+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 42
Thread: Massive Garage Sale - MKIV stock parts and aftermarket - GTA
  1. #1
    SupraForums Member Danny T's Avatar
    Join Date
    Dec 2002
    Location
    Toronto
    Age
    39
    Posts
    1,022
    Massive Garage Sale - GTA - OEM MKIV parts from my personal car
    EDIT - OEM 6spd driveshaft added Nov 30/12
    All used parts are fully fuctional and are off my running 1994 MKIV TT 6spd C-SPEC with nil issues - Paypal pls add 3%. Shipping is extra and will be quoted on a case by case basis.
    As there are ALOT of parts below, I am willing to make a package deal for those interested in making a substantial multiple item $$ purchase.
    1994 MKIV TT 6spd OEM Parts
    BRAND NEW - OEM Toyota 2JZ-GTE shortblock assembly -- $2200 (with oil pans and oil pickup $2500)
    Exterior Parts
    rear hatch wiper arm and motor assembly -- $60
    oem front bumper amber side marker turn signals -- SOLD
    oem front bumper amber turn signals -- $40
    stock hood - black -- $300
    Electronics
    OEM 6spd ECU - modded by superchips (fuel cut and boost cut removed) -- $200
    Drivetrain/Suspension
    OEM 6spd driveshaft - perfect condition - $300
    OEM diff cover from 2JZ GTE 6 spd diff -- $160
    OEM 6spd torsen diff - this is in perfect condition and 100% functional, includes bearings (as pictured) -- $200
    OEM coil springs -- $80
    OEM front swaybar -- SOLD
    OEM rear swaybar/subframe MOUNTS -- SOLD
    OEM flywheel and bolts -- $200
    OEM clutch and pressure plate and bolts -- $80
    COMPLETE flywheel with clutch pkg - REDUCED - $200 ($80 savings)
    Cooling System Parts
    polished upper hard pipe -- $80 (incl 2 blue silicone couplers)
    OEM upper water neck -- SOLD
    OEM lower water neck -- $20
    Engine Parts
    Stock twin turbos polished cast piping and heat sheild - $140
    stock alternator -- $50
    stock oil pump -- $50
    Stock crank damper/balancer -- $50
    Set of stock Main Caps and bolts -- $60
    OEM oil filter assembly -- $100
    OEM oil dipstick and tube assembly -- $40
    OEM coolant hard pipe for block -- $60
    Air and Fuel Delivery
    OEM fuel pump hanger minus fuel pump and sending unit -- $40
    OEM fuel rail/FPR -- $80
    OEM Mass Air -- $60
    OEM intake manifold (minus sensors) upper and lower runners -- $180
    OEM throttle body -- $80 (no sensors)
    Misc Engine Bay and Chassis Parts
    OEM cruise control unit -- $50
    OEM Traction control pump and actuator -- $50
    OEM ABS assembly -- $80
    OEM charcoal canister -- $50
    OEM fuel and brake line plastic covers - $60
    OEM valvetrain components
    OEM USDM cams -- $140
    OEM Cam gears (2 sets)-- $75 each set
    intake valves -- $60
    exhaust valves -- $60
    stock valve springs/retainers/locks -- $50
    valve buckets and shims -- $60
    timing gear back plate -- $20
    Timing gear belt cover -- $20
    OEM hydraulic timing belt tensioner and tensioner bracket assembly -- $100
    OEM TT valve covers -- SOLD
    sig designed by ToyoBeastly...updated by arpusim
  2. #2
    Join Date
    Dec 2002
    Location
    Toronto
    Age
    39
    Posts
    1,022
    PICTURES
    [IMG][/IMG]
    Stock Mains and Bolts
  3. #3
    SupraForums Member
    Join Date
    Sep 2011
    Location
    Virginia
    Posts
    352
    Price and mileage of turbo?
    '94 6speed MKIV FSR Street Fighter 6266
  4. #4
    Join Date
    Dec 2009
    Location
    Toronto Ontario Canada
    Posts
    45
    Do you have the plug n play harness for the turbo timer?
  5. #5
    SupraForums Member
    Join Date
    Dec 2009
    Location
    Calgary, AB
    Posts
    151
    What is the story of the short block, do you have a spare gte cylinder head for sale?
  6. #6
    Scratching and Sniffing VanSupra's Avatar
    Join Date
    Nov 2002
    Location
    Canada
    Posts
    2,800
    pm sent.
  7. #7
    Join Date
    Dec 2002
    Location
    Toronto
    Age
    39
    Posts
    1,022
    Brand New OEM 2JZ GTE shortblock assembly
  8. #8
    Join Date
    Dec 2002
    Location
    Toronto
    Age
    39
    Posts
    1,022
    reserved for pics
  9. #9
    Join Date
    Dec 2002
    Location
    Toronto
    Age
    39
    Posts
    1,022
    reserved for pics
  10. #10
    Join Date
    Nov 2002
    Location
    Canada
    Posts
    2,800
    Did you not get my pm?
    Thanks Don.
  11. #11
    Join Date
    Nov 2002
    Location
    Canada
    Posts
    2,800
    Paypal sent fot the motor mounts.
  12. #12
    Milf Hunter
    Join Date
    Jul 2011
    Location
    Toronto, Ontario
    Posts
    218
    I also live in the GTA area I am interested in your BOV and your Electronic Boost Controller...if you can PM me your prices Id appreciate it. Thanks.
  13. #13
    Milf Hunter
    Join Date
    Jul 2011
    Location
    Toronto, Ontario
    Posts
    218
    Pics of the front of the boost controller for condition ?
  14. #14
    Join Date
    Apr 2009
    Location
    toronto
    Posts
    82
    Pm sent
  15. #15
    Join Date
    Sep 2009
    Location
    canada swo
    Posts
    60
    pm
    can u pm me ur number , im in kitchener and can pick up some parts in the next two weeks im on holidays,, thx
  16. #16
    Join Date
    Sep 2009
    Location
    canada swo
    Posts
    60
    ok cleaned out
  17. #17
    Join Date
    Sep 2009
    Location
    canada swo
    Posts
    60
    i texted u, and send u my number, u still alive
  18. #18
    Join Date
    Apr 2011
    Location
    toronto
    Posts
    10
    Exclamation WOoW
    Hey pm Sent. I need alot of this stuff, in the middle of an aristo swap!!!
  19. #19
    My final Build telustech's Avatar
    Join Date
    Apr 2007
    Location
    Dartmouth, N.S.
    Posts
    71
    PM Sent
    LHD 94TT WideBody
  20. #20
    BURNED!!!!! suprafanatic's Avatar
    Join Date
    Oct 2001
    Location
    Waterloo, ON, Canada
    Posts
    1,109
    Hey Danny - I'm looking for some engine parts - shoot me an email or PM - thanks.
    E-mail me at adrenaline 'at' gto.net with your needs
  21. #21
    Join Date
    May 2008
    Location
    Aurora, ON
    Posts
    76
    EBC still avaliable?
    What's with all this 'low boost, 'high' boost, 'part' boost talk? whenever I drive my car I'm on 'whatever-this-motherfucker-will-make' boost! - Slither
    1992 Toyota Soarer TT, centerline 3inch exhaust, SAFC2, profec A,
  22. #22
    1986.5 # 818 87supramario's Avatar
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,068
    Oil pan? Let me know.
    Mario
    Mitsubishi T78 Turbo + goodies - $450 shipped!! - reduced
    Resurrection complete. Build thread-> http://www.supraforums.com/forum/sho...d.php?t=614654
  23. #23
    Join Date
    Apr 2011
    Location
    toronto
    Posts
    10
    hey danny, I would like your boost controller!
  24. #24
    Join Date
    Dec 2008
    Location
    On the outside
    Posts
    2,068
    Quote Originally Posted by Danny T View Post
    no oil pan sorry
    Stock clutch fan and fan? PM me
    Mario
  25. #25
    Join Date
    Sep 2009
    Location
    Edmonton
    Posts
    79
    Do you have a boost control sensor for sale?
+ Reply to Thread
Similar Threads
  1. FS: My MKIV Garage Sale - Stock and Aftermarket Parts
    By SupraLizard in forum Canadian Forum
    Last Post: 09-19-2006, 10:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
