final gear ratio mpg affect
+ Reply to Thread
Results 1 to 2 of 2
Thread: final gear ratio mpg affect
  1. #1
    SupraForums Member sleeknsilver's Avatar
    Join Date
    Feb 2001
    Location
    las vegas, nv
    Posts
    1,888
    How much do final gear affect mpg? Say from 3.13 to 3.73? Cruising of course
    97 sc400 rsp (soon to be 6spd gte)
    93.5 supra turbo 6spd single turbo (SOLD 3/18/07)
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    SupraForums Member T6Rocket's Avatar
    Join Date
    Mar 2002
    Location
    Raleigh, NC
    Posts
    3,961
    I don't think the odo and speedo would even read correctly to measure the difference. They are going to read very high, unless you can find the correct gear for the trans.
    Gas mileage is always a little worse with shorter gears. You may find yourself "skipping" gears to avoid shifting so often on your way to 6th, a gear you will spend a lot more time in than you used to.
    Al
    94TT Auto, 6466
    9.95@133.80 27 psi 4/16/16
    Previous setup: HKS Twin 2835's
    9.57@142.42 32 psi, 10/29/06
    Previous car: 90 Talon AWD, 5 spd, FP Red (60-1)
    10.56@132.36 built motor, 28 psi, Sept 2000
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. final compression ratio Q?
    By recharged95 in forum MKIV Technical
    Last Post: 12-25-2002, 06:33 PM
  2. final gear ratio change from 93.5 to 94??
    By Xdreamer in forum Naturally Aspirated
    Last Post: 10-30-2002, 09:29 PM
  3. Transmission and final gear ratio
    By StangDuo in forum MKIV (1993-1998)
    Last Post: 08-28-2002, 11:59 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
