Field's SFC Hyper R Fuel Controller
+ Reply to Thread
Results 1 to 19 of 19
Thread: Field's SFC Hyper R Fuel Controller
  1. #1
    ElusiveStreetRacing elusivesuprat's Avatar
    Join Date
    Dec 2002
    Location
    North Palm Beach
    Posts
    27
    Alright i have never heard or this fuel controller before...does anyone have one or know if its worthy?
    ESR "Not the fastest, Simply the hardest to catch!"Click here to enlarge
  2. Remove Advertisements
    SupraForums.com
    Advertisements
  3. #2
    BPU is so 1997
    Join Date
    Feb 2001
    Location
    Ohio
    Posts
    6,953
    Andi B endorses it.
  4. #3
    Team ZTP LateralusFU's Avatar
    Join Date
    Aug 2001
    Location
    Dallas, TX
    Age
    36
    Posts
    289
    I plan on getting this in a few months. Several Dallas guys have it and like it. It has 3 maps you can store so you can tune one for race gas and one for pump!
    Adam
    -09 Cyber Gray Z06
  5. Remove Advertisements
    SupraForums.com
    Advertisements
  6. #4
    BPU is so 1997
    Join Date
    Feb 2001
    Location
    Ohio
    Posts
    6,953
    I have one sitting in my toolbox awaiting installation as well.
  7. #5
    Supra OG
    Join Date
    Feb 2001
    Location
    Frisco, TX
    Age
    35
    Posts
    1,372
    Cheers,
    Andi
    Supra OG
  8. #6
    SupraForums Member
    Join Date
    Feb 2001
    Location
    Florida
    Posts
    3,105
    I have that Field SFC unit. I like it. IMO, in real-world use the Apex S-AFC is probably the best fuel controller, and this Field unit is perhaps the 2nd best.
    Steve Hayes
  9. #7
    Senior Member
    Join Date
    May 2001
    Location
    OC, California
    Posts
    645
    Why? Erratic behavior or other? Looks like this is better: Adjustment ranges from +/- 50%. The Super AFC boasts an 8-point adjustable fuel curve with 500 RPM increment setting points. The Fields can go +/- 30% on 8 points in 1000 rpm increments.
    I'm leaning towards the Fields so I can have a map without meth, with meth only, and with meth + 50 shot of NOS.
    Also, I cannot get the AFR below 10.4 with the GCC at max fuel pull. I've even tried pulling out 2 clicks on the VPC and still 10.2 AFR on meth.
    So, I'm hoping that the Fields unit will help me pull out more fuel on meth only plus then have another setting, presumably pulling out less fule when spraying a 50 shot on top.
    TIA!
    manual on MKIV
    http://www.mkiv.com/techarticles/sfc/
    Steve Hayes
    98 TT 6spd Black/Black BPU++'s (SOLD Sad Day :( )
    If it's got a motor, race it!
    07 BMW 335i - 6 speed, 19" CSL Reps, Titanium Silver, Juice Box S2 & HOS Switch
  10. #8
    SupraForums Member
    Join Date
    Feb 2001
    Location
    Florida
    Posts
    3,105
    Spool, are you asking me why I say the S-AFC is better? I like the adjustable RPM points of the AFC, though I've had very little problem getting the curve flat enough with the fixed 1000 RPM increments of the SFC.
    IME, if you start making wild swings in the adjustments -- for example, adding 15% at 4K RPM and pulling 25% at 4500 RPM -- The AFR curve may just go crazy -- it may stop responding in a linear fashion relative to the input on the fuel controller. What I'm trying to say is that it seems that the factory ECU with piggy back units doesn't like wild swings in the fuel curve.
    Here's an example: Once, on the dyno, we were trying to flatten out a rich dip at 4K RPM and a lean spike in the 5K RPM range. We were pulling a bit of fuel at 4K and then adding a good bit at 5K RPM. Once we got the swing to about 20% total (say, pulling 10% at 4K and adding 10% at 5K), the AFR started going in the opposite direction we were adjusting for. By that I mean we'd add fuel at 5K RPM, and the AFR would get even leaner there. Then, we went back, zeroed everything out, and started from scratch without the wild swings, and it smoothed up nicely without pulling or adding more than a few %.
    If you are having to adjust more than the 30% that the SFC will allow, there's probably something wrong with the car somewhere (though I understand in your particular case you are thinking about pulling fuel to be replaced with methanol).
    FWIW, my AFR is just about dead flat at high 11s with the VPC and SFC all set flat (no boost or cut). I think I'm pulling about 1 or 2% in a place or two on the SFC, but otherwise everything is flat. It just works out that way on my car with the VPC C chip, SFC, GA head and intake, 264 cams, and 74GTR turbo.
    Steve Hayes
    TIA!
    manual on MKIV
  11. #9
    SupraForums Member BLITZSUPRA's Avatar
    Join Date
    Mar 2001
    Location
    Atlanta, GA
    Posts
    2,605
    I use it, it is beautiful in its simplicity. I have a pump gas-17 psi map, race gas map for 25 psi and the last one for 28 psi, all changed by touching one button.
    '94 Supra T
  12. #10
    Useless Member KReddy05's Avatar
    Join Date
    Oct 2003
    Location
    Vegas/NYC
    Posts
    717
    So how was the install? How does this compare to the SAFC2?
    95 Black/Black TT 6-spd
    12.07 @ 118.4
  13. #11
    SupraForums Member
    Join Date
    Feb 2001
    Location
    Florida
    Posts
    3,105
    Install is pretty simple. Just hard-wire it in to the Field's harness (or the PHR alternative to the Field's). Of course you COULD hardwire it into the factory ECU harness, but IMO you should NOT make modifications to the factory ECU harness -- you should always use a Field's type harness for adding piggy-back electronics. There just isn't enough excess wire on the factory ECU harness, and with all the screwing around, you're likely to evenually cause connection problems or something if you don't use a harness extension like the Field's.
    Steve Hayes
  14. #12
    Join Date
    Oct 2003
    Location
    Vegas/NYC
    Posts
    717
    does the safc2 let your store maps like the fields? if so, how many?
  15. #13
    Super Big D. Moderator White_lightning's Avatar
    Join Date
    Feb 2001
    Location
    DFW, Tx
    Age
    41
    Posts
    1,461
    I have it .. and love it..
    check it out..
    http://www.jadesupra.net/Supra.html
    D.
    2008 C6 BPU++
    Tuned by Sam.
    No matter how fast light travels it finds the darkness has always got there first, and is waiting for it.
  16. #14
    10'S BABY REDL1NE's Avatar
    Join Date
    Jan 2004
    Location
    Home of 7 National Championships
    Age
    35
    Posts
    3,787
    Just saw this as I was searching through the archives...good link
  17. #15
    SupraForums Member ::MySTiK_[SuPRa]::'s Avatar
    Join Date
    May 2002
    Location
    Massholechusetts
    Posts
    2,705
    Another happy Fields SFC user here.
    -Phu
    1994 White Supra 6SPD T67DBB
  18. #16
    SupraForums Member
    Join Date
    Apr 2005
    Location
    Posts
    1,604
    It's old school but it works well. Funny this post should get dredged-up (must be a noob).
  19. #17
    Join Date
    Jan 2004
    Location
    Age
    35
    Posts
    3,787
    Quote Originally Posted by MtFujiSupra
    Actually not a noob, just thought I'd use the ol search button as opposed to starting a new thread and Mystik was nice enough to help me out.. Thanks again
  20. #18
    Join Date
    May 2002
    Location
    Massholechusetts
    Posts
    2,705
    Quote Originally Posted by 89MKIIIT
    Hey man,
    Did you figure out what the problem was?
    -Phu
  21. #19
    Join Date
    Jan 2004
    Location
    Age
    35
    Posts
    3,787
    Quote Originally Posted by ::MySTiK_[SuPRa]::
    Hey man,
    -Phu
    Ya sure did. I just coupled it with the VPC and its good to go. The Yellow wire from the VPC to the input of the SFC then SFC output to ECU. Works great. Thanks again
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
