+ Reply to Thread
Results 1 to 2 of 2
Thread: 1jz Jzz30 Bee-r Limiter wiring help.
  1. #1
    Join Date
    Feb 2010
    Location
    State College, PA
    Posts
    45
    Hi guys, just got a bee-r limiter for my 1jz. I have a stock jzz30 ecu. We wired it up today using the wiring guide in this thread: http://www.supramania.com/forums/sho...70-specific%29 After doing research there seems to be a lot of confusion on which pins the green and yellow wires should be wired to. We tried wiring it in a couple different ways. At first the limiter would be on all the time and the car would misfire. And now you can rev it freely no matter what you have any of the knobs set to.
    Does anyone have a bee-r installed on a 1jz jzz30 ecu and has it working correctly. And if so what pins on the ecu do you wire the green and yellow wires of the limiter to?
    Any help would be greatly appreciated.
    Thanks, Alex.
  2. #2
    Join Date
    Feb 2010
    Location
    State College, PA
    Posts
    45
    Basically it seems like its not seeing any rpm signal. Which pin on the ecu is good to use for an rpm signal?
+ Reply to Thread
Similar Threads
  1. bee*r limiter help
    By Kazooie in forum MKIII (1986.5-1992)
    Last Post: 10-06-2009, 10:53 AM
  2. bee r rev limiter
    By 88supramaniac in forum MKIII (1986.5-1992)
    Last Post: 04-29-2009, 02:20 PM
  3. bee r rev limiter
    By jonny5 in forum MKIV (1993-1998)
    Last Post: 07-01-2007, 09:41 AM
  4. Bee-R rev limiter
    By 6ick6 in forum Shops & Part Reviews
    Last Post: 03-09-2006, 12:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
