Brake caliper slide pin stuck?
+ Reply to Thread
Results 1 to 8 of 8
Thread: Brake caliper slide pin stuck?
  1. #1
    Join Date
    Jul 2008
    Location
    new jersey
    Posts
    37
    Can anyone give an advice to what would be the best way to unstuck a brake caliper slide pin? I was currently changing my front rotors on my 89 supra and the left caliper won't seem to slide side to side, however i can push it up and down with some force, and since i can't move it side to side, I'm unable to mount it back on with the new pads.
    Any helpful advice would be greatly appreciated..
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Junior Member
    Join Date
    Mar 2009
    Location
    Seattle
    Posts
    142
    Use a clamp to move it
  4. #3
    Join Date
    Jul 2008
    Location
    new jersey
    Posts
    37
    james87, use a clamp? can u please be more specific on how to use the clamp on removing the slide pin, what kind of clamp, a C-clamp?
    oh nevermind, you said to move it..ok ill try that.. thanks..
  5. #4
    Supra Moderator Zumtizzle's Avatar
    Join Date
    May 2006
    Location
    NorCal
    Posts
    4,589
    It's more likely seized and done. Time for a new one.
    Welcome to my nightmare!
  6. #5
    Join Date
    Jul 2008
    Location
    new jersey
    Posts
    37
    finally got the caliper slide pin out...PB blast didn't work, but soaking it in diesel fuel for 15mins did the trick..5yrs my supra sat and rusted the caliper slide pins, and it only took 15mins in diesel fuel to get the rust off..
  7. #6
    Super Moderator Wreckless's Avatar
    Join Date
    Feb 2002
    Location
    Albuquerque, NM
    Posts
    8,804
    Make sure you clean off that slide pin with steel wool and repack it with the proper grease to ensure that it doesn't happen again. Using regular old axle grease that cannot deal with the high temps of braking components is usually what causes that to happen, as it will cook down into a glue-like resin over time.
    Jeff
    "I spent a lot of money on booze, chicks and fast cars. The rest I just squandered." -- George Best
  8. #7
    Addict raysupra's Avatar
    Join Date
    Jan 2010
    Location
    NC again
    Age
    27
    Posts
    1,114
    100% silicone is a old mechanics tool but I dont think they sell anymore.. and you can Buy new pins.. Hon out the caliper and use some brake grease or 100% silicone.. Most of the time new calipers thou.. I got mine at a autostore for like under 60$ a peice for new caliper and hardware
    -Parker-
    1983 MKII:-Built 7M/R154/AEM EMS2
  9. #8
    Frozen Lake Driver D-Oaten's Avatar
    Join Date
    Nov 2008
    Location
    Langley, BC
    Posts
    1,282
    just take the two bolts out of the hub that bolt the caliper bracket in place. take it off with the rotor, then go get a pair of new calipers and change them both. If one went out the other one won't be far behind.
    Plus keeping things in the brake system equal is always a good idea.
    Stock Mk3 calipers are cheap, I think I paid $40 each for mine.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. seized caliper - slide pin removal
    By SupraCooled in forum MKIII (1986.5-1992)
    Last Post: 04-09-2011, 08:28 AM
  2. Brake Caliper Stuck on Sliding Pin
    By 7m Brew Co in forum MKIII (1986.5-1992)
    Last Post: 06-17-2009, 12:07 PM
  3. Brake caliper stiff / stuck
    By m22rockcrusher in forum MKIII Technical
    Last Post: 02-06-2005, 09:16 PM
  4. Brake caliper question, little pin sticking out?
    By 99YellowStang in forum MKIV (1993-1998)
    Last Post: 10-12-2003, 12:42 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
