High Powered 5MGE
+ Reply to Thread
Results 1 to 7 of 7
Thread: High Powered 5MGE
  1. #1
    SC400 Newb rpk2012's Avatar
    Join Date
    May 2002
    Location
    Lubbock, TX
    Age
    31
    Posts
    1,438
    High Powered 5MGE
    Hello all. I dunno how I would search for this so.... Here it goes.
    I am planning on rebuilding my 5MGE while my car gets painted. As I was looking on celicasupra.com I saw some nice upgrades I can do for better performance. Here is a list of what I am doing. I have some questions though so please bare with me.
    Port, polish, 3-angle valve job w/ stronger valves and springs for cylinder head
    More aggressive cams
    Bore out cylinders w/ bigger pistons and crank
    Thinner head gasket to raise compression
    Retune AFM and/or increase fuel pressure
    Adjustable cam gears
    Bore out throttle body w/ larger intake pipe and a ram air setup
    Nitrous. 50
    Really its everything they were saying people can do with the 5MGE. But here comes the questions.
    --What type of valves and valve springs should I get and where to get them? What are the specs on them so I know exactly what I need?
    --What cams should I use? I hear AEM are nice cam gears.
    --OK a big question. When I walk into the shop to get my cylinders, what should I request? What pistons and what crank should I get and use? Size and specs? What should I ask them to bore it out to?
    --Adjustable cam gears. again, no clue what I should get. I have read that the adjustable cams with three screws and not good to use. They are not as reliable I have heard.
    Lastly I am thinking of going with rabidchimps Performance Throttle Body.
    I am sorry for all the questions but I am trying to learn and this is a new experience for me.
    BTW - I have an 83 P-Type.
    Current-
    '15 VW Jetta TSi - DD
    `89 Toyota Supra Turbo RHD 5-Speed - 1JZ-GTE VVTi Swap in progress.(Running)
    OLD- `91 Toyota Supra Turbo 5-Speed - 2JZ-GTE VVTi
    '06 Lexus IS250 AWD
    '92 Lexus SC400
    `94 Lexus GS300
    MANY 1j MKIII, 2 GTE MKIII's
    '83 P-Type
    JDMVIP - RHD Owners Group & Information
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    villerat
    The first question is how much power you wont? there are many ways of going about it. first, is the 5m going to meet the goals of the power and the money you're puting in?
    there are 6m, 7m, 1jz, 2jz, ect.. engines to think about to lower your cost and the big question is parts. Parts on a 5m and 6m are not ez to find and can cost more. just somethang to think about.
    villerat
  4. #3
    '85 Supra P-Type awilmut's Avatar
    Join Date
    Jul 2001
    Location
    Ottawa, Ontario, Canada
    Age
    35
    Posts
    308
    7M, 1JZ, 2JZ, lower costs? BAHAHAHAHAHA....
    Andrew
    '85 p-type
  5. #4
    Join Date
    May 2002
    Location
    Lubbock, TX
    Age
    31
    Posts
    1,438
    I am looking for just enough power to play with. I am getting a 3rd gen in a few months so I don't see a need for a swap. I cannot even get my tires spinning in water atm. My car is acting SLOW. BTW what do these run stock in the 1/4 mile? Thanks
  6. #5
    Registered User BillyM's Avatar
    Join Date
    Feb 2002
    Location
    Greenville, SC
    Age
    31
    Posts
    722
    thought about turboing the 5m? look at the top of the tech section for everything you want to know about it....
  7. #6
    Just some guy Racefiend's Avatar
    Join Date
    Feb 2002
    Location
    Bay Area, CA
    Age
    38
    Posts
    1,919
    Yes, just turbocharge it. You'll spend 1/4 of the cash and get just as much if not more power than all you listed. Its reliable too, as long as you don't get greedy with the boost (speaking from experience)
    Christian
    Click here to enlarge
  8. #7
    Twin-Turbos 2X the Proble Kingsoup's Avatar
    Join Date
    Feb 2002
    Location
    Calgary
    Age
    37
    Posts
    1,117
    Meh, a shop that bores and builds a 5MGE would be quite expensive. If you want too bore it out, just buy the 6MGE, its a pre-built stroker.
    Really, you could spend thousands and thousands on it, and end up with lesser a motor then a 1JZ. I wouldn't bother with turbo 5M or 6M, avoid the 7MGTE as its a piece of crap motor. You could spend 10k and still end up with less a motor then the 1JZ is from the factory.
    Your only route is 6MGE or 1JZ-GTE, I wouldn't even consider anything else, too costly, or too troublesome.
    1988 Toyota Supra Turbo
    Completly rebuilt and replaced
    Modified and Stuff
    1993 Mitsubishi 3000GT VR-4
    Lots of Mods
    400+hp
    1990 Toyota Celica GTS
    I love this car!
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
