee WI
    Posts
    1,230
    Like I said, Im doing a 2jz set up next. Aftermarket support is sooo much better.
    Btw what fuel rail are you running Zach? I wanted to ask you when I saw your car but totally forgot lol
  10. #10
    Junior Member
    Join Date
    Oct 2009
    Location
    Las Vegas, NV
    Age
    25
    Posts
    148
    Quote Originally Posted by flubyux2 View Post
    those s2's are better than the hks 272s?
  11. #11
    Now with JDM tyteness! foreverpsycotic's Avatar
    Join Date
    Jul 2006
    Location
    Southern CT
    Age
    26
    Posts
    3,729
    S2 cams are insane for what they are. Pretty much the most aggressive cam for the street. The s3 cams are for something like an 80mm+ turbo, the s2 cams are for a 71-80mm turbo. S1 is for a 71mm and under.
  12. #12
    Moderator/Troll Slayer SupraTrey's Avatar
    Join Date
    Mar 2002
    Location
    Midwest
    Age
    34
    Posts
    6,052
    Moved to 1J section. You will get a better response there bud.
  13. #13
    Junior Member
    Join Date
    Oct 2009
    Location
    Las Vegas, NV
    Age
    25
    Posts
    148
    Quote Originally Posted by RacerXJ220 View Post
    aww im torn between the 264s and 272s..i want mid and i want high end range lol...
    what are your head specs bro? anything ported? Im leaning more towards the 264s
  14. #14
    Join Date
    Dec 2002
    Location
    Age
    32
    Posts
    1,363
    IMO, pick your turbo, then pick your cams.
    I went with a 74mm for all top end torque, and that's what my setup is for.
    My head is completely ported, titanium retainers, bronze guides, Ferrea everything. It's in the sig.
  15. #15
    Junior Member
    Join Date
    Oct 2009
    Location
    Las Vegas, NV
    Age
    25
    Posts
    148
    Ive got the hx40 sitting on the shelf i believe thats a 74mm trim.. ive decided on ported and port matched manifolds. titanium retainers and springs and hks 264s
+ Reply to Thread
Similar Threads
  1. BC 280 Cams vs HKS 272 Cams Idle Video Comparison
    By Sins4u33 in forum NorthEast Forum
    Last Post: 06-23-2009, 08:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
