Is it difficult to Change motor mounts?
+ Reply to Thread
Results 1 to 11 of 11
Thread: Is it difficult to Change motor mounts?
  1. #1
    SupraForums Member
    Join Date
    Mar 2013
    Location
    Chicago
    Posts
    240
    Hello Supra Fans, has anybody changed their motor mounts and if you have how hard is it? Thanx my supra is almost reaching 200,000 miles and i starting to feel a vibration from the motor, might need motor mount change. Doing TRD Motor mounts on a 1997 auto tt.
    Thank You in advance.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    Follow the white rabbit -Defi-'s Avatar
    Join Date
    Dec 2010
    Location
    Colorado Springs
    Posts
    1,652
    time consuming more than anything i would think. Youll have to lift the motor obviously, which means disconnecting the shifter linkage and drive shaft. Radiator hoses need to come off and the heater core lines. Dont forget the grounds as well and the a/c and p/s lines. You might be able to get by without undoing them but its sketchy.
    Click here to enlarge
    || Borg Warner/S366 || ProEFI || E85 || Single WALBRO 450lb/hr || Lucas 1260cc || Pressurized Concepts ||
    http://www.supraforums.com/forum/sho...ct-Defiance)))
  4. #3
    SF Contributing Member Tayousei's Avatar
    Join Date
    Jun 2009
    Location
    Winnipeg, Canada
    Posts
    2,164
    I have a 94 auto TT and I tried getting it from the bottom, but after a fruitless and frustrating attempt at it, I decided to pull the motor, and then it snowballed into a build I never intended to do... Now I'm single turbo'd, stroked, built auto, etc.... allll because of those motor mounts, lol. Good luck and hide your own wallet!
    1994 Supra, 3.25L Stroker, BW S363, ProEFI, Titan S2 trans/stall, OS Giken LSD, S1 cams fully built by Eden (me.) - 636RWHP @ 20PSI on E70
    My Build Thread
    http://TheraVape.net
    www.facebook.com/theravapeinc
  5. #4
    SupraForums Member
    Join Date
    Feb 2013
    Location
    tennessee
    Age
    28
    Posts
    78
    Just did this about a month ago its a pain in the ass I even did mine on a lift. I wouldent do it myself again and just have somone else do it.
  6. #5
    Hardtopper HellBringer's Avatar
    Join Date
    Jan 2002
    Location
    Charlotte, NC
    Posts
    2,373
    Not all that difficult, IMO, but on a '97 you'll need to swap out the brackets, which will definitely make it much more labor intensive. Using a cherry picker my buddy and I did the TRD mounts on my old '94 6sp in maybe 2-3 hours at most. We did it while I was in the middle of a single swap, so the stock twins were out of the way, but the intake manifold and everything on that side of the bay was still intact. The cherry picker wasn't long enough to get it from the front and I didn't want to to drop the bumper so we did it from the side, one side at a time. On the driver side you can get to the top bolt by removing the oil filter and leaving everything else in place.
    1993.5 Supra TT 6sp Hardtop -- Niced Up Motorsports built 10:1 3.0, ProEFI 128, PTE7175, Tilton, Alpha-tuned, 1035WHP
    1994 Supra TT 6sp -- 11.8 @ 118MPH BPU
    2013 Infiniti G37x -- Daily
    2003 Denali XL -- Grocery Getter & Tow Rig
    Formerly:
    1997 Supra TT Auto BPU -- 12.0 @ 122MPH
    1994 Supra 6sp -- 72mm, VPC/AFC, stock longblock -- 722WHP & 10.36 @ 139.5MPH
    1993.5 Supra TT Auto BPU
  7. #6
    SupraForums Member 2fst4u's Avatar
    Join Date
    Apr 2010
    Location
    nc
    Posts
    381
    if you have access to a lift jst unbolt the front sub-frame and hold the engine up with a cherry picker while using the lift to raise the car.
  8. #7
    SF Contributing Member Mike i6's Avatar
    Join Date
    Mar 2007
    Location
    Chicago
    Posts
    198
    If you have never done mounts before, it can be a pain in the ass. But it's not the hardest car to do it on.
  9. #8
    Somebody's Watching Me! ovey1's Avatar
    Join Date
    Jan 2005
    Location
    the big O
    Posts
    1,826
    http://www.supraforums.com/forum/sho...ight=Wheel+hop this thread has a way to do the change in fifteen minutes u will need to look thru it to find it more or less he used a cutoff wheel and cut into the lag of the engine mount and uses a screwdriver to unscrew it.
    So Smooth......Always!
  10. #9
    Reverend Hillclimb SlackJawOutlaw's Avatar
    Join Date
    Jul 2012
    Location
    Valhalla
    Age
    22
    Posts
    2,526
    Quote Originally Posted by ovey1 View Post
    Here is the post in that thread:
    "Just got back in from some more testing. I went ahead and re-installed the TRD engine mounts. For those of you who have never done engine mounts, I have a trick for you. I cut a slot in the end of each of the lower stud heads. This allows you to install the engine mount with the stud out then simply screw the stud back in once the engine mount is in place. I was able to do both mounts in about 10 minutes like this...way faster! With the TRD engine mounts back in there was no increase or decrease in the shuddering."
    - TurboMatt
    1994 Renaissance Red Original TT 6-Speed - Hillclimb Monster - Under the scalpel
    Feel free to ask or PM for anything and everything about Computer Hardware
  11. #10
    SupraForums Member NA-T PETE's Avatar
    Join Date
    Nov 2011
    Location
    australia
    Posts
    506
    Yea I did it the other day, bitch of a job, just changing the mounts isn't so bad as you can get to the top ones with uni joints and bars but you need to people. I changed the legs that bolt on the block and it was such a bitch, you'll need a decent tool set.and a mate helping, 4 hours and we had a pit but I did have to remove my.external gate and oil cooler sandwich plate to get at it
  12. #11
    SupraForums Member
    Join Date
    Mar 2013
    Location
    Chicago
    Posts
    240
    Thanks Guys sounds likes its going to be a job but it must be done.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Trd motor mounts and trans mounts !!
    By Curt Aigner in forum Elmhurst Toyota Scion
    Last Post: 11-12-2012, 04:02 AM
  2. How do I change the motor mounts?
    By supradriver247 in forum MKIV (1993-1998)
    Last Post: 10-03-2007, 12:43 PM
  3. Hi Dusty, question about motor mounts/transmission mounts
    By andysoff in forum MVP Motorsports, Inc.
    Last Post: 05-09-2007, 09:08 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
