Page 2 of 2 FirstFirst 1 2
Results 26 to 37 of 37
Thread: Car won't turn over
  1. #26
    Junior Member
    Oct 2010
    Jacksonville, FL
    122
    You're tapping my knowledge now. Does the igf come off of the coil packs or the ignitor?
    94 Toyota Supra Single Turbo 6spd Hardtop
    90 Jeep Wrangler lift, rims, and tires coming soon Daily
    87 Pontiac Fiero GT swapped to a 4.9L V8 SOLD
    08 Mazdaspeed 3 Fully bolted, meth, cobb tune SOLD
  2. #27
    Raising the BAR Dj6ta's Avatar
    Sep 2010
    College Station, TX
    25
    2,139
    Blog Entries
    2
    Y
    Quote Originally Posted by N8_MS3 View Post
    The igniter uses the confirmation signals of the coils to send the IGF to the ecu. So the answer is both.
    Downside to owning a Supra
    Quote Originally Posted by -defi- View Post
    down side? when girls get in and ask "where is the cup holder?"..... real question.... "Who the F*%! said you could bring a drink in here?!".
  3. #28
    Junior Member
    Oct 2010
    Jacksonville, FL
    122
    Battery keeps dying. I'm gonna have to buy a battery charger. But I am getting the same signal from my resistor to my injectors. 2.5v on battery 2.5 on resistor and injectors. I just noticed something today. My coolant sensor isn't hooked up. The connector broke and my buddy just twisted the two wires together....... I don't know if that would be my problem. I know the coolant sensor is one of the fail safe plugs but Idk if twisting it together and closing the circuit would matter. I'm ordering another connector.
  4. #29
    Sep 2010
    College Station, TX
    25
    2,139
    Blog Entries
    2
    Yes, the coolant temp sensor can in fact cause some of the problems you have described. I don't know why you ordered the connector though. I just bought one at Oreilys for about 10 dollars.
  5. #30
    Junior Member
    Oct 2010
    Jacksonville, FL
    122
    Well I made a thread in elmhurst toyota. Hmm. I will give them a call right now.
  6. #31
    Junior Member
    Oct 2010
    Jacksonville, FL
    122
    I called them. I may have not been specific enough but I need the connector not the sensor. They don't have the connector.
  7. #32
    Sep 2010
    College Station, TX
    25
    2,139
    Blog Entries
    2
    Yeah, the one I bought was for an IS300 I think and they use the same connector as our cars.
  8. #33
    Junior Member
    Oct 2010
    Jacksonville, FL
    122
    Oh ok I see. Yea I had the guy check all toyota connectors for coolant sensor. He had the sensor to test with. None matched up.
  9. #34
    Junior Member
    Oct 2010
    Jacksonville, FL
    122
    Ok progress has been made. I bought a new connector from toyota and wired it in today. It fires up everytime I crank but won't stay running. RMP gauge works too. Where to look now?
  10. #35
    Jul 2010
    Kernersville, NC
    7
    Probably a silly question at this point, but have you rechecked all your grounds?
    "Exhaust gasses go into the turbo... witchcraft happens... and you go faster!" -Jeremy Clarkson
  11. #36
    The Great Kruso Kruso's Avatar
    Mar 2002
    Sugar Land, TX
    3,660
    Quote Originally Posted by sixpatch View Post
    +1 but LOL at this thread in general.
    1991 MKIII Toyota Supra 1JZ, the "official" FFIM MKIII- Officially stolen.
    1994 MKIV Toyota Supra Single T70, Fuel, MAP ECU, RPS 6 puck................Sold.
    1993 MKIV TT w/ 79k original miles APU
    2011 Toyota Tundra 5.7 Rock Warrior
    Quote Originally Posted by Zach90Turbo View Post
    When I put 7M in the search it only came up with blown head gasket threads.
    "There is so much good in the worst of us, And so much bad in the best of us. That it behooves all of us Not to talk about the rest of us."
  12. #37
    Mar 2009
    Houston
    395
    I have a question, does it start then die immediately? Also have you tried starting and giving it gas instantly, therefore keeping it running until you let off and it dies?
  1. Car won't turn over!??
    By Hatu in forum MKIII Technical
    Last Post: 08-16-2011, 05:15 PM
  2. Car won't start. Turns on but won't turn over.
    By JCFsupra in forum 1JZ/2JZ Swap
    Last Post: 05-04-2011, 07:36 PM
  3. Car won't turn-over (start), please help.
    By steve80 in forum MKIV (1993-1998)
    Last Post: 06-19-2009, 08:53 AM
  4. Just Installed Motor&Car won't Turn Over???
    By BOOST ALMIGHTY in forum MKIV (1993-1998)
    Last Post: 09-06-2006, 07:49 AM
  5. Car won't turn over
    By OvenRude in forum MKIII (1986.5-1992)
    Last Post: 12-14-2002, 02:52 PM
