Correct Wheel Offset Size for Varrstoen on Supra MKIV
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 46
Thread: Correct Wheel Offset Size for Varrstoen on Supra MKIV
  1. #1
    Join Date
    Dec 2011
    Location
    Australia
    Posts
    7
    Hi guys, im buying new wheels I'm choosing 18" Varrstoen 2.2.1 Matte Black
    http://www.varrstoen.com.au/shop/2-2...ims-wheels-18i
    I need to choose offsets but I'm not sure what will fit correctly and the last thing I want to do is end up with useless wheels laying around and having to resell them.
    so just asking the experts
    The Selection is
    Front: 18x9.5
    Rear: 18x10.5
    offsets available: 12, 15, 22, 30, 34
    Any of the wheel experts know what offset is best suited for those wheels and what will fit correctly?
    Thanks for the help.
    Cheers
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    iSketch Master! AlxRSPTT's Avatar
    Join Date
    Jun 2002
    Location
    Rio Ranco, New Mexico
    Age
    31
    Posts
    8,938
    The closest will be the 34, but that may not be enough depending on your fender mods. For reference Volk TE37's in Supra offset, in those sizes are +40/+45, F/R. The fronts most likely will be ok, but the rears will definitely require a fender roll, and/or a stretched tire.
    Alex
    Click here to enlarge
    1997 RSP TT BPU+ *Supra rebuild* Click here to enlarge
    1985 P-Type Supra *under construction*
  4. #3
    Join Date
    Dec 2011
    Location
    Australia
    Posts
    7
    Everything is stock at the moment, I dont mind rolling the guards.
    What tyres would fit on the front and rear if i was to go for a 34 on both front and rear.
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    Jun 2002
    Location
    Age
    31
    Posts
    8,938
    I don't want to comment directly on the sizes as I'm no expert at this tire sizing to fit our fenders.
    Alex
  7. #5
    Join Date
    Dec 2011
    Location
    Australia
    Posts
    7
    Thanks Alex I appreciate the help mate!!
  8. #6
    JetFire Blakbird's Avatar
    Join Date
    Mar 2004
    Location
    East of DC
    Posts
    4,438
    What size tires were you hoping to run?
    Black Onyx 95 HT NA->VVTI GTE/V160/BW S366SXE/Infinity 6/806HP&655TQ@34psi on E88 built and tuned by Freed Engineering
    Black Onyx 00 GS400 Platinum/RSR Coils/TSW Rascasse/CatBack Exhaust/Cruiser
  9. #7
    Join Date
    Dec 2011
    Location
    Australia
    Posts
    7
    Rear: 255 or 265 or 275
    Front: 235 or 245
    thoughts?
  10. #8
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    67
    Posts
    13,516
    I can't give you a complete answer but this comparison might help you since I have 18" X 9.5"F and 10.5"R, both +45 offset and with no fender mods the widest tires I could fit without any contact or interference of any kind was 265/35F and 285/35R. With the +34 offset your wheels will stick outward from the fender another 11mm further than mine. So if you are willing to roll the front and back fenders (mine now have the lips cut off due to my wider CCW wheels in sig below) that should give you the clearance you need for the tire sizes I use. If you're willing to run more camber and/or maybe pull the fenders a bit, even the +30's can probably be made to fit but that type of fitment is not for me so I can't say for sure.
    Nick 95 6sp
    Twin Garrett GT2860's w/TiAL exhaust housings, WG's and BOV's, on V-band moded HKS twin manifolds, AEM v2, AEM WB, ID1000's,
    AEM meth/water spray kit, GSC S1 cams, ported head Ferrea valvetrain, +0.020" CP pistons w/crown & skirt coatings, Carrillo H-beams,
    OS Giken triple clutch & Super Lock LSD, Racelogic TC, TRD gen2 catback
    street wheels: Veilside EvoV 9-1/2"F X 10-1/2"R with 265/35F & 285/35R NT05's
    track wheels: CCW LM5 10"F X 11-1/2"R with 285/30F & 315/30R R888's
  11. #9
    Moderator Steve Jarvis's Avatar
    Join Date
    Feb 2001
    Location
    Lewisville, NC
    Posts
    3,504
    Blog Entries
    1
    I wouldn't recommend those offsets at all. If you do buy the wheels, your best bet would be the +34mm offset with a 255/35R18 front and 285/30R18 rear.
    The 255/35R18 will have better clearance than the 245/40R18 due to the height of the tire.
    You may want to go with a 285/35R18 rear tire, as it will give you better straight line traction, but you may not like the looks of having 1" taller rear tire.
    With the sizes above, you will have to roll/cut your rear fender lip.
    Later, Steve
    2001 Porsche 911 Turbo EVOMS GT610 Blk/Blk 6sp
    2001 M3 Red/Blk 6sp, exhaust, coil-overs, and wheels, 19x9.5" with 275/30R19 front and rear
    2006 M5 Sapphire black metalic, stock for now
  12. #10
    Join Date
    Dec 2011
    Location
    Australia
    Posts
    7
    would it be okay if i was to go 245/35R18 Front and 265/30R/18 Rear, because my supra is only a SZ-R at the moment gutless and being a street car for the moment? *shy face*
    As long as the tyres remain in the 30-35 height ill be okay for clearance?
  13. #11
    Swagger Wagon bkfill's Avatar
    Join Date
    May 2004
    Location
    Brooklyn, NY
    Posts
    401
    do you have TT brakes in the front? I called that company and asked what offset I would need to clear the TT brakes he said +22, but +22 is aggressive as hell might not even clear the fender.
    Call them see what they say
    bkfill - 93 Black 6Spd Super99
  14. #12
    Join Date
    Dec 2011
    Location
    Australia
    Posts
    7
    I've got 2/1 (small brakes) but in the later future I may upgrade to 4/2 so id like the flexibility of having them also fit to big brakes
  15. #13
    SupraForums Member
    Join Date
    Jan 2002
    Location
    Finland
    Age
    36
    Posts
    5,539
    You need +22 to clear the big brakes. Somewhere I read that you even might need a 5mm spacer in the front making it +17.
    Supra MKIV Euro-spec 6spd TT -93
    3.3, 10:1, VVTi, 80mm
    Stoptech BBK, Work Meister S1, KW V3 etc
  16. #14
    I Can Has EBT? shak's Avatar
    Join Date
    Apr 2004
    Location
    Jax FL
    Posts
    3,130
    As far as I can remember, they did not clear TT brakes and you had to use a spacer for +35mm wheels.
  17. #15
    Ninja detuned's Avatar
    Join Date
    Dec 2003
    Location
    Orlando
    Posts
    1,826
    Here are my Old (now discontiuned in this offset) TE37s in 19x10.5 +35 with a 275/35 tire:
    Fronts were 8.5 +22 as those were the only ones I can find with a slight concave that still fit.
    Here are 19X10.5 +22 with the same tire: (sorry for the crappy pics) These looked the best IMO, but I would have had to put on a smaller tire which was no bueno.
    9.5+22:
    Go here to put in your sizes then compare....
    http://www.1010tires.com/WheelOffsetCalculator.asp
    PD
    1993.5 Ridox 6MT 6766
    1997 T4R V6 5MT
    1993.5 BB BL Auto PT67
    1988 Harley 883 Cafe
    2004 LS650 Bobber
  18. #16
    Join Date
    Feb 2001
    Location
    Lewisville, NC
    Posts
    3,504
    Blog Entries
    1
    Quote Originally Posted by Farouk View Post
    It's not about power, it's about handling. The NA is still a 3,400 lb. car and need a lot of tire. I would mount a 245 or smaller tire on a 9.5" wheel regardless.
    Later, Steve
  19. #17
    Join Date
    Dec 2011
    Location
    Australia
    Posts
    7
    So I shouldn't mount a tyre smaller than 245 on a 9.5" wheel? and no smaller than 265 on a 10.5" wheel?
  20. #18
    Join Date
    Feb 2001
    Location
    Lewisville, NC
    Posts
    3,504
    Blog Entries
    1
    Go to tire rack.com. You will see what the max and min wheel width is for a certain tire.
    Most manufacturers will list a minimum 245 for a 9.5" wheel, I'm just saying I wouldn't do it.
    Later, Steve
  21. #19
    SupraForums Member
    Join Date
    May 2010
    Location
    Vancouver, BC
    Posts
    1,362
    The Selection is
    Front: 18x9.5
    Rear: 18x10.5
    Cheers
    I haven't even read the replies in this thread but here is what I can tell you...
    The back spacing of the rim will hit the Twin Turbo calipers.
    So basically Varrstoen wheels do not fit the Supra.
    The only offset that clears the Twin Turbo brakes is +12.
    Even with a +22 (the Varrstoen model I have clear TT brakes), I still was required to custom pull my front and rear fenders a lot (about 20-25mm).
    Also even though Varrstoen has those offsets listed, they rarely will have them available, or pretty much never.
    They mostly over the +12 or +22 offset.
    If you have the smaller 2/1 pot brakes, then the +22 will fit but you will still need to run smaller/streched tires.
    Fyi I run 255/35 19x9.5 +22 front
    and 285/30 19x10.5 +22 rear
  22. #20
    SupraForums Member slither's Avatar
    Join Date
    Aug 2002
    Location
    Virginia
    Age
    39
    Posts
    6,785
    Just buy correct offsets and be done with it, a 9.5" wheel deserves atleast a 265, and a 10.5" deserves at absolute minimum a 285. Any smaller, and sorry to the ones who have done it, look like vdub stretched tire shit. If the widest part of your tire is where it contacts the rim, it looks like shit. Period. Sorry a nice looking supra still can't pull that stretched shit off.
    If the wheel you want doesn't have the correct offsets, don't modify your car to make them fit. Modify your taste and do it right.
    Stretched tire = ANY tire that the widest part is where it contacts the rim
    AboveFab(supra fabrication)
    Feel free to text me with any questions/tech/advice/info. Its quicker and more personal than pms and you are sure to get a quick response. 434-470-2700
  23. #21
    SupraForums Member
    Join Date
    Jan 2004
    Location
    Pa
    Age
    36
    Posts
    106
    Quote Originally Posted by slither View Post
    +1. Buy the correct size wheels and tires for your car. Ah the good old days when this tire stretch nonsense was non-existent.
    Also, my front wheels are a 18x9 +42 and clear supra brakes. You dont need a low offset for brake clearance if the wheels were made for the car.
  24. #22
    SupraForums Member tyzorg's Avatar
    Join Date
    Sep 2007
    Location
    fort myers, fl
    Posts
    376
    Well in looking into these wheels,
    So I would need 18x8.5 or 9.5 +22 with 5mm spacer to clear front tt brakes
    Or 18x8.5 +15 offset? Would that be flush up front?
    For rear 18x10.5 + 30 would clear the rear calipers correct ?
  25. #23
    2007 FSAE World Champion supradjza80's Avatar
    Join Date
    Oct 2004
    Location
    Appleton, WI
    Age
    31
    Posts
    1,239
    Quote Originally Posted by Steve Jarvis View Post
    Later, Steve
    I think I know why he was confused, up above here you said you would mount a 245 or smaller on a 9.5" wheel, which really doesn't make sense. But down below you clarified saying that you really would not use a 245 or smaller on a 9.5" wheel based on tire data from the manufacturers. I think that is where the OP's confusion came in from a simple typo.
    Later, Steve
    Dave Hanna
    http://www.youtube.com/user/supradma71
    1992 Toyota Supra Turbo 342 rwhp
    1991 Audi 200 20V Quattro Turbo [Sold]
    1997 Toyota Supra Turbo 6spd 400 rwhp @ 13.5 psi
    2006 Lexus IS250 AWD
    2005 Formula SAE FPG 3rd Place
    2007 Formula SAE World Champions
    2008 Formula SAE VIR Champions
    2008 Formula SAE MIS 4th place
  26. #24
    Join Date
    May 2011
    Location
    Colombia
    Posts
    56
    I want those wheels too, but I dont know, which is the size that I need to look raz?
    I have a Supra mk IV NA
  27. #25
    Join Date
    May 2011
    Location
    Colombia
    Posts
    56
    I am talking with the varrstoen´ dealer and he told me the offset that I need for my MK4 NA is 19" x 9.5 + 22 front and 19" x 10.5+30 rear with a tire 245-35-19 front and 285-30-19
    it will looks flush in the supra???
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. wheel size and offset
    By georgevlades in forum MKIV (1993-1998)
    Last Post: 07-15-2013, 01:10 PM
  2. wheel offset size
    By COOL2J in forum MKIV (1993-1998)
    Last Post: 10-15-2010, 07:41 AM
  3. What is the correct offset for 17's ona supra
    By parrot in forum General Supra Forum
    Last Post: 02-05-2008, 08:07 PM
  4. Correct wheel offset?
    By Mahsty in forum MKIV Technical
    Last Post: 06-19-2002, 02:39 PM
  5. Whats the correct wheel offset for the MKII supra?
    By Frank_MA61 in forum MKII (1982-1986)
    Last Post: 01-25-2002, 02:44 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
