R154 Transmission
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 32
Thread: R154 Transmission
  1. #1
    SupraForums Member
    Join Date
    Mar 2011
    Location
    Connecticut
    Posts
    301
    R154 Transmission
    just wondering if anyone has swapped over from the w58 to the r154 tranny? if so, how did it work out for you? i currently am running NA-T with the gte short block setup. im looking to make more power but i need a stronger tranny. would the r154 be a possible fit?
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member
    Join Date
    Sep 2011
    Location
    michigan
    Posts
    1,141
    yes it will fit, it can handle more then the w58. but not as much as a V160/V161. but it will be a cheaper setup, which will allow you to make more power the the w58. or you could always save up and wait to get a six speed.
  4. #3
    SF Contributing Member xtoefield's Avatar
    Join Date
    Apr 2005
    Location
    scaring Flicktitty from bowling rematches
    Age
    30
    Posts
    5,809
    what are you horsepower requirements? what's your current setup consist of? this topic has been beaten up so much and covered extensively.
    Daily: '13 Macbook Pro Numbers-750GB@5400RPM, Weekend: '90 MK3
    Click here to enlarge Originally Posted by miss_supra95 Click here to enlarge
    Ugh, got my first dick.
  5. #4
    SupraForums Member
    Join Date
    Mar 2011
    Location
    Connecticut
    Posts
    301
    Quote Originally Posted by xtoefield View Post
    well im not looking to shatter records, i dont take the car to the track or anything. i just drive it casually. im looking to make between 500-550 realistically which i know my turbo/setup can handle. its just a matter of finding the right tranny that can sustain that kind of power. having said all that, could this be a realistic option? ive looked into the v160 and honestly its not worth it to me right now b/c its just so much money between the tranny, differential and anything else i would need to successfully convert.
  6. #5
    Join Date
    Jun 2010
    Location
    Augusta GA
    Posts
    22
    Im pushing 575rwhp and 552 fttq through my r154 not a single problem ever. Ive made over 630 rwhp as well and no problem with the tranny. Im looking for 750 plus here soon. As far as the clutch I run the ACT extreme pp and the southbend feramic six puck setup works awesome no slipping its pretty much the top of as far as a single disk goes, but if your going to buy a twin disk setup on top of the r154 you may as well buy the v160 for that cost.
    1992 Sc300-USDM 2jzgte swapped, Marlin Crawler R154, South Bend Clutch setup, 97 OEM Bumpers, E-85 gas only, Titan motorsports Fuel setup, turbonetics hp72, Full V-band Single Exit 3"Intercooler piping, Supra LSD, Tanabe Sustec Coilovers, AEM V2 with all sensors, Harness done by Tweak, Synapse Syn-chronic BOV, Rh pro evos j8's, Black Interior swapped, ICE COLD A/C, Fresh Black Onyx Paint, Tuned by Battleground Motorsports
  7. #6
    SupraForums Member
    Join Date
    Feb 2009
    Location
    Fond du Lac wi
    Posts
    164
    Blog Entries
    1
    spend the cash and buy a used V160 and get it over with. You will kick your self in a few years if you dont
  8. #7
    SupraForums Member Juhanis's Avatar
    Join Date
    Oct 2003
    Location
    Los Ghettos, California
    Age
    34
    Posts
    2,767
    550whp for the r154 is cake. the v160 may be stronger (mainly only because its ratios are shorter) than the r154. basically since the v160's ratios are so much shorter, it sees less stress internally under load than the r154 would. in my opinion you're only paying for the hype of the v160 if you're not looking to make 600-700+ whp. i myself would consider going v160, but that's only because i've destroyed tons of r154 pressure plates, and grenaded one r154. another problem with the v160 is since its ratios are so short and close together you'll find yourself shifting a lot more than if you had a r154. with my 3.91 gears and a r154 i can go from 50-150 with just 3rd and 4th. bottom line, is my opinion is its not worth paying the 2-3k for a transmission you'll never need. unless you want to brag to your buddies that you have a six speed or something. haha.
    Sisu Research & Development, Specializing in Expandable Fuel Injector Sales/Production.
    I'm currently not taking any new orders. I do plan to still build injectors in the future.
    Feel free to pm me if you have any questions.
    stable:
    90 supra, bw s366, 272 cams, srd 1400cc, e85, front/rear bbk, 2jz, megasquirt diypnp
    91 eagle talon tsi, bw s258, forged 6 bolt, built close ratio trans, PTT twin disc, evo brakes
  9. #8
    -Question Conjecture- swing lo's Avatar
    Join Date
    Oct 2003
    Location
    Behind her. . .
    Posts
    2,848
    ^ You can't be serious.
  10. #9
    Join Date
    Apr 2005
    Location
    Age
    30
    Posts
    5,809
    Quote Originally Posted by Juhanis View Post
    . you're fucking retarded or trolling.
  11. #10
    SupraForums Member
    Join Date
    Mar 2011
    Location
    Connecticut
    Posts
    301
    interesting lol
  12. #11
    SupraForums Member
    Join Date
    Mar 2011
    Location
    Connecticut
    Posts
    301
    hope someone can help me with this question. would my current master cylinder work for this swap or do i absolutely need the mkiii master cylinder?
  13. #12
    SF Contributing Member atown636's Avatar
    Join Date
    May 2009
    Location
    atl
    Posts
    596
    No need to swap masters cylinders, the mk4 master works fine
  14. #13
    SupraForums Member
    Join Date
    Mar 2011
    Location
    Connecticut
    Posts
    301
    Quote Originally Posted by atown636 View Post
    thank you sir!
  15. #14
    wasting my life on SF muchoboosto's Avatar
    Join Date
    Jul 2006
    Location
    Haslet/Arlington TX
    Age
    30
    Posts
    1,805
    Sorry, not to jack the thread, but I am about to go NA-Auto to R154. Do I need to swap the auto tunnel with a manual tunnel to accommodate the R154 (or is that only for the v160)?
    1994 Supra NA-T/R154
    1968 Dodge Charger 440/727 AUTO
    1968 Dodge Charger Drag Car-full tube chasis on 32x14x15s
    My site,
    www.backoutofwhack.com
  16. #15
    I turn my own wrenches! a10secstreetcar's Avatar
    Join Date
    Jan 2004
    Location
    FLORIDA
    Posts
    5,089
    Quote Originally Posted by muchoboosto View Post
    No auto Tunnel will be fine.. Depending on you extension on the shifter assembly you will make 2 small 1" cuts to tuck/cut for the shifter to come through. Very easy! Btw v160 FTW, I was R154 for a week! The R154 just does not feel right, and this is coming from someone who has owned 600hp+ mk3's with r154's..
    Proof:
  17. #16
    Join Date
    Jul 2006
    Location
    Haslet/Arlington TX
    Age
    30
    Posts
    1,805
    Quote Originally Posted by a10secstreetcar View Post
    You are the man! Thanks bud!
  18. #17
    SupraForums Member
    Join Date
    Mar 2011
    Location
    Connecticut
    Posts
    301
    for anyone who has done this swap, which tranny mount am i going to need? ive heard the r154 tranny mount should work while someone else said it wont work but i could use my w58 mount with a cross member.. can any1 clear this up for me so i know what im going to need? thanks
  19. #18
    Join Date
    Jan 2004
    Location
    FLORIDA
    Posts
    5,089
    Quote Originally Posted by Scooterman View Post
    I used the w58 mount with auto cross member, so the w58 mount with the existing 5 spd cross member should work as well.
  20. #19
    Join Date
    Jan 2004
    Location
    FLORIDA
    Posts
    5,089
    Np!
  21. #20
    SupraForums Member
    Join Date
    Mar 2011
    Location
    Connecticut
    Posts
    301
    thanks alot man!
  22. #21
    Join Date
    Jan 2004
    Location
    FLORIDA
    Posts
    5,089
    thanks alot man!
    Glad I could help..
  23. #22
    From the land down under Mr Ree NZ's Avatar
    Join Date
    May 2008
    Location
    Wellington, New Zealand, 6023
    Age
    42
    Posts
    3,230
    When I installed my R154 (from a jzx90 or 100 with remote shifter) The mount and crossmember bolted straight up to my A80, no changes needed.
    It seems the mount/crossmember for the 7M R154's are in a slightly different position.
  24. #23
    Join Date
    Oct 2003
    Location
    Age
    34
    Posts
    2,767
    Quote Originally Posted by Scotchington View Post
    nah, the whole thing was a joke.
    i have no idea what i'm talking about... here i'll be like everyone else v16x = best transmission in the world. every car should have one.
  25. #24
    Join Date
    Oct 2003
    Location
    Behind her. . .
    Posts
    2,848
    ^ Is this real life?
  26. #25
    SupraForums Member
    Join Date
    Feb 2011
    Location
    Sacramento
    Posts
    165
    I'm running the r154 in my mkiv with 2jzgte and gs400 rear end. somehow my speedo is off by like 7-10mph when I'm doing 70mph on the car my GPS says I'm going 79mph or so. any idea how to fix this?
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. FS: R154 transmission
    By HLYSHFT in forum NE: For Sale/Wanted
    Last Post: 08-01-2009, 02:29 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
