v2 stuck in ONIDLE state?
+ Reply to Thread
Results 1 to 13 of 13
Thread: v2 stuck in ONIDLE state?
  1. #1
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    Anyone else have this issue?
    Garth messed with a few parameters the other night, but it seems like the ProEFI does not get the fact that I'm not in idle any more, and was puling timing to compensate.
    Set that to 0, but now idle control is crap, and if the AC is on (defroster), the idle goes up the longer it's let sit.... (ie, AC turns on, 700->1000, sit 30 seconds more, 1000 -> 1200, 1200->1800, 1800->2000 etc). I have to blip the throttle and try and move forward a little to make it fall back...so I've been turning off heat at stoplights lol.
    Click image for larger version
    I note that Garth wanted me to put 0.5% for TPS idle entry, but have 0 in my live config. Not sure if that will make a difference. (I manually merged them, must have read that wrong.)
    -Matt
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    spracingonline.com DentGuy's Avatar
    Join Date
    Aug 2008
    Location
    Algonquin, IL
    Age
    35
    Posts
    2,846
    my TPS for idle entry is 3%, maybe give that a try
    Bob W.
  4. #3
    SF Vendor Member Sound Performance's Avatar
    Join Date
    Feb 2001
    Location
    I don't know how to put this but I'm kind of a big deal. People know me. I'm very important. I have many leather-bound books and my apartment smells of rich mahogany.
    Age
    51
    Posts
    11,663
    Your idle entry % or your actual TPS % need to be set accordingly.
    Click here to enlarge
    Sound Performance
    630-893-5002
    DO NOT PM ME!!!
    Email - XXSUPRAXX@AOL.COM
    Instant Messenger - XXSUPRAXX
    Text or Cell Phone - (630) 205-6690
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    I'm using CAN / calculated TPS, so it's 0.00 when my foot is off the pedal.
    The problem is, even if moving (and with a non-zero tps), it never goes off of ONIDLE...
    Hopefully this is a non-issue in a few days. :-/ Garth's had some laptop trouble, which is what's caused the delay in getting me v3.
    -Matt
  7. #5
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    According to the docs, 3, & 1 for hysterisis should work, as it's the TPS position to EXIT idle control. (again, according to docs), but that's almost what I had it at in the beginning (2 % entry, 1% hysterisis).
    That being said, it never left ONIDLE.
    -Matt
  8. #6
    Join Date
    Aug 2008
    Location
    Algonquin, IL
    Age
    35
    Posts
    2,846
    Does your TPS have a reading???
  9. #7
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    Yes, in the idle screen, you can clearly see tps values going 10+% and state still being onidle.
    I assume that the usual state is for it to go OFFIDLE if you're driving, right?
    -Matt
  10. #8
    SupraForums Member
    Join Date
    Aug 2009
    Location
    Raleigh
    Posts
    730
    any progress?
    VQ38DETT with ProEFI128 on Twin 6262
    Corn Fed
  11. #9
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    No new progress at the moment. Waiting on v3 to move forward. Also trying to find information on SMG integration.
  12. #10
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    I'm in the process of doing the v3 conversion now, and will report back if this is resolved in v3 (which I'm going to guess it is.)
    -Matt
  13. #11
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    As an update, V3 progress is stalled until ProEFI comes up with a V3 firmware for the M54 BMW. As of now, only the generic firmware exists. There is V3 firmware that works for the M3 (and it gets ECT and TPS values), but will not start on my vehicle due to digital crank vs VR crank (M3).
  14. #12
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    You MUST have your Air Control Source set to IAC for it to work! Mine was set to ETC, and that was the problem.
    I now have idle that doesn't suck.
    -Matt
  15. #13
    Join Date
    Sep 2013
    Location
    New York
    Posts
    47
    Thinking more on this, I think the behavior is not surprising.
    I told the unit that I was using the Electronic Throttle Control to control idle.
    I have no Accelerator Pedal Position Sensors assigned. I have no TPS assigned aside from CAN.
    Thus the unit had no idea when the "ETC" was actualy "off idle", which in this case, would not be, ever, as it's not being controlled.
    I just wish I thought about that a bit harder a few weeks ago.
    -Matt
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Replies: 11
    Last Post: 10-25-2006, 11:21 AM
  2. a/c stuck on
    By 1-2 clutch u in forum MKIII Technical
    Last Post: 08-11-2004, 01:43 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
