+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 37
Thread: 1.5JZ not starting
  1. #1
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    1.5JZ not starting
    So I recently built a 1.5JZ thats going into an S14.
    I just had a custom harness made by chasebays, and wired everything up this week.
    Now the engine will crank all day long, but not start.
    After going through the engine Ive realized its not getting spark or fuel.
    Im looking for any input or ideas on this. Ive been searching and troubleshooting all week so now Im looking to see if anyone can point in a direction for anything I might be missing.
    Some info about the engine:
    1.5jz using a 2jzge block, stock 1j head
    Im running an aristo 2j ecu
    I have an AFPR
    Walbro 255 pump
    everything else is pretty much in stock form.
    As far as wiring the only things I dont have plugged in are the O2 and the IAT sensors because Im waiting on those to arrive.
    I am just trying to turn the engine over to make sure it starts right now before I have it finished so there is no intercooler or intake on the engine yet.
    As far as diagnosing the problem so far I have established that the ecu and ignitor is getting correct power and ground, the coil packs have been tested to be within spec at 0.8 ohms, and they are receiving 12v of power at the plugs. I tested the ignitor on another 1j so I know its good.
    The fuel pump works and I get constant fuel pressure at 43psi.
    When I crank the motor over injector 2 give one spray of fuel right away then nothing from any of the injectors.
    Im leaning towards the problem being in the ecu or possibly cam sensors?
    I cranked the engine with and without the ecu and it did the exact same thing without the ecu.
    Does anyone have any ideas about this?
  2. #2
    AzSupracentral.com Clint G's Avatar
    Join Date
    Jun 2004
    Location
    Gold Canyon, AZ
    Age
    28
    Posts
    1,640
    Blog Entries
    1
    I am assuming your using a stock ecu? Have you used this ecu before? Have you opened up the ecu to inspect for bad caps on the board? Are all your grounds hooked up to good mounting points and tight, is your crank sensor connected and connection good. Thats where I would start.
    -Clint
    SOLD AND PARTED OUT 1989 Black Mica Supra TURBO-R, 2.5GT, 5spd, T66, BC 264, PRO-EFI 128, Dual Walbro, 1600cc, E85 flex fuel, 1ZZ coils.
    ADMIN @ Azsupracentral.com
    Quote Originally Posted by bashivr4 View Post
    mkIII looks really dated imo.
    Quote Originally Posted by kwnate View Post
    I'm not saying the mk3 doesn't look dated, but your vr4 looks like an 86.5 mk3 with some pep boys grills on the side.
  3. #3
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Its stock 2j aristo ecu. I'm having a friend test it with his car this morning to see if that could be the problem.
    I check all my ground and they're good. I spent a lot of time ground the the electrical in the car. The crank sensor is connected, I haven't checked the connection for that so ill do that and see what it comes out to.
    Also, I forgot to mention I'm running 440cc aristo injectors.
  4. #4
    SupraForums Member Jostar's Avatar
    Join Date
    Aug 2004
    Location
    Chicago IL
    Age
    32
    Posts
    2,632
    Chase harness..... MMMMhhhhhhh isn't there a Thread regarding Issues with there custom made harnesses?
    Getting out Boosted by Turbobozzer... for now...
  5. #5
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    hmm I haven't seen that. I can already say ill never order a harness from them after dealing with there customer service and how long it took them.
  6. #6
    2Fast4U OneJSupra's Avatar
    Join Date
    Nov 2006
    Location
    Orlando, Fl
    Posts
    996
    You know you have to wire your injectors sequential right when you using 2JZ ecu?
    1JZ | Stealth ECU | PTE CEA 6266 Billet |Tuned by ME-Motorsports
  7. #7
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Edit: double post.
  8. #8
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Yes. I talked to chasebays about having the injectors wired correctly for the 2j ecu when I ordered the harness. I'm trying to rule out anything that I could have done wrong before I suspect the harness. But I'm beginning to feel less certain about the harness.
  9. #9
    Now with JDM tyteness! foreverpsycotic's Avatar
    Join Date
    Jul 2006
    Location
    Southern CT
    Age
    26
    Posts
    3,717
    Do you have more than one volt meter? If more than one injector is firing on startup with injector 2, it is wired wrong.
  10. #10
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    I pulled the fuel rail off to physically see what was going on. Only Inj 2 would fire once when it would first crank, then none of the injectors including #2 would do anything.
  11. #11
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Just tried the ecu on another car and its good
  12. #12
    A Lowe's length in front RacerXJ220's Avatar
    Join Date
    Dec 2002
    Location
    Alabama/ Seoul, Korea
    Age
    32
    Posts
    1,353
    If there's no reading from the crank sensor, car will not have spark or fuel.
    After using a chaser harness myself for my 1.5J swap, I would check the grounds from the crank, cam, MAP, and TPS.
  13. #13
    Join Date
    Jun 2004
    Location
    Gold Canyon, AZ
    Age
    28
    Posts
    1,640
    Blog Entries
    1
    I haven't been hearing anything good about chasebay's harness's they have been putting out, They may of wired the harness incorrectly. If you have a friend with a running 2jz since you are using a 2jz harness try swapping some sensors and narrowing out any other possibilities but it sounds like it could be wiring issue to me.
  14. #14
    Join Date
    Dec 2002
    Location
    Age
    32
    Posts
    1,353
    Ooops. I used a Chaser harness, not this Chase or wahtever it is.
    Check ALL the wires yourself.
    My Tweak harness was even messed up. Nobody seems to be able to get it right.
    VRP74TBB w/ ETT, 880cc, Stinger 4424, A1000, 272's, ACT eXtreme, 1mm OS valve dual spring ferrea everything and ported 1JZ head, 2.5L block. 27+PSI on 93 + meth 50/50, SP QSV. ???rwhp.
    635rwhp on old 2J block.
  15. #15
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Im thinking its a wiring issue also. Im going to check the crank and cam sensors first. Im hoping it might just be a crank sensor. And Ill also trace and check all the wires myself.
  16. #16
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Orange County, California
    Age
    23
    Posts
    1,972
    Quote Originally Posted by RacerXJ220 View Post
    If anyone in southern california is doing a mk3 swap hit me up.
    I make some damn good quality supra & sc300, 2jz & 1jz harnesses but I've never worked on a mk3 before.
  17. #17
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Update: I went through the harness and traced the wires for the crank, cam and TPS sensors.
    The harness came out fine, Im going to replace the crank and cm sensors next.
  18. #18
    Join Date
    Sep 2010
    Location
    Sandiego,Tijuana
    Posts
    55
    Quote Originally Posted by Ryeno View Post
    I am sort of close to orange county... 2jz swap and with a Mk3
  19. #19
    Join Date
    Dec 2002
    Location
    Age
    32
    Posts
    1,353
    I updated the wrong thread, lol.
    Check your sensors before you replace them. They may not be bad, and it could be something else.
    Hang in there. I had a lot of wiring gremlins, but patience and persistence will pay off.
  20. #20
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    I checked my cam sensors and all the wires in the harness, they were all good. When I looked at my crank sensor it was looses. I tightened it down and all my injectors started firing. But still no spark. This makes me think my sensors are good.
    What would cause my engine to get fuel but not spark?
  21. #21
    SupraForums Member
    Join Date
    Feb 2010
    Location
    Posts
    1,151
    With the key on, is there power at one pin of each coils' plug?
  22. #22
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Yes, with the key in the on position I got power at each coil's plug
  23. #23
    SupraForums Member
    Join Date
    Feb 2010
    Location
    Posts
    1,151
    Check the crank sensor.
    Have you checked for codes?
  24. #24
    Join Date
    Mar 2011
    Location
    Bothell WA
    Posts
    27
    Just checked resistance on the crank sensor. it came out to 1,089 ohms. Good resistance says 1,630 to 2,740 so Im gunna take a guess and say that should hopefully be the problem.
  25. #25
    Join Date
    Dec 2002
    Location
    Age
    32
    Posts
    1,353
    And you are sure you looked up the correct sensor? There are two different ones, that read different, IIRC.
+ Reply to Thread
Similar Threads
  1. 1.5jz
    By dinhnerz in forum 1JZ/2JZ Swap
    Last Post: 04-08-2009, 01:56 AM
  2. value of a 1.5jz AT
    By flyspyder in forum Florida For Sale/Wanted
    Last Post: 01-04-2007, 04:51 PM
  3. 1.5jz
    By manmx83 in forum For Sale/Wanted - Parts Only
    Last Post: 07-15-2006, 06:49 AM
  4. 1.5jz
    By 1JZ_Cressida in forum 1JZ/2JZ Swap
    Last Post: 07-10-2005, 02:44 PM
  5. Starting Problems!! Starting research..
    By www.xpnet.org in forum MKIII Technical
    Last Post: 06-19-2003, 03:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
