Blow off valve questions. (Location, how many, and fakes)
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 26 to 40 of 40
Thread: Blow off valve questions. (Location, how many, and fakes)
  1. #26
    SupraForums Member
    Join Date
    Jul 2007
    Location
    St. Louis, MO
    Posts
    196
    Thanks for the feed back and good points made above.
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #27
    Twin Meister
    Moderator
    KenHenderson's Avatar
    Join Date
    Feb 2002
    Location
    SoCali
    Posts
    9,818
    Two Blitz Dual-Drive BOVs, with stiffest springs, as close to VeilSide 100 mm throttle body (1100 whp motor) as reasonably possible:
    Ken.
    www.sp-power.com
    HKS 3.4L: 1110 all-boost whp/839 lb-ft @ 2.6KG/CM^2
    1994 "SP ENGINEERING" TWIN HKS GT3240 TOYOTA SUPRA TURBO
    1985 Toyota Celica Supra P-Type 5MT
    1991 Toyota Supra Turbo Hardtop/Sunroof 5MT (BPU)
    1993.5 Toyota Supra Turbo Hard Top (BPU)
    1995 Toyota Supra Turbo 6MT (APU)
    2006 Toyota 4Runner Limited V8
    2010 Lexus IS-F
    2016 Lexus IS 350 F Sport
  4. #28
    Dr. Pepper Bandit Biologist's Avatar
    Join Date
    Jun 2010
    Location
    In My Laboratory
    Age
    24
    Posts
    3,427
    Procharger big red
    took off my cold side IC piping that will be getting polished
    Renaissance Red
    Click here to enlarge
    Rest in Peace K.P 7-16-2012
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #29
    SupraForums Member
    Join Date
    Apr 2013
    Location
    Myrtle Beach SC.
    Age
    34
    Posts
    230
    On my car I have the TIAL BOV and it is mounted fairly close to the TB...and to me this makes the most sense as once you let off the gas pedal the TB closes and that is the first place that air stops moving forward and has to move backwards....So in theory you want it to be able to release at the closest point so having the BOV as close to it as you can allows that air to escape very quickly...However my buddy has the same BOV mounted on his hot side pipe right before his intercooler and it works just fine as well. I have a 76mm turbo on my car and he has an 88mm on his... As far as brand I am TIAL all the way man..best quality and sound you can ask for.
    95 Black Auto// Turbonetics 76mm//Titan stage 3 block// stage 2 head// ATF stage 3 auto// tripple pumps//FIC 2150cc injectors// upgraded rear diff// 804whp at 33psi on E-85//PRO-EFI flex fuel.
  7. #30
    SupraForums Member
    Join Date
    Oct 2013
    Location
    Allentown, PA
    Age
    32
    Posts
    284
    I've always loved my Turbonetics Raptor BOV, which will be replacing my SSQ soon hopefully I ran it on my Mustang for a while.
    I would switch over to a piston style (pretty much anything other than the HKS SSQ style) since they vent more air if you are worried. I doubt you would need 2, but it’s all up to the person. If it lets ya sleep at night then add another one. Not going to hurt at least.
    If you really want to vent some air you can always get a Mad Dog 104.
    http://racepartsolutions.com/index.p...part-solutions
    1994 NA-T Supra.
    461RWHP, 93Pump, 16Psi
    Stock GE motor, 272 cams, Home Built Header and cold side, Ebay FFIM + throttle body.
    www.SloppyMechanics.com
  8. #31
    SupraForums Member
    Join Date
    Jul 2009
    Location
    Depew, NY
    Age
    30
    Posts
    194
    Quote Originally Posted by ShotPoopra View Post
    dafuq.
    That's pure awesome.
    2003 G35 Sedan
  9. #32
    SupraForums Member
    Join Date
    Jun 2012
    Location
    Florida
    Age
    26
    Posts
    288
    Can't go wrong with Tial
    -BW 9179 -Cp Pistons -Eagle rods -BC Valvetrain -Tial 50bov/44wg -Twin Walbro 450 -LQ9 C.O.P -Soarer R154 w/SB Extreme Clutch -MegaSquirt PRO
    thin line between my stressor and stress reliever
  10. #33
    Question to suit. 220's Avatar
    Join Date
    Dec 2002
    Location
    Anywhere, USA
    Posts
    3,007
    Engineers @ Borg Warner knew what they were doing when they put a BOV on the turbo... So did Toyota near their turbos, etc...
    We're splitting hairs in this thread, lol.
  11. #34
    T88 YOU supradupaflyguy's Avatar
    Join Date
    Nov 2004
    Location
    Austin, TX
    Posts
    3,567
    Quote Originally Posted by RacerXJ220 View Post
    You're neglecting the fact that both of those "technologies" are using recirculated BOVs. Toyota does it because they use a MAF system, which needs recirculation. Borg Warner does it to make consolidate all components of a turbo system into a single unit (namely turbo, BOV, and waste gate).
    I'd say you could argue either way. You could argue that placing the BOV near the turbo would allow you to keep more boost built between gears for drag racing, and placing it closer to the TB would place less stress on the turbo if you don't care about boost between gears.
    1998 Quicksilver 6spd (12K miles)
    1998 IJM 6spd (21K miles) SOLD
    2003 Harley-Davidson F-150
    My build thread:Click here!
  12. #35
    SupraForums Member
    Join Date
    Jul 2007
    Location
    St. Louis, MO
    Posts
    196
    Since everyone posted pics, u can sort of see mine near the TB
  13. #36
    SupraForums Member
    Join Date
    Jul 2007
    Location
    St. Louis, MO
    Posts
    196
    I cant stand the welds on the pipe but its finctional^
  14. #37
    SupraForums Member
    Join Date
    Feb 2001
    Location
    SE PA
    Age
    67
    Posts
    13,496
    Quote Originally Posted by zrs6v4 View Post
    I cant stand the welds on the pipe...
    In that case I'll post up some more pipe welds. You can also see my two TiAL's BOV's, one on the hot side and one right before the TB.
    Nick 95 6sp
    Twin Garrett GT2860's w/TiAL exhaust housings, WG's and BOV's, on V-band moded HKS twin manifolds, AEM v2, AEM WB, ID1000's,
    AEM meth/water spray kit, GSC S1 cams, ported head Ferrea valvetrain, +0.020" CP pistons w/crown & skirt coatings, Carrillo H-beams,
    OS Giken triple clutch & Super Lock LSD, Racelogic TC, TRD gen2 catback
    street wheels: Veilside EvoV 9-1/2"F X 10-1/2"R with 265/35F & 285/35R NT05's
    track wheels: CCW LM5 10"F X 11-1/2"R with 285/30F & 315/30R R888's
  15. #38
    SF Contributing Member
    Join Date
    Apr 2005
    Location
    Chicago
    Age
    36
    Posts
    807
    ^^^ That's a pretty bad ass engine bay to say the least.
  16. #39
    SupraForums Member
    Join Date
    Oct 2013
    Location
    Allentown, PA
    Age
    32
    Posts
    284
    Quote Originally Posted by articzap View Post
    dafuq.
    Haha, yeah a lot of the Procharger and blower guys need em. I’ve known a few people running 3-4 50mm BOV’s on their race cars. So much air it forces itself past the throttle plates etc, and doesn't let the motors rev down, bad feeling at the end of the track lol. It’s crazy to see guys at idle with the BOV’s way open hissing air out.
  17. #40
    SupraForums Member
    Join Date
    Jul 2007
    Location
    St. Louis, MO
    Posts
    196
    Nick, very nice setup and very clean.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Blow off valve location
    By Supraboy21 in forum MKIV (1993-1998)
    Last Post: 04-29-2012, 07:02 PM
  2. Best blow off valve location?
    By SealSupra-6 in forum Naturally Aspirated
    Last Post: 06-03-2006, 03:49 PM
  3. blow off valve mount location
    By LoBudjetRacer#1 in forum MKIV Technical
    Last Post: 02-06-2002, 01:16 AM
  4. Best Location 4 Blow Off Valve
    By REDBLITZ in forum MKIV Technical
    Last Post: 10-20-2001, 05:04 AM
  5. Blow off Valve location???
    By Jodicious in forum MKIV Technical
    Last Post: 08-29-2001, 05:16 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
