Results 1 to 6 of 6
Thread: Coil pack, injector, cam angle replacment plugs.
    Junior Member
    Jan 2008
    australia
    139
    for 3sge variable cam timing engine as fitted to celica, altezza and whatnot.
    can you help with these?
    just the shells, or if they come only with patch wires thats fine also.
    thanks
    Peter
    Your #1 OEM parts source Curt Aigner's Avatar
    Oct 2001
    Elmhurst,ILL 60126
    51
    39,078
    I need the 5 digit number printed on the body of the connector . It starts with "1xxxx"
    Thanks,
    Curt
    eparts@elmhursttoyota.com
    www.elmhursttoyota.com
    630.279.2265 parts direct
    630.835.0122 parts fax
    My weekly hours are 3:45am CST-4:00pm CST M-F CENTRAL STANDARD TIME
    You can call me or use e-mail. If you use e-mail I need your name,address,phone number and CCinfo and items requested.
    Junior Member
    Jan 2008
    australia
    139
    coils 11885
    injectors 11153
    cam angle 10947
    water temp 10737 11062
  4. #4
    Oct 2001
    Elmhurst,ILL 60126
    51
    39,078
    Did you try your local dealer ? Shipping usps priority mail 10-14 days = 17.95
    90980-11885 housing, list 7.53 cost 5.65
    90980-11153 housing, list 8.33 cost 6.25
    90980-10947 housing, list 8.33 cost 6.25
    90980-11062 housing, list 8.22 cost 6.16
  5. #5
    Junior Member
    Jan 2008
    australia
    139
    yes ill check local tommorow and get back to you.
    unless they have stock in the country i normally find it quicker via you
    thanks.
  6. #6
    Oct 2001
    Elmhurst,ILL 60126
    51
    39,078
    ok no problem.
  1. coil pack plugs
    By mine4118 in forum Part Ordering Information
    Last Post: 03-07-2011, 02:56 AM
  2. Coil Pack plugs...
    By b-rett in forum 1JZ/2JZ Swap
    Last Post: 03-23-2009, 11:52 AM
  3. Coil pack plugs
    By BoostedAzn in forum Elmhurst Toyota Scion
    Last Post: 07-13-2005, 04:45 PM
  4. coil pack plugs
    By dondz in forum Elmhurst Toyota Scion
    Last Post: 01-28-2005, 11:19 AM
